If you could only pick one of these lenses for events, which?
Started Jan 15, 2017 | Questions
ArtByLukeBennett
ArtByLukeBennett Regular Member • Posts: 145
I already own the 35mm F2 and the 16 - 55 F2.8 for the X-T2.
For the purposes of events work, wedding in particular, which of the following would you add to the collection, ignoring price for the moment:
56mm F1.2
90mm F2
50 - 140mm F2.8
And why? Thanks.
 ArtByLukeBennett's gear list:ArtByLukeBennett's gear list
Canon PowerShot G3 Fujifilm X-T2 Fujifilm XF 56mm F1.2 R Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR +1 more
Fujifilm XF 50-140mm F2.8 Fujifilm XF 56mm F1.2 R Fujifilm X-T2 XF 90mm
Stflbn Veteran Member • Posts: 3,733
Re: If you could only pick one of these lenses for events, which?
Definitely 50-140.   Mainly because it's versatile, fantastic,  and I use it as my primary lens at most events I shoot.
Fuji X-T2 | X-pro2 | X-T1
16 1.4 | 23 1.4 | 56 1.2 | 16-55 2.8 | 50-140 2.8
http://501concepts.com
 Stflbn's gear list:Stflbn's gear list
Sony RX100 V Sony a6500 Sony a7 III Sony FE 55mm F1.8 Sony FE 28mm F2 +9 more
michaeladawson Forum Pro • Posts: 18,313
56mm F1.2
90mm F2
50 - 140mm F2.8
And why? Thanks.
You'll get a lot of votes for the 56 f/1.2.  But I would go with the 50-140.  If you only have 3 lenses I think you will get a lot more use out of the focal length range offered by having the 50-140 in the bag.  The 56 f/1.2 will undoubtedly give you beautiful brides portraits and the wide aperture will be useful in a lot of cases.  I just think with just three lenses you would get more usage from the 50-140.  If you get a fourth lens get the 56.
Mike Dawson
 michaeladawson's gear list:michaeladawson's gear list
Nikon D7200 Nikon D5 Fujifilm X-T2 Nikon D850 Fujifilm X-E3 +39 more
OrdinarilyInordinate
OrdinarilyInordinate Veteran Member • Posts: 3,741
50-140mm f/2.8 for the reasons of silent and fast AF (56mm f/1.2 is generally not at all fast in low light--I know well because I use it regularly indoors with X-T1, all on the latest firmware), very good OIS, and versatility of focal length range. It's a very nice sharp lens too. When it comes to capturing the moment quickly, I'd trust that lens more than 56mm f/1.2 to do it on split notice.
The 90mm f/2 is by all accounts a gorgeous lens, but more limiting in terms of being quite long. For staged portraits, any of those lenses will be great. For continuous event photography where people are moving about and doing different things, I'd go with the 50-140mm f/2.8.
Also for event photography, I hope you are able to use flash (either bounce on the camera or some strategically-placed light stands), in which case the fact that the zoom is only f/2.8 at the brightest should not be an issue.
With all that said, I had a great time with the little normal prime 35mm f/1.4 at my friend's wedding where I was a guest. I unobrtusively captured a few photos of my friends and the wedded couple, and that focal length was great for almost everything, and the f/1.4 aperture was very helpful, because I did not use flash (and limited myself to full electronic shutter for silence).  It was a great documentary type lens for the general party scenes.
 OrdinarilyInordinate's gear list:OrdinarilyInordinate's gear list
Nikon Coolpix A Fujifilm X-T2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +4 more
Yake Senior Member • Posts: 1,531
But who cares what I would pick?  Pick the lens *you* want to shoot with.
 Yake's gear list:Yake's gear list
Sony a7 III Canon EOS RP
stevo23 Forum Pro • Posts: 24,759
56mm F1.2
90mm F2
50 - 140mm F2.8
And why? Thanks.
Hard to decide between 56 1.2 and 50-140. The bokeh is unrivaled with the 56, so you can really use that. But the 50-140 will cover more bases for you.
90 feels a bit tight for a lot of shots and you'll not want to put it on the camera every time you need it. 50-140 covers a lot of bases.
 stevo23's gear list:stevo23's gear list
Fujifilm X-Pro2 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 27mm F2.8 Fujifilm XF 23mm F1.4 R +3 more
MarcosV Veteran Member • Posts: 6,522
For event work, here's another vote for the 50-140/2.8.
I own the 56/1.2, 90/2, and 50-140/2.8.  It's one thing to shoot portraits of people posing for your shots; it's something else when you must quickly capture the shots you need, where you may not have time to zoom with your feet to get the framing you want.
The 50-140 is also longer than the 90; which can fill your long reach or tight framing options.
Sure you aren't going to get the super shallow DOF of the 56/1.2 or 90/2, but, it will get you the DOF you need when everyone in your image needs to be in sharp focus and you still have a good chance of getting sufficient background blur in a lot of situations.
I love primes; but, I would focus on primes after you get a second body so you have two lens at the ready.
 MarcosV's gear list:MarcosV's gear list
Sony RX100 IV Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 16mm F1.4 R WR XF 90mm +28 more
ArtByLukeBennett
OP ArtByLukeBennett Regular Member • Posts: 145
Thank you for all the replies so far everyone. It has pretty much cemented what I thought already. I do fully intend to get a second body if and when the opportunity to make some income presents itself. And with respect to the lenses, they'll get plenty of usage regardless.
ejw07
ejw07 Regular Member • Posts: 469
90mm f2
E.W.
Vistaview Regular Member • Posts: 400
Wouldn't it be good to have something wider? What if you have to shoot groups of four, five or six people in tight quarters? Even 50mm on a crop sensor is pretty tight. You'd have to back up a lot to fit everyone in.
 Vistaview's gear list:Vistaview's gear list
Fujifilm X-T2 Samyang 12mm F2.0 NCS CS Fujifilm XF 35mm F2 R WR
He already owns the 16-55 f/2.8.  It's certainly wide enough.
Right you are -- I'm missed that.
XEddieX Contributing Member • Posts: 766
Another vote for the 50-140mm. I already had the 90mm but decided to get the 50-140mm lens for mostly ceremony use and some reception use. My primes are more for posed or a bit more relaxed sessions during the wedding day. I'm still planning on getting the 56mm,just having a hard time deciding between regular one or ADP (used is only $100-150 more than regular one)
caesarb Contributing Member • Posts: 606
50-140mm f/2.8 - due to versatility and speed required by dynamic nature of event photography.
liquid stereo
liquid stereo Veteran Member • Posts: 7,286
Versatility or second camera
56mm F1.2
90mm F2
50 - 140mm F2.8
And why? Thanks.
If you have a second camera I suggest the 90/2. Coupled with our other lenses, you're in good shape.
If you have only one camera I suggest the 50-140/2.8.
You may want to rent the 50-140/2.8 first. I found it a bit weighty and for that reason only, I will not add it to my kit.
 liquid stereo's gear list:liquid stereo's gear list
Fujifilm FinePix X100 Canon EOS 7D Canon EOS-1D X Fujifilm X-Pro1 Fujifilm X-Pro2 +10 more
