M3 and M5 USB charging?
Started Jan 15, 2017 | Questions
Ryan New Member • Posts: 12
Hi,
Anyone has any experience with whether these cameras can be charged via USB? If so is it a standard USB cable and how long does it take to charge up a battery?
Canon EOS M3
FallenLeaf Photography
FallenLeaf Photography Regular Member • Posts: 475
Re: M3 and M5 USB charging?
The M3 cannot be charged via USB.  I have a second battery and a mobile charger that can plug 2 batteries into it, and that can be plugged into a USB to charge.  I keep a mobile USB battery on me and the setup works great as I can either charge via device or have 1-2 batteries charging in my bag, with one in my camera.
 FallenLeaf Photography's gear list:FallenLeaf Photography's gear list
Olympus E-M5 II Olympus 12-40mm F2.8 Pro
Xiaomu New Member • Posts: 6
to my knowledge, it doesn't support usb charge.
P Jordan Forum Member • Posts: 66
The M3 and M5 do not have the necessary circuitry for USB charging, you have to take the battery out to charge it.
 P Jordan's gear list:P Jordan's gear list
Canon EOS 5D Canon EOS M Canon EF 17-40mm f/4.0L USM Canon EF 70-200mm f/2.8L IS USM Canon EF-M 18-55mm f/3.5-5.6 IS STM +4 more
OP Ryan New Member • Posts: 12
Thanks all, I have less hopeful on the M3 but thought I read somewhere the M5 has it.... Oh well.
Actually by the looks of things there should be an update on all standard USB charging cameras to the Type C USB ports...its quicker for phones a tablets. Should work the same for cameras..... Dont like carrying too many chargers around.
mrshadowstreet New Member • Posts: 2
yep, standart USB cable is used to charge up your photo device
Andy01 Veteran Member • Posts: 5,188
Not only are you 5½ years late to this thread (it was answered in 2017), but your information is incorrect for the question that was asked. These two "photo devices" (M3 & M5) CANNOT be charged using a standard (or any other) USB cable.
The OP (person you replied to) has also not posted on DPR in 4½years.
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
KEG
KEG Veteran Member • Posts: 4,908
You aren't entirely correct, I can put the battery from either of them into M6 mk II, RP or R10 (or any other late entry canon which uses LP-E17) and even use external powerbank to charge because those 3 use dog standard USB-C.
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
Look again. The OP (many years ago) asked if it was possible to charge the M3 or M5 CAMERAS with USB. The question wasn't whether the batteries from those cameras could be charged with USB.
Third party USB battery chargers have been around for a while (no need to use a different camera to charge the batteries in), but that wasn't the original question.
barbara j Contributing Member • Posts: 781
This old thread reminds me, what a pain in the neck it was not being able to plug in the camera to charge the batteries.
 barbara j's gear list:barbara j's gear list
Canon EOS M3 Panasonic Lumix DC-GX9 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Panasonic 12-60mm F3.5-5.6 OIS +4 more
