40-150 f2.8 bricked by EM1mkii
Started Jan 14, 2017 | Discussions
Photo Pete Veteran Member • Posts: 5,430
Just tried updating the 40-150 f2.8 with Olympus Camera Updater via the EM1 mkii.
As soon as I pressed 'update' I got a message on the computer screen saying 'unable to communicate with camera'. The rear of the camera was, however, showing the updating symbols. Assuming that the camera was actually updating despite the 'failure to communicate' message, I left the camera connected to the computer in that state, waiting for the OK message to display, until the camera eventually turned itself off (must have been around 50 minutes).
Result - a totally bricked 40-150 f2.8 lens. Turn the camera on with the 40-150 connected and it doesn't display any image. It won't autofocus or respond in any way whatsoever.
Bl**dy stupid that the update process can put the camera and lens at risk like this should some communication error or software error occur.
Anyone know of a way to rescue the lens without sending it back to Olympus?
Have Fun
Photo Pete
Olympus 40-150mm F2.8 Pro Olympus E-M1
Aberaeron Forum Pro • Posts: 10,184
Re: 40-150 f2.8 bricked by EM1mkii
Firstly check out the update procedure again. Carefully.
Then try doing the update procedure again. If necessary, repeat.
If after all of that, it still fails, get help.
(unknown member) Veteran Member • Posts: 7,274
The body can be recovered by copying firmware to SD card and initiating a firmware flashing. But I wonder three things:
1) Either lenses requires a totally own update device for recovery, forcing you to send it to Olympus.
2) Lenses firmware can be flashed same way as the bodies, by firmware itself informing body that it is specific lens firmware and body does it like it does it for itself.
3) Lenses firmware initiation is different from body, so far unknown.
As we already know, the body itself can read a firmware from the SD card and start flashing itself. You don't need a computer to do it because the camera is the computer to do it, just in a "recovery mode" where it goes when you initiate it via computer itself over USB.
And I think that if the engineers has been smart enough, the situation is like in 2, you have the firmware telling to the recovery mode that update the firmware to lens. If I would have a bricked lens, I would risk for it, but as I don't I am not going to test it
Then that would have a problem, as we know how you can download a firmware from Olympus server without their software and how to rename it for card for flashing, I haven't seen any way to download the lens firmware and how it should be renamed to do downgrade.
Okapi001 Veteran Member • Posts: 5,145
You can do absolutely nothing with the bricked lens. The camera don't know there is a lens attached and you cannot initiate the update procedure. AFAIK the only way is to send the lens to the Olympus for repair.
It happend to me a few weeks ago with the 300mm (I think computer lost USB connection during the upgrade). The repair was covered by the warranty, so no real harm done (and they cleaned the lens for free;-) . But I will check what happens to the bricked lens after the extended warranty expires, and if the repair is not free, I will never try to upgrade it myself. It seems it's all too easy for something to go wrong.
 Okapi001's gear list:Okapi001's gear list
Olympus OM-D E-M10 II Olympus PEN-F Olympus E-M1 II Olympus OM-D E-M1X OM-1 +18 more
453C Veteran Member • Posts: 7,087
It wouldn't hurt to carefully clean the body & lens contacts, and make sure it's fully locked in the mount. Those problems can strike any gear.
Also, if you have an old body around, give the lens a try on it and see what happens.
Please let us know how it works out, and good luck.
MickeyVee
MickeyVee Regular Member • Posts: 445
The same thing happened to me a couple of months ago with my 40-150 Pro.  Unless the updater can see the lens, you're bricked.  If it still can, you can try the update again.  Fortunately mine was still under warranty and the Olympus Service Centre is a 5 minute drive from me.  Had it back in a couple of days.
Good Luck!
 MickeyVee's gear list:MickeyVee's gear list
Olympus E-M1 III Olympus 12-100mm F4.0 Olympus PEN-F Olympus E-M5 III Olympus M.Zuiko Digital 17mm F1.8 +2 more
OP Photo Pete Veteran Member • Posts: 5,430
7
Good Luck!
Thank-you all for the replies.
It seems like the lens is well and truly bricked. The updater cannot see the lens anymore so I have no way to start the update process again. I certainly don't like the idea of hacking the update with a SD card in the camera (particularly not with the new EM1mkii being the camera!).
Olympus warranty for the 40-150 is in place until June 2017 so it will have to go back for a warranty repair. Hopefully it will be repaired without any undue hassle, although I have a football match to shoot tomorrow and I'm a bit p****d of at having to shoot it with the 75-300 rather than the 40-150 and mc-14.
What a stupid way to carry out updates. Why do Olympus force us to risk communication errors when they could have an official system to update from SD cards instead?
Several of my other lenses are waiting for firmware updates and I'm too nervous to try doing them now.
Have Fun
Photo Pete
Mark Thornton Veteran Member • Posts: 4,570
I note that Panasonic bodies do perform the update from the SD card and will also update Olympus lenses in this way. So if you want to use the SD card approach, get a (cheap) Panasonic body.
 Mark Thornton's gear list:Mark Thornton's gear list
Panasonic Lumix DMC-GX1 Panasonic Lumix DC-GX9 Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +8 more
Good to know.
Nikon also perform updates from SD cards. Not sure about other manufacturers as I've not used them... but I'd be interested to know if anyone other than Olympus uses the stupid approach that requires uninterrupted connectivity to the computer during the update process itself.
I've just taken the plunge and updated my 12-40 f2.8 with no problems, so the error seems to have been a random connection failure. With proper design by Olympus that sort of error need never impact upon the firmware update of a £1200 lens. Shame on them.
Have Fun
Photo Pete
samtheman2014
samtheman2014 Veteran Member • Posts: 4,571
Good to know.
Sorry to hear about your woes Pete I am new to Sony and my camera came with the latest firmware but it looks like they have a similar process involving a PC .
http://briansmith.com/guide-to-sony-camera-firmware-updates/
I must say the Panasonic and Nikon method of doing it in camera with a card seems much less of a fouter .
Have Fun
Photo Pete
Hoepfully it will be remedied quickly
Jim I am Sam I am not
 samtheman2014's gear list:samtheman2014's gear list
Panasonic FZ1000 Panasonic Lumix DMC-GH4 Sony a7R II Panasonic Lumix DMC-GX8 Nikon AF-S Nikkor 14-24mm f/2.8G ED +10 more
Clayton1985 Veteran Member • Posts: 8,802
Photo Pete wrote:
Good to know.
Fuji is also via SD card.    So far I haven't had any issues but I'm not at all comfortable with a process that doesn't allow for some type of do over in situations like yours.
radsaq
radsaq Contributing Member • Posts: 938
Good to know.
As a software developer, I'm surprised that it's even possible for this to happen.  What theyshould be doing, and what it appears like given the appearance of the update process, is:
  1. Download update file from to PC
  2. Verify checksum/signature of firmware file on PC
  3. Copy update file to camera
  4. Verify checksum/signature of firmware file on camera
  5. Erase existing firmware
  6. Apply new firmware from file
If this is how it worked, then the only failure case should be if power is removed after step 5 completes and before step 6 completes. If the initial download from the internet doesn't get a complete file, or the camera doesn't get a complete file from the PC, it is trivial to detect this. And certainly the camera shouldn't erase anything before it knows it has a valid update file.
Of course, I've never verified that these are in fact the steps that the Olympus update does take. But it certainly looks like it goes through a download, copy to camera, then flash step. Maybe they're not properly looking at signatures/checksums? This is fairly basic stuff, though. It shouldn't be hard to make it mostly bullet-proof (aside from potential loss of power to the camera).
 radsaq's gear list:radsaq's gear list
OM-1 Olympus 40-150mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro Olympus 25mm F1.2 OM System 12-40mm F2.8 Pro II +3 more
Good to know.
Exactly my thoughts. Communication errors should not be a risk to the update process if the update process is sufficiently robust. If the file is installed to the camera and checked before the update starts then there should be no need to be tethered to a computer at all when the firmware update is actually being applied.
However, the Olympus instructions clearly state that you should not disconnect your camera from the computer whilst it is being updated (until 'OK' is displayed on the camera rear screen)... so I guess the connection is required for something and we can assume that they are not installing in the way that you have indicated?
Regardless of the technicalities, I have found out the hard way that the update process is not particularly robust and that a lens can be rendered useless should a communication error occur, even when the user is following Olympus's instructions precisely.
Have Fun
Photo Pete
radsaq
I always assumed that the "don't disconnect until it's done" is there simply so that people don't get careless. But I've never been willing to experiment and find out.
I wouldn't like to experiment to find out the details either.... but I didn't really get a choice.
Have Fun
Photo Pete
karlreed Senior Member • Posts: 2,650
Rather scary.. 40-150 f2.8 bricked by EM1mkii
My experience of USB connections via hubs is that they can be AWFULLY flaky. So, this needs to be kept in mind if updates must be by a direct connection to the computer, ior, internet rather than via a card.
However, best practice for this kind of update is NOT to destroy the current version until the update is complete AND the system has been re booted.
This can be done by booting via a pointer to the active system. The VERY LAST THING the updating s/w does is to change this pointer to point to the new systems.
All the other comments about check sums etc. of course apply, however, tricks like this date back at least to the late 1970's. It's now 2017!
karl reed
 karlreed's gear list:karlreed's gear list
Sony RX100 III Nikon D750 Nikon Z6 II Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED +5 more
Re: Rather scary.. 40-150 f2.8 bricked by EM1mkii
That only works if you have space for both new and old to exist simultaneously. It is regrettably common to cut corners on space for firmware.
photohounds
photohounds Senior Member • Posts: 1,156
Tried another body yet?
Had equivalence disease when switching from 6x7cm to MINI 35mm format. Now cynical marketing men call it: "full (Marketing) frame".
Four thirds and MFT pics:
http://photohounds.smugmug.com/browse
Gear test samples - even some RB-67 shots:
http://photohounds.smugmug.com/Gear-tests
OMDs with dim-light action and smoke?
http://photohounds.smugmug.com/Performing-arts
 photohounds's gear list:photohounds's gear list
Olympus M.Zuiko Digital ED 75mm F1.8 Olympus OM-D E-M5 Olympus E-M1 Olympus E-M1 II Olympus OM-D E-M1X +7 more
photohounds
Or maybe there was a PC failure or a cable glitch? First time since 2003 [E-1] that I've heard of this.
Cheap 3rd party cables are never a good idea for serious stuff - I've even had partly saved pics with those
Lucky I don't erase the card before verifying as I would have been caught a couple of times.
But Chill!
Some old classics arrived!
Oly don't like USB hubs..Rather scary.. 40-150 f2.8 bricked by EM1mkii
I didn't chase this completely, however, I found this page
https://www.olympus.com.au/Support/FAQ-Trouble-Shooting/Digital-Cameras/What-can-I-do-if-I-could-not-connect-my-camera-wit
It contains this warning..
"Caution:
Computer may not be able to recognize the camera when you use USB HUB for connecting camera and computer. Please note the use of USB HUB is out of operation warranty. Please try connecting camera and computer without USB HUB if you currently use it.".
I'm not sure if it relates to the OP's problem, it IS worth keeping in mind.
karl reed
