dv312 wrote:
Frdric BERNARD wrote:
dv312 wrote:
Been through this route except the 12-100mm
Ended up selling both 25mm and 75mm
The 45mm is the best bang for the buck , cheap, sharp, yields great bokeh, so no need to sell
I just bought the 25mm 1.7 for it's a steal
I rarely use it but could be handy for street and close up portraits and documentary
The 75mm while a glowing lens is a tad too long for most circumstances
I will not buy the 12-100mm but will look seriously at the PL 12-60mm
Looking at your gear list, could not you replace 12-40, 14-150, 35-100 with just the 12-100 ? You have the extra prime lenses that could be necessary for low light / bokeh pictures when you want aa faster aperture than f4, and your PEN-F is compatible with Sync IS (perhaps you should use the grip with the 12-100), when you will not be able to use Double IS with the 12-60 and the Olympus bodies. Moreover, the bokeh at 60mm f4 will not be as good as it is at 100mm f4.
Thanks for the advice
I've looked long and hard at the 12-100mm ; still finds it too large and heavy for my everyday shootings
The 12-60 is smaller/lighter and I'm sure the PL brand would produce excellent optics
I 'll keep the 14-150 since it's cheap /small/light for casual shooting
May let go of the 12-40 once I get the 12-60
I have yet to decide whether or not to let go of the 35-100 since it's so good and light
In terms of bokeh, I'll have to resort to the 45mm 1.8 or the 35-100mm 2.8
The F4 lenses bokeh will not give me the looks I want at longer focals
The 12-100 is just fine on travel or for a one day hiking in the mountains or in the city or anything touristic. But for casual and social shots at home or with friends, it's a little big, but in fact it's quite the same with the 12-40 (and probably the 12-60). But the 12-100 is far more versatile than the 12-60 IMO, especially thanks to Sync IS for static subjects in low light situations.
Sync IS is one thing you just can not imagine the effectiveness before getting the lens in your hands mounted on the body.
Now I use the 12-100 with an E-M5II with grip when I am a tourist or when I need a longer range outdoors, and generally the E-P5 with a small lens for social shots, especially indoors : the 14-42EZ, the 20mm or the 25mm (which takes special shots with the subject always on a slightly blurred background, hard to use but gives far better results compared to a kit zoom).
I think a PEN-F with a grip could takes these both roles and usages
You would have IMO a better usage of a 100-300 or 75-300 for animals or birding, compared to the 14-150 and 35-100. Having in one lens the 12-100 range with high IQ is a special thing than only MFT gives to date.
