Samsung NX500 as an astrophotography camera
Started Jan 12, 2017 | Discussions
Phisci New Member • Posts: 10
Ive used my camera with an 85mm f1.8 lense ,  135mm f2 lense and 80mm f7.5 telescope and have had very pleasing results.  Anyone else using this great camera for star photography? Also how do I post pics?
Samsung NX5 Samsung NX500
markyboy81 Veteran Member • Posts: 4,778
Re: Samsung NX500 as an astrophotography camera
I haven't used it for that purpose yet but I plan to with the 12mm f2.0 lens.
You need to visit the desktop version of this site to post pictures, I'm interested to see what you've shot.
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
OP Phisci New Member • Posts: 10
Eta Carina to Southern Cross, 2min exposure using 85mm lens F1.8
Large Magellanic Cloud Galaxy. 2 minute exposure using 135mm F2 lens on NX500.
Both images were processed in Nebulosity (stacking, stretching etc) and Pixinsight (DBE tool to remove light gradients)
Amazing shots, I'm looking forward to trying this out when I finally get a clear sky here in the UK
TJL LTFF
TJL LTFF Senior Member • Posts: 1,728
Very nice work. Have you thought about posting a few of your photos in the DPR Astro Forum. I believe some members there could learn from and appreciate your efforts.
Thanks for sharing here, also.
 TJL LTFF's gear list:TJL LTFF's gear list
Sony RX1R II Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS +10 more
Thanks.  I'm only 6 months into the hobby so while I have learnt a few lessons I am far from proficient. At least the initial results are encouraging.  There is a very good beginners astro photography forum at www.cloudynights.com those guys really know their stuff.
TillmanB
TillmanB Contributing Member • Posts: 501
Very cool shots, how do you avoid the stars streaking from the rotation of the earth?  Do you have one of those devices that move the camera to compensate?  I've tinkered around with astrophotography using my Rokinon 12mm f/2 but without a means to compensate for rotation I find that anything over about 20 seconds results in noticeably elongated stars.
Yes,you have to use a "mount" that follows the rotation of the earth so that the stars don't streak. The best is the so-called equatorial mount, but Alt-Azumith mounts can also be used.
As a general guide, astro-photography requires several elements:
1. Reasonable camera
2. for wide field views, a 50-80mm will do. Faster (lower F ratio) is better. I use 45mm f1.8 and 85mm F1.8
3. For more detailed narrow field field views, you'd need something like an 80mm refractor telescope, around F7
4. An adaptor to connect camera to scope
5. An equtorial or Alt-Az mount
6. Good processing software and a fast laptop
7. Lots of patience to learn to use the kit well.
The processing software is where the real magic lies in getting good images once the photons have been collected by the camera.
TillmanB
Thanks for the info, I might get serious one of these days and get the required equipment.  My method of taking 20 second exposures is a pretty sad compromise between minimal streaking and keeping the ISO down enough that things aren't a noisy mess.
noncho
noncho Regular Member • Posts: 348
Here is one from me with Samyang 12 2.0:
85 1.4 is good for telephoto, you can see interesting details. But you have to use no more than 3-4 seconds exposure.
www.NonchoILiev.com
 noncho's gear list:noncho's gear list
Canon EOS-1D X Samsung NX1 Samsung NX500 Canon EF 85mm F1.2L II USM Samsung NX 30mm F2 Pancake +11 more
What happens if you use longer exposures?
noncho
The movement of the stars become visible and it's not nice.
www.NonchoILiev.com
