Wide lens advice
Started Jan 11, 2017 | Discussions
petercarleton New Member • Posts: 3
Wide lens advice
Hi,
I have a Canon 60D with a 50mm 1.4 lens.
I want to use it for taking overhead photos of food in my kitchen but I can’t get the camera far enough away without hitting our low ceiling.
Can anyone recommend a cheap wide lens that will help me fit everything in?
I’ve been looking at the: Canon EF-S 24mm f2.8.
Does anyone know if this lens would be wide enough? I’m hoping to take shoots about 2 feet above the food.
Thank you for any advice in advance.
Canon EF-S 24mm F2.8 STM Canon EOS 60D
KENTGA Veteran Member • Posts: 8,733
Re: Wide lens advice
I'd suggest a 10-22 (or similar) zoom. It will be useful for other photography.
Kent
 KENTGA's gear list:KENTGA's gear list
Canon EOS 7D Canon EOS 6D Canon EOS Rebel SL1 Canon EOS 80D Tamron AF 18-270mm F/3.5-6.3 Di II VC LD Aspherical (IF) MACRO +14 more
PaulProz Junior Member • Posts: 40
I just tested it for you with a 70D and EF-S 24 STM and 2 feet easily gets a large dinner-plate in the frame.
I use the 24 a lot for general indoor photography. I have the 10-18 as well, but the 24 is so much faster, for indoor light it's much nicer when not using a flash.
 PaulProz's gear list:PaulProz's gear list
Fujifilm X100S Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS Fujifilm XF 35mm F2 R WR +1 more
Peter Kwok
Peter Kwok Senior Member • Posts: 2,635
High school trigonometry
According to Canon Japan website here: the EF-s 24mm STM covers 50°35’ horizontal and 34°55’ vertical.
With some math, at 2 feet directly above your food, the 24mm lens can cover 1.88 x 1.25 feet.
Peter Kwok
Click here for my PBase gallery
WYSIWYG - If you don't like what you get, try to see differently.
 Peter Kwok's gear list:Peter Kwok's gear list
Canon EOS 5DS Canon EOS R5 Canon EF 16-35mm F4L IS USM Canon RF 14-35mm F4L IS USM Canon EOS M6 +8 more
OP petercarleton New Member • Posts: 3
Perfect Paul. I'll go for that lens then. Thank you!
Re: High school trigonometry
Thank you very much for taking the trouble to do that Paul. Much appreciated.
Ronomy
Ronomy Veteran Member • Posts: 4,062
24mm stm is a nice lens but the 10-18mm is pretty fantastic too.  Add it to your wish list...You'll be impressed with it.  Very sharp!  Must have for super wide.
 Ronomy's gear list:Ronomy's gear list
Canon PowerShot SD800 IS Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-FZ200 Canon EOS 7D Canon EF-S 15-85mm f/3.5-5.6 IS USM +6 more
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Good advice here already. Have you considered setting the food on the floor on a tablecloth?
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
