Lens suggestion for speakers at conferences
Started Jan 10, 2017 | Discussions
(unknown member) Forum Member • Posts: 83
Re: Lens suggestion for speakers at conferences
Kaso wrote:
Tronhar wrote:
Kaso wrote:
Tronhar wrote:
I strongly recommend looking at a monopod.
This.
A monopod was part of my recommendation, posted earlier.
Is it an issue for you that I did not specifically reference your statement?
Life is too short and precious to "take issue" with forum posts.
I was highlighting a point of agreement. I was not attacking you. On the contrary, I was doing "thumbs up." Oh well...
Then I humbly apologise if I misconstrued your expression.  It is a perfect example of when we can only read and not appreciate the tone of voice of the communicator that we can misunderstand the expression.   I was in your position at one time and got a piece of advice to liberally use emoticons to show my state of mind.  Hopefully I can continue to do that!
We are not remembered for the gear we use, just the images we capture or create.
Kaso Veteran Member • Posts: 4,488
Please do was you wish. I continue to think positively and err on the side of friendliness even in the absence of decorative symbols.
Absolutely...  and I wish you all the best.
AdriaanMeijer
AdriaanMeijer Veteran Member • Posts: 3,047
I know these lenses
Pepege wrote:
I have though of the following two lenses:
  • Canon EF-S 17-55mm 2.8 IS USM
  • Canon EF 70-200mm 4.0 L IS USM
I have these lenses and they are very fine lenses indeed. I prefer the 70-200 most of the time, but that has to do with taste.
I'm not too sure about video. I don't do video. Once I did a test video with the 70-200 and the sound of the IS was way to loud to be useful. You'll need an external mic for that. Or a tripod and switching IS off.
The IS and AF of both are good. But they add to your skills of holding the camera to reduce camera shake. I have some nice shots at 1/20 at 200mm, tack sharp, but where the subject was capable of making large movements creating useless photos. Peter Kwok adressed this.
Or would you recommend the Canon EF 70-200mm 2.8 L IS II USM instead? It is definitely more versatile, but quite expensive and heavy compared to the others...
Well that is a fine lens indeed!
What it adds -compared to the f/4- is shallow DOF and a whole stop of light.
The costs -apart from money- are weight and size. Not always a problem, but it might be intrusive and it might be troublesome to use for a longer period of time, like holding it up without monopod for 10 minutes.
Aditional:
I'd shoot RAW to be able to restore some Powerpoint imaging in post processing.
If you're going to be at different places with different light, be early and do something with a grey card to have the WB okay.
All in my humble opinion of course!
If I seem to talk nonsense or you can't understand me, it's probably my English
 AdriaanMeijer's gear list:AdriaanMeijer's gear list
Canon EOS 7D Canon EOS 600D Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-200mm F4L IS USM Canon EF-S 18-55mm f/3.5-5.6 IS II +5 more
OP Pepege Regular Member • Posts: 387
Thanks, both to your, for your suggestion!
I also bought a monopod now including some lens plates. And I am glad that you considered 2.8 as too slow, this makes my investment in the Sigma 1.8 feel right!
Thanks again!
Peter
 Pepege's gear list:Pepege's gear list
Canon EOS 80D Canon EF 70-200mm F2.8L IS II USM Canon EF 35mm F2 IS USM Sigma 50-100mm F1.8 DC HSM Art Canon EOS M5 +11 more
both are too slow for indoors in conference rooms
  • Canon EF 85mm 1.8 USM
  • Canon EF 100mm 2.0 USM
eithervwill work
  • Canon EF 135mm 2.0 L USM
probably too long for aps-c indoors
Thanks for your advice, it underpinned my decision to go for the Sigma 50-100 1.8 which will remove to need to switch between 3 primes...
You didn't mention external flash. They are great if ceiling is near white for bounce flash
Ah, right I own a 420EX. But I rarely use it. I often forget to use the ceiling and therefore don't like to use a flash. Thanks for reminding me.
2ndact scene1 Contributing Member • Posts: 802
Some great advice here that I have read with great interest.
Based on only brief experience I would add: 1) for group shots such as speakers in a panel discussion, you will need something wide if you can get close in. I like the EF 35mm f2.0 IS but it sometimes may not be wide enough on a crop body. 2) I find it hard to time shots for the brief pauses speakers generally take - catching them in mid sentence does not work that well. An applause line is a great opportunity for good shots if they not only pause but also smile while the audience reacts. And 3) if you plan to use fill flash, study and practice ahead of time!
Best of luck.
 2ndact scene1's gear list:2ndact scene1's gear list
Canon EOS 5D Canon EOS 7D Canon EOS 6D Panasonic Lumix DC-GX9 Canon EF 85mm F1.8 USM +8 more
Best of luck.
I have a EF-S 24mm 2.8 that I could use for group shots. And since I am very pleases with my new Sigma 50-100 1.8 I already fancy the Sigma 18-35 1.8. But first I will practice to see what I really need...
Thank you!
It will take me some time to try out all those tipps I got here!
Timing can be frustrating -- and a waste of time .
I always use AI Servo (activated by AF-On "back button focusing") and Continuous.
Although I manage to be still, resting firmly on the monopod, the speaker's head and upper body move slightly even when he/she is standing at the podium -- hence AI Servo.
Facial expressions (especially eyes and mouth) change moment to moment -- hence Continuous. From the 3 to 5 continuous captures of one intended composition, the "best" one can be selected. One frame = no choice.
Good advice - as long as the shutter is not too noisy compared to the sound level in the room.  If it is a small event it could be distracting but otherwise  sounds like the way to go.  Thanks.
Shop for quiet shutter.
Two days ago I used my new Sigma 50-100 the first time during a talk.
I was quite happy with the lens. The venue was not really large (about 50 participants). If audience is larger, more focal length on both sides would be nice (e.g. a 70-200 on FF).
In this case I was happy with my FL of 50-100 and also the aperture. The venue was brightly lit. All the more, I was surprised about the ISO needed (mostly 500-1000) to get a shutter speed of 1/125 and shorter. I think noise is starting to be visible on 100% crops above ISO 640. Above ISO 1000 it is distracting.
The handling of the sigma is great. I like the smooth zoom ring. The weight is okay. I sometimes used my monopod, sometimes I hold it freehand. Freehand is working if you don't have to shoot the whole day.
What I found out: I need to be more accustomed to my gear. I tried P, Av, and M with and without Auto ISO. I used continuous and AI servo. The mid autofocus point (with recomposing) and dedicated autofocus points. But I definitely need more practice. I had too few keepers due making mistakes with my camera.... And whitebalance was quite off, when set to manual. I had to adapt it in post.
Here are some of my best shots. RAW, post processed (Exposure, sharpness & noise with DXO Optics Pro):
5
What do you think? Any tipps for improvement?
ttbek Veteran Member • Posts: 4,869
My tip is to make a new thread for the new topic, perhaps even in another subforum, in order to 1) reduce commentary on the old topic (I almost started writing a lens recommendation before I reached the comment where I found out you already got a lens)  and 2) get more interested viewers of your new question.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
Thanks, I posted my photos here:
https://www.dpreview.com/forums/thread/4122036
Any feedback welcome!
