Is the 24-70mm 2.8 II L Sharp?
Started Jan 9, 2017 | Questions
ShutterofSunshine New Member • Posts: 1
My wife and I are a photography team and we have rented the 24-70mm 2.8 II a total of 3 times and the images are always blurry. They are no where near as sharp as any other lens we own or rent. Does anyone else have this issue? Or have we just rented the same bad lens 3 times?
cpharm86 Senior Member • Posts: 2,742
Re: Is the 24-70mm 2.8 II L Sharp?
No issues with mine. After 3 times I would say it is not the lens.
Welcome to DPREVIEW.
ed rader Veteran Member • Posts: 9,068
if you are a photographer surely....
you wouldn't need to ask this question.  you've read the reviews?
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
Abu Mahendra Veteran Member • Posts: 5,312
Is the Ayatollah Shia?
>> I'm already lovin' my Canon 35IS lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
ffabrici Senior Member • Posts: 1,353
Yes, it is very sharp and especially at 24mm where it delivers prime like sharpness. Please remember to do MFA at both wide and tele on each camera body used.
diness Veteran Member • Posts: 3,758
What other lenses do you own and rent?   Are you using a fast enough shutter speed with no is?   Is it focusing in the correct spot?   It's possible you got the same bad one three times, but I suspect user error instead.  This lens is very very highly regarded.
 diness's gear list:diness's gear list
Canon EOS R Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Maybe that rental 24-70 f/2.8L II has been banged around and isn't as sharp as it should be. My 24-70 f/2.8L II is incredibly sharp and resistant to flare even wide open--more so than most fixed focal length lenses.
Since you are a photo team, I'm pretty sure you know camera handling and whatnot, so I'm figuring you are renting a bum lens.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
TheBlackGrouse Veteran Member • Posts: 3,586
Just thinking, you rented this lens three times, hard to believe that they are all wrong.
And the reviews about the 24-70 2.8 L II are quite clear, it is an amazing lens.
However, there are always combinations of body, lens, converter etc that don't seem to work. For instance, some lenses are not performing on crop cameras.
Anyone?
TheBlackGrouse
Active outdoor photographer
kingslayer Regular Member • Posts: 287
This is one of the sharpest canon lens out there. Just google it.  Maybe it's what's behind the lens that is making it blurry.  What camera do you have and did you ever try shooting it on a tripod.
BigBen08 Veteran Member • Posts: 7,473
I think the OP has left the building.
My 24-70 II is razor sharp right out of the box. Never bothered to MFA,.
Scott Larson Veteran Member • Posts: 7,505
The Mark I version was very good. It was a little soft at 70mm when I pixel-peeped but still very good.
My Mark II version is as sharp as my prime lenses. I have not found any blurriness at any focal length.
 Scott Larson's gear list:Scott Larson's gear list
Sony RX10 IV Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +17 more
MarcBton Regular Member • Posts: 257
Only blurry when I ignore shutterspeed limitations when shooting indoors or at low light. I need to remind myself to bump up my ISO. A grainy picture is better than a motion blurred one. It is flawless outdoors in good light or on a tripod.
First camera 1979, first slr 1982, first dslr 2008
 MarcBton's gear list:MarcBton's gear list
Canon EF 50mm F1.4 USM Canon EF 16-35mm F4L IS USM Fujifilm FinePix X100 Olympus Tough TG-4 Canon EOS 5D +11 more
