dperez wrote:
If you try Picolay and you're successful, please put something in here... I"ve been playing with it off and on for a couple days, and so far I've been unsuccessful getting it to do anything...
Dear dprez,
I was successful with Picolay here are two examples:
They are not perfect and I am not an expert regarding this technology. I also have no experience with other programs that may do a better job.
I found some problems with hairs appearing two times in the photos and things like that. I know that other programs have some options to repair these effects manually but within the procedure of calculating the stacked photos.
I also had the problem you observed. With my 24 MP K-S1 I never run into problems - but the program did not like my 36 MP photos from my K-1 (FF camera). I reduced the resolution of my photos and it worked fine.
I also do not have much experience with the settings the program offers.
Actually I try to avoid the image stacking technology but try to maximize DOF with a small aperture and lots of distance rings or a bellow in between camera and lens. I run into problems with diffraction going this way. But the problems with diffraction can be solved by a program doing deconvolution sharpening like Piccure+.
I may have a little more resolution with image stacking as the lens works at an optimal range regarding the MTF chart of the lens - but I won't have problems with artefacts that can occur as a result of image stacking - especially if your object has fine hairs.
Best regards
Holger
I"ve tried most of the stacking software from Photoshop (dreadful) to Combine ZP (clumsy and not great results) to Helicon Focus (sometimes works, but often has poor quality results with flowers), so anything new that purports to work is worth a try. And Zerene is too expensive for fiddling with flowers.
I started with a small stack - 12 images in jpegs. Put them in and told it to stack with the defaults. About 30 seconds later it pops up an error that there's not enough storage for the current command. As near as I can tell, there's NOWHERE to tell it where to store whatever it's storing. And it's sitting on a disk with a TERABYTE of empty space. On a box with 32GB of memory. So, I have no IDEA what "storage" it doesn't have.
Hit OK on the popup and it continues counting steps... Yesterday I let it sit for an hour and it count over 3800 steps. Nothing changed, nothing got aligned or generated or anything else. Just steps.
Tried it today with THREE images - jpegs. SMALL jpegs (or what I think of as small at 3000x2000 px). Popped up the same "not enough storage" error. Continued counting after I closed it. In the last 20 minutes or so it's gotten up to step 892 and counting, but mostly it just sits there like a stump.
And no, there's nothing in the manual I can find for "what to do when it sit there indefinitely"...
Good news is, it's free, so all you lose playing with it is a little time.
