Canon APS-C portrait lenses
Started Jan 5, 2017 | Discussions
jakethesnake34 New Member • Posts: 4
I am looking to get a new lenses that I can use for portraits that is shorter 50mm. I have a 50mm f1.4 and a 70-200mm f4 and need something to fill in the gap below 50mm. I would like to spend less than $750. I have been looking at the Sigma 18-35mm f1.8 art, Sigma 17-50mm f2.8, canon 17-55 f2.8, or really anything around there. I wouldn't be opposed to getting multiple primes either (something like the canon ef-s 24mm f2.8 plus the canon 35mm f2). Any recommendations would be greatly appreciated! Thank you!
 jakethesnake34's gear list:jakethesnake34's gear list
Canon EOS 1100D Canon EF 70-200mm F4L USM Sigma 50mm F1.4 EX DG HSM
Kaso Veteran Member • Posts: 4,488
Re: Canon APS-C portrait lenses
Given that I happen to have all the lenses you mentioned, I highly recommend the Canon EF-S 17-55mm f/2.8 IS USM. It's a relatively old design, but it consistently delivers top wide-open performance across the zoom range. It sits on my 80D most of the time.
The Sigma 17-50mm f/2.8 EX DC OS HSM, a bit difficult to find now relative to the newer 17-70mm f/2.8 DC OS HSM "Contemporary", may be considered if you want to optimize your budget.
The Sigma 18-35mm f/1.8 DC HSM Art is optically phenomenal. No arguments if you must have f/1.8. I find out that I should slow down to insure proper AF or do MF myself. In other words, this lens excels in a controlled environment.
Keith Z Leonard Veteran Member • Posts: 6,134
There is no 17-70 f2.8 DC OS HSM C, it's f2.8-f4 sadly.
The 17-50 f2.8 OS is a great little lens, really. So is the Canon 17-55, they are about on par with each other (different strengths and weaknesses) but the Canon costs a lot more, of course. The Sigma 17-50 f2.8 OS is going for 400$ new.
Great lens, but of course a fairly short range, but if it works for your needs, great option.
 Keith Z Leonard's gear list:Keith Z Leonard's gear list
Canon EF 70-200mm F4L USM Canon EF 100-400mm f/4.5-5.6L IS USM Sigma 50mm F1.4 EX DG HSM Canon EF 24-105mm f/4L IS USM Canon EOS 400D +16 more
Typo. (I have both 17-50 EX and 17-70 Contemporary.)
Spotted Cow Senior Member • Posts: 1,586
Sigma 18-35mm f1.8
pilou1253 Regular Member • Posts: 139
+1
It completely fits the needs you mentioned. This lens is often described as a "bag of primes", can't be more true! I use it most of the time, mainly for candids/portraits and it is great.
Good luck for your final choice!
 pilou1253's gear list:pilou1253's gear list
Canon EOS 1000D Canon EOS 70D Canon EF 28mm f/1.8 USM Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM +7 more
Sidekicker Senior Member • Posts: 1,771
Another recommendation for the EF-S 17-55 2.8.  I have owned a copy for many years, and it has performed very nicely for me as a general purpose/portrait/landscape  lens.
That being said, if I were considering a lens for mainly portrait work, I would go with several faster primes.
 Sidekicker's gear list:Sidekicker's gear list
Sony RX100 VI Sony a6600 Sony E 35mm F1.8 OSS Sigma 56mm F1.4 DC DN | C (X-mount) Sony E 16-55mm F2.8 G +4 more
SundridgePete Regular Member • Posts: 398
I've used a friend's 17-55 and it's lovely. I own the 35 f2 IS and use it on full frame and can wholeheartedly recommend that also. It feels solid, has quick and quiet focus, the IS works a treat and it's got a decent MFD.  The 24 has great reviews, would be nice and light and gives you the 35mm equivalent focal length which is ideal for street. You can't go wrong with either choice - the two primes or the zoom - it just depends how you want to shoot.
BAK Forum Pro • Posts: 26,019
10-18 STM zoom and the 35mm f2
This should give you great versatility and excellent portraits (you provide the talent) with the 35mm lens in all kinds of trying conditions.
BAK
Although I should probably add that you might not want both primes, as 35 & 50 equivalent focal lengths aren't too dissimilar...
arty H Senior Member • Posts: 1,546
Re: 10-18 STM zoom and the 35mm f2
I can recommend the Canon 35F2IS and the Canon 85F1.8 for portraits on a crop. The shorter lens is great for any environment, and the IS helps when the light gets very low. The 85 is a nice lens, but is on the long side for indoor portraits. Of course, this depends on the size of your house and the sort of portraits you want. It works fine for head shots indoors, and is more flexible outside. The two lenses are sharp and very useful.
Both of these Canon lenses have very fast and accurate AF, even in low light. They are compact and relatively light.
I have never had an interest in large, heavy lenses, but that is a personal gripe. Even though the Sigma 18-35 zoom is reputed to be very sharp, the size and weight of the lens is a real turn off for me. Of course, people carrying a 7D with the 24-70 F2.8 II clearly don't have this view. There are People walking around with 1D series cameras and 70-200 F2.8 lenses. Size and weight preferences are personal. Some people thing that a Rebel is large and heavy, and carry small mirrorless cameras.
