Metz MZ 54-3 not fully working with EOS 450D. Can you help please?
Started Dec 26, 2016 | Discussions
Phil1 Senior Member • Posts: 2,307
My son-in-law has an EOS 450D and wanted a more powerful and versatile flash than the built in one. As it happened I had an almost mint Metz 54MZ-3 surplus to requirements and we tried to marry them up.
The Metz fired but the some of the adjustable parameters on the screen on the 54MZ-3 didn’t respond to the camera:
1. The ISO setting was absent on the flash and
2. The focal length and aperture settings were fixed and did not change when they were altered on the camera.
However, off the camera everything on the flash’s screen worked as it should which seems to suggest that the camera and flash were not communicating. Would you agree and, if so, can you suggest what might be done to make the two communicate with each other please?
Many thanks
Phil
PS the Metz has the SCA3102 foot fitted and the software has been updated to give "ETTL". Having said that, when I was using it on my 5D2 I used it in Auto as I couldn't seem to get the ETTL to work satisfactorily.
PPS Apologies! I originally posted this in error in the 7D-80D forum
Canon EOS 450D (EOS Rebel XSi / EOS Kiss X2) Canon EOS 5D Mark II
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: Metz MZ 54-3 not fully working with EOS 450D. Can you help please?
Just posting the link to the answer in the other forum in case someone searches the same issue here:
https://www.dpreview.com/forums/thread/4095918
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
OP Phil1 Senior Member • Posts: 2,307
Thanks very much! I've now had a reply from Metz UK and they will upgrade the foot to 5M which they say will do the trick - at a cosr of ca. £28.
If it works it will be worth it as it was great on my 5D & 5D2.
Phil
