RAW-JPEG autoswitch mystery
Started Dec 21, 2016 | Discussions
motiwala
motiwala Regular Member • Posts: 473
I recently acquired NX3000 out of curiousity and I am overall pleased with the camera.
I always keep shooting mode on all my cameras to RAW including on this one. On a recent trip I noticed that a few pics in series were shot in JPEG mode. That's quite surprising as I don't remember changing mode (in fact I never shoot JPEG).
More surprisingly, there are two series of pictures shot in JPEG mode. Pictures before and after those series are in raw files.
Any idea how this could have happened?
 motiwala's gear list:motiwala's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Nikon Coolpix A Sony RX1R Sigma dp3 Quattro +5 more
Samsung NX3000
Fayewong Junior Member • Posts: 36
Re: RAW-JPEG autoswitch mystery
The priority mode dials support Raw( Aperiture, Shutter, etc) , If you switch the dial to automatic or scene selection, it won't be taken in raw but in jpeg. Not all of the dial modes support Raw. Or that is what I have come to learn when using my Nx500 recently.
motiwala
OP motiwala Regular Member • Posts: 473
oh, that's quite stupid of Samsung to associate shooting mode with storage mode. I am primarily a Sony shooter and previously Pentax but never came across such thing.
Let me try and see if that was the cause.
ttbek Veteran Member • Posts: 4,869
I think Faye Wong has the correct explanation for this case, but it is also worth knowing that booting the camera without any SD switches to jpeg only and does not automatically switch back when an SD is inserted or on reboot, it must be changed back manually in the menus.  At least for NX300 and NX1, I don't have your exact model.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
Check the exif for the shooting mode I suppose, if you don't remember using those modes than be wary that your mode dial may be getting a bit off... a known issue that a number of forum members have faced.
motiwala
Checked exif and those JPEG were indeed shot in program mode, thank you for explanation. However this is a serious logical bug which Samsung should fix.
Thanks Faye wong and all of you for responding.
Hirsti Contributing Member • Posts: 660
This can also happen if you use the NX 45mm 3D lens.  If you accidentally switch the 2D/3D switch which is easily done unfortunately the camera will stop shooting in RAW and shoot in JPG for 3D mode.  I have had to put some tape over the switch to stop it from happening.
 Hirsti's gear list:Hirsti's gear list
Sony RX10 III Sony a7R II Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +1 more
That is very interesting to note, since i also have the NX 45mm 3d Lens. I think 3D was a popular thing a few years ago , but its a fad these days to shoot in 3d. feels more like a gimmick since I still need a 3D television too. I will probably shoot in 2D 99.9% of the time.
markyboy81 Veteran Member • Posts: 4,778
You don't actually need a 3D television, you just need to convert the files and then use some cheapo red/green 3d glasses. The results are actually pretty decent.
http://www.hasaan.com/2012/10/how-to-watch-3d-movies-on-your-non-3d.html?m=1
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
