Galapagos lens: 35-100/f2.8 or 100-300/f4.0-5.6
Started Dec 19, 2016 | Questions
9z9z New Member • Posts: 1
I'm headed to the Galapagos and want to buy one long lens for the trip. Would you recommend the Panasonic 35-100/f2.8 or Panasonic 100-300/f4.0-5.6 ?
Obviously these are very different lenses.  I've heard reports about whether you mostly want a medium zoom (35-100) on the Galapagos because the animal get unexpectedly close anyway. But others have written that their favorite keepers were at the longer zoom level.  Anyone have an opinion to offer there?
The other factor I'm thinking is that the difference in zoom length may be a bit misrepresentative given the difference in sharpness. DxO gives these scores:
35-100 overall score 19 (with sharpness at 10 P-Mpix)
100-300 overall score 12 (with sharpness at 5 P-Mpix)
I'm not familiar with these DxO scores, so I may be misinterpreting it.  Would that imply that with cropping, these two lenses might have more overlap than one might guess as judged by the detail captured.   E.g. would a print from the 35-100 at 100mm be more like the 100-300 at e.g. 160mm?
Since the 100-300 is reported to be especially soft at the long end, maybe it doesn't really have 3x more "effective" reach than the 35-100?
Pedagydusz Veteran Member • Posts: 6,027
Re: Galapagos lens: 35-100/f2.8 or 100-300/f4.0-5.6
I can't answer directly your questions, but I will give some indications based on experience.
First, about the lenses themselves. I don't know the 100-300, but I can tell you that the 30-100 2.8 is an outstanding lens, and is 2.8. I am almost sure that within overlapping range, it is  noticeably superior to the other lens. This in in general.
Now, I have been, several years ago, to the Galapagos, and one thing I can tell you: I would not gmake that trip without good coverage from lets say, 12 or 14 mm, 20 at very minimum, to something longish, 200 mm or more. Definitely not only 100 mm.
It is true that the photographic opportunities in the Galapagos are not like in the African plains, where the longer the better. But there are occasions when you will want a longish lens, 200 mm or 300 mm.
Now, it is not always very convenient, in such environment, to swap lenses, so I would use if possible two cameras. A GM-1 or GM-5 Panasonic with a 12-32 mm lens is one possibility, could fit in a pocket and the quality is surprisingly good. But take also a camera with a longish lens, as I said a 200 or 300 mm. I personally would take a 100-300 mm, regardless of DxO it is a quite useful lens.
And you will love the Galapagos!
 Pedagydusz's gear list:Pedagydusz's gear list
Sony Cyber-shot DSC-F707 Panasonic Lumix DMC-GX7 Canon EOS 7D Olympus E-M1 Panasonic Lumix DMC-GX8 +3 more
sebiruns
sebiruns Contributing Member • Posts: 849
I would go with the 35-100 f2.8. First of all, it is the much better IQ lens. Second of all, if there is one place on earth where wildlife will be up, close and personal it is galapagos. And at another note. The fast aperture can help freeze motion when you are shooting from a shaking boat on a somewhat cloudy day or in twilight. Make sure to take a wide angle as well. And have fun. This is a trip of a lifetime. I seriously enjoyed it.
 sebiruns's gear list:sebiruns's gear list
Fujifilm X-T2 Carl Zeiss Touit 1.8/32 Fujifilm XF 16-80mm F4 Apple iPhone X
phil from seattle
phil from seattle Veteran Member • Posts: 3,699
I've been there twice. The most important thing to understand is the wildlife has no fear of humans so you can approach VERY closely. You will be surprised how many relatively short FL shots you will make of the wildlife. I seriously doubt you will be able to tell the difference between the two lenses as you will be stopped down most of the time and won't be shooting much at the long end of the 100-300.
First trip was in 2008. I took a D90 (APS-C) with a 35-105mm zoom (about 155mm EFL). It worked out OK. There were a few shots that would have benefited more reach but not a huge number. For every shot that I missed because the animal was too far away, another one came along that was much closer.
This fall I took an EM-1 with a 12-40mm pro, 35-100mm f/2.8 and a 40-150mm (300mm EFL).   In retrospect, I would have left the 35-100mm at home - the speed was unnecessary. However, I would have been happy with the 35-100mm.  I got the 40-150mm as a backup but wound up using it a lot.
Take a look at some of my shots.  I did shoot some at 150 but 100 was a sweet spot and there were times when 100 was too narrow.  I'd say take both lenses if you can make the room.
Take a landscape lens. There is nothing in the world like the landscape of the Galapagos. And be sure to visit the fish market in Puerto Ayora if you can. Great interaction between the humans, sea lion, pelicans and herons.
By the way, on our boat there were 7 photographers. All but one was shooting with MFT cameras. The Guy with a Canon 5D had a Canon zoom monster. He got way tired of lugging that thing around and was paranoid about getting it wet. Got some good shots but so did I.
I loved this fluffball. Think it is a Red Footed Booby chick.
Oyster catcher with a snack.
This guy was trapped in a lagoon by low tide.
need to pp out that shadow...
This is pretty common - you can get so close to them.
Gaggle of photogs shooting a bird in the shade while facing the setting sun. The herding instinct is strong. The woman with the point-n-shoot was the only one to at least try to get a decent vantage point.
 phil from seattle's gear list:phil from seattle's gear list
OM-1 Olympus E-M1 II Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Olympus M.Zuiko Digital ED 60mm F2.8 Macro +2 more
kenw
kenw Veteran Member • Posts: 7,095
Both, sell one when you get back...
I was shooting APS-C when I was there and a 70-200/4 was what was on the camera the most.  Very occasionally I used a 1.4x converter for even more reach.  This was Canon APS-C so the 70-200 was equivalent to m43 56-160.  However, I also did a lot of shots with a 17-40.
100mm will be way too narrow a starting point I think.  Lots of reach in Galapagos can lead to really boring shots of bird heads with no context or interest.
On the flip side I'd say 50% of our good shots were more in the m43 140-180 focal range so I think I'd find 100mm a little short.
For a "once in a lifetime" trip I'd recommend getting a little gear just for the trip.  Get both the 35-100 and 100-300 with the plan to sell one or the other used when you get back from the trip.  Similarly I'd strongly recommend picking up a used camera body as a backup for while you are there and then sell it used when you get back.  Buying the extra lens and the extra body you might lose at most $50 to $75 selling them used when you get back.  Cheap rental and cheap insurance for a "once in a lifetime" kind of trip.
Oh - and have a blast, Galapagos is an amazing place!
Ken W
See profile for equipment list
 kenw's gear list:kenw's gear list
Panasonic Lumix DMC-GM1 Nikon Z7 Panasonic Leica DG Summilux 15mm F1.7 ASPH Nikon Z 14-30mm F4 Nikon Z 24-200mm F4-6.3 VR +46 more
averacpa Regular Member • Posts: 219
Re: Both, sell one when you get back...
I would definitely bring the 100-300, you will want the reach. I was there 2 years ago on an expedition trip. I brought a 9-18, 20, 45-150 and the 100-300. You can only walk along the designated paths (except in town) and only with a naturalist which will limit you to animal access. Although many animals are close enough for the 35-100, I shot mainly in the 150-250 range. It provides better isolation of the animal against the background, makes the "pop" out. Also, while the animals are somewhat close, they are still far enough not to fill the screen at 100mm so you may end up cropping quite a bit.
A better lens would be the 100-400, but in terms of cost and weight, the 100-300 worked very well.  As with the other posts, a wide angle lens is also needed.  My two most used lens were the 9-18 and 100-300.
While walking around town along the pier.
Focusing not easy on flying birds with the 100-300.
Taken from a Zodiac
Along a walkway.
He was probably around 30 feet away
Dan P Regular Member • Posts: 127
if you have choose just one...
Lots of great advice here -- and you'll have a great time!  (I was there 7 years ago, and will be going back in a month.)
re: 100-300 -- for those distant shots (eg Frigate birds in the sky, beasts on the shore when you are in a Zodiac), yes, it is great. That said, when I had that lens, I got very frustrated with the slow focusing. So, for flying birds or when the Zodiac is moving, you may find the length good but the focusing infuriating.
re: 35-100 -- you WILL find this to be incredibly useful. Definitely use this.
One more thought. I was not at all prepared with the underwater aspects of the Galapagos. I had a cheap underwater digital, and got some highly mediocre shots with it, but you might want to think about getting a camera for that realm. The Oly TG-4 seems to be the consensus favorite (it shoots RAW and none of the other little guys do). I got a refurbished one for well under $300 on the GetOlympus web site. It has some quirks, but I am hoping it'll help me get some decent shots.
Have a great trip! And if you're going to Espanola, be prepared for the Technicolor marine iguanas to blow your mind.
Dan
Male marine iguana, Espanola
DPerl
aliasfox Senior Member • Posts: 1,375
If you're running an E-M1, you could consider the 4/3 50-200 f/2.8-3.5 as well.
 aliasfox's gear list:aliasfox's gear list
Olympus XZ-1 Olympus PEN E-PM2 Olympus E-M1 Panasonic Lumix DMC-GM5 Olympus E-M5 II +17 more
