Not worth it.
Started Dec 17, 2016 | User reviews
David Marques Neves
David Marques Neves New Member • Posts: 9
Not worth it.
Fast and precise autofoccus
Expensive, too much distortions, flares and aberrations at f/1.4~f1/.8.
The 50mm f/1.8 STM is better in f/1.8 and all apertures after this.
Not worth it.
 David Marques Neves's gear list:David Marques Neves's gear list
Canon EOS 6D Canon EF 17-40mm f/4.0L USM Canon EF 24-105mm f/4L IS USM Tamron SP 70-200mm F/2.8 Di VC USD Canon EF 50mm F1.8 STM +4 more
Canon EF 50mm F1.4 USM
Prime lens • Canon EF • 2515A003
David Marques Neves's score
3.5
Average community score
3.7
crashpc Veteran Member • Posts: 7,240
Re: Not worth it.
I had this lens before I jumped to nikon and back, and it was quite good, even wide open on crop body. Now I'm thinking if I should get it again, buy some Sigma/Samyang or wait for Canon native EF-M lens...
 crashpc's gear list:crashpc's gear list
Canon EOS M10 Canon EF-M 15-45mm F3.5-6.3 IS STM
irm Veteran Member • Posts: 3,105
Re: Not worth it.
It is slow, imprecise and not repeatable focus. Focus mechanism is fragile. Over priced.
I have two of these and one has been repaired by Canon 5 times.
my 2 exposed flashcubes worth.
Ian the pbase supporter.
http://pbase.com/ianm_au
Please check my profile for equipment list.
An amateur with dreams of being a good to excellent photographer.
 irm's gear list:irm's gear list
Canon EOS 10D Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF 50mm F1.8 II Canon EF 135mm F2L USM +9 more
ZX11
ZX11 Veteran Member • Posts: 6,156
Re: Not worth it.
It can't be stored with weight on its front moving element.  A lens hood attaches to the body and protects the focusing part.
I am surprised the OP thought it focused great.  To me, it needs ideal lighting to provide the contrast my low end camera body uses to focus.  Poor lighting and low contrasting objects will leave it focusing short.  A furry horse head (focus point on his eye area) will fail while a close in shot of a blue eyed cat's eye (iris parts discernible) will be sharp.
"Very funny, Scotty! Now beam me down my clothes."
"He's dead, Jim! You grab his tri-corder. I'll get his wallet."
 ZX11's gear list:ZX11's gear list
Canon EF 85mm F1.8 USM Canon 70-200 F2.8L III Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F1.2L USM
Alexsfo Senior Member • Posts: 2,362
Re: Not worth it.
Totally agree. I tried this lens on my 6d and it's very mediocre, inconsistent AF, busy bokeh, sharness is not impressive. I found 50m STM is better in every regard including low light AF and closeup ability not to mention better build quality for 1/3 price.
 Alexsfo's gear list:Alexsfo's gear list
Canon EOS 5D Mark IV Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM Canon EF 24-70mm F4L IS USM +4 more
Jonathan Brady
Jonathan Brady Veteran Member • Posts: 6,725
although a short review, I tend to agree
I had this lens for a couple of years and never once took a sharp image with it wide open that I was impressed with from a technical perspective.  I'm a fan of lenses which offer a sharp center and quickly fall off towards the periphery of the image (ie, 85L II) as I believe that's a great way to add character to a portrait.  But the 50mm f/1.4 isn't even sharp in the middle.  It's just mush.  Using it on a crop body is even worse as the pixel density of modern APSC sensors stresses the already weak optics even further.
There's a reason I own exactly one 3rd party lens and it's the Sigma 50mm f/1.4 Art and that is because ALL of Canon's native 50mm options have MAJOR compromises.  The Sigma Art does as well (focusing issue) but that's one I can live with as most of the issue is remedied by the Sigma dock.
Re: although a short review, I tend to agree
Here is one for ya:
1:1, slightly croped.
As DPR does something to the image, I recommend you to see the image in this direct link:
https://postimg.org/image/7h0cf5kp5/
much better...
Kevin Omura
Kevin Omura Senior Member • Posts: 2,388
Ordered in three and all had AF failures
Would question the reliability of this lens. We purchased three from the same shop and just under 2 years old all three had AF problems and had to be repaired at our cost by Canon.
Image quality is good but reliability is a definite issue on some. Perhaps current one's have had the problem(s) fixed, the one's we had repaired see to be ok though because of the problems they don't get as much use as they normally would.
 Kevin Omura's gear list:Kevin Omura's gear list
Canon EOS D60 Canon PowerShot S100 (2000) Canon PowerShot S5 IS Canon PowerShot G2 Canon PowerShot G6 +69 more
Scott Larson Veteran Member • Posts: 7,505
Re: Not worth it.
I also managed to break mine twice. The second time it was just a tap on that protruding metal around the lens and it no longer focused. Canon fixed it for free both times but I can't rely on a lens that is that prone to failure, so it sits at home.
 Scott Larson's gear list:Scott Larson's gear list
Sony RX10 IV Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +17 more
Re: Not worth it.
...One day, I opened a can of tuna, and my lens in another room broke down....
Re: Not worth it.
That is lik taking a photo and the lens not working anymore. Contrast below f2.2 is very poor, lots of CA and blue and purple fringing.
From f2.4 and beyond very good, but focus is not reliable.
But if shooting under very lowlight and a reasonable distance from the stage matters change.
photosen Veteran Member • Posts: 6,226
Re: Not worth it.
To each his own, mine focuses great, everything looks fine from 1.8, bokeh is nice, one day I might get some use out of the funky results at 1.4, which i expected when I got it; and it has never failed, but I do treat it with care. The price is reasonable, particularly when compared to other options. It was my first lens and offered the huge advantage of telling me this was a hobby for me from the get go, which might not have happened with a safer route like the 18-55.
The one thing I would suggest for anyone starting out is to try other focal lengths first on APS-C: 24mm, 35mm, 40mm, 85mm; and then see if the 50mm does something for you.
The best bokeh goes unnoticed, grasshopper.
 photosen's gear list:photosen's gear list
Canon EOS 30D Canon EOS 70D Canon EF 35mm F2.0 Canon EF 50mm F1.4 USM Canon EF-S 10-22mm F3.5-4.5 USM +3 more
Jura S Senior Member • Posts: 1,980
Re: Not worth it.
It completely depends how you use it.
ZX11
At f8
Couldn't any lens do that at f8?  Say my kit lens 18-55mm STM stopped down to f/8?  I only pull out my 50 f1.4 when I need something more wide open than f5.6 (I think that is the kit lens at 50mm).
Silvex Senior Member • Posts: 1,407
Re: If I couldn't have the f/1.2 L...
...I would get the f/1.8 STM. It's not so much that the f/1.4 is a bad deal, but that the f/1.8 STM might just be the best value to be had in a Canon lens.
Yes.
Had 1.4, then Jumped to Nikon with all gear, and now When I´m back, I bought 1.8 STM, and I´m quite pleased. It´s definitely at least on par with 1.4 at 1.8, which is awesome. I might add Rokinon 1.2 to it though, if I decide to go crop all the way. 1.8 is not enough fun. It´s a cheap workhorse.
Re: At f8
Don't think that 18-55 is sharp enough even stopped down.
50/1.4 wide open has issues with bright lights and contrasty transitions.
50/1.4 at 1.4.
ZX11
Re: At f8
50/1.4 at 1.4.
I like it.  Not sure how the background is in focus and the subjects.  My 50mm 1.4 seems to have poor contrast in the times there is a lack of light.  I figure that is why L glass has the pricier LD elements instead of regular glass.
I wanted the 1.4 as a solution to low light but it turned out to be more of a DOF effect.  Now I mostly use it for items photographed in a lightbox for ebay.  I will have to keep it in mind to stop it down for contrast.
Testing flash or no flash in bright sunlight.  This might be a car's sunshade bouncing light up to her.
After too much time being the subject.
Re: At f8
ZX11 wrote:
Jura S wrote:
50/1.4 at 1.4.
The distance between camera and chess players was around 6 times greater than between them and the background. Bottles look blurry though.
