Silkypix Raw File Converter settings
Started Dec 11, 2016 | Discussions
RMGoodLight
RMGoodLight Forum Member • Posts: 93
8
I used Lightroom for developing my XA1 and XT10 images for the last 2 years. I own Irident Developer for a year now and now I tied the free Raw File Converter (Silkypix) and are very satisfied with the results. They are so good that I plan to switch my workflow to Raw File Converter.
Sharpening
Sharpening is up there with Irident Developer. Depending on texture you have the impression to get more detail out of it than with ID. I tried and checked and that are my default settings:
  • There are 2 sharpening modes in Raw Developer. Manual
  • Type normal sharp produces very sharp results that can look clear and oversharpened very easily.
  • ISO100 Outline emphasis 14, Detail emphasis 100
  • ISO800 Outline emphasis 20, Detail emphasis 100
  • ISO1600 Outline emphasis 17, Detail emphasis 100
  • ISO3200 Outline emphasis 14, Detail emphasis 100
  • ISO6400 Outline emphasis 14, Detail emphasis 100
  • Type pure detail gets you closer to Irident Developer in the matter of sharpness because it is more sophisticated.
  • ISO100 Outline emphasis 37, Detail emphasis 48
  • ISO800 Outline emphasis 37, Detail emphasis 48
  • ISO1600 Outline emphasis 37, Detail emphasis 48
  • ISO3200 Outline emphasis 37, Detail emphasis 48
  • ISO6400 Outline emphasis 40, Detail emphasis 48
Noise reduction
For noise I could not get Silkypix to work that flawless as ID and LR. The results are ok but here I need help. (I think about using Lightrooms noise reduction with the output of SP).
My settings so far. Manual
  • ISO100 Color distortion 0, Noise reduction 0, Noise Level 0, Noise cancel 38
  • ISO800 Color distortion 11, Noise reduction 5, Noise Level 0, Noise cancel 38
  • ISO1600 Color distortion 15, Noise reduction 15, Noise Level 0, Noise cancel 38
  • ISO3200 Color distortion 18, Noise reduction 10, Noise Level 0, Noise cancel 38
  • ISO6400 Color distortion 25, Noise reduction 38, Noise Level 0, Noise cancel 38
Since I could not find any current settings for Silkypix / Raw File Converter I thought I should publish my own settings. And maybe someone has some additional advice to get more out of it?
 RMGoodLight's gear list:RMGoodLight's gear list
Fujifilm X100T Panasonic LX10 Fujifilm X-A1 Sony a7R III Samyang 35mm F1.4 +5 more
Fujifilm X-A1 Fujifilm X-T10
Advent1sam
Advent1sam Veteran Member • Posts: 9,089
Re: Silkypix Raw File Converter settings
For noise reduction you also have 2 settings, hs (high speed) and hr(high resolution)
I prefer to have neat noise zero in 99/100 cases, with hs or hr depending on subject. In the main the default nr is satisfactory to my eyes, sometimes I pull back if its too much.
Post a few raw images that you think you need help with and lets compare.
Like you fuji ex2 even surpasses the paid for sp versions and if correctly integrated is so easy to use.
Sharpening
Noise reduction
oscarvdvelde Senior Member • Posts: 1,421
To get maximum detail the most important thing is to go to the Noise tab and change from "High Resolution" to "High Speed". This reduces smearing of detail which happens even when all NR sliders are at zero. It is just not so effective in noise reduction when needed.
Then in Development I usually keep the slider at its default setting.
In Sharpness the finest look is usually Pure detail combined with something like 60-80 on outline and 10-20 on detail.
It is a bit laborious because I don't know a way to make these settings load as default. In RawTherapee I saved a profile and set it as a default for opening new images, instant sharpness/microcontrast pop.
 oscarvdvelde's gear list:oscarvdvelde's gear list
Fujifilm X-T3 Fujifilm XF 27mm F2.8 Samyang 12mm F2.0 NCS CS Fujifilm XF 16mm F1.4 R WR Samyang 50mm F1.2 +4 more
affair New Member • Posts: 11
I've just recently gotten the X-T2. I got a one year plan for lightroom so using that, but got interested in trying the Raw file converter x2 (silkypics). To my suprise after sharpening the files in silkypics and converting them into TIFF and then back into lightroom again, the colors are really different. The ones just imported straight into lightroom looks dull and has more noise compared to those imported from silkypics. I was quite suprised by the difference.
Tim Simmons
Tim Simmons Regular Member • Posts: 210
This is a wonderfully helpful post. I'm learning to love Silkypix, I just wish there were more tutorials and tips so that the learning wouldn't have to be so much trial and error.
Sharpening
Noise reduction
RMGoodLight
OP RMGoodLight Forum Member • Posts: 93
Thank you for the input. I tested the mentioned tipps and found it very usefull.
I tried to better match high ISO sharpening Vs. noise reduction. OOC colors where another point that I checked. And I got some surprising conclusions.
Reduce demosaic sharpness to zero! The presharpening will work out like Clarity slider in Lightroom. It enhances clear edges BUT it changes the image colors drastically. It reduces the vivid suptle colors and makes them more uniform, muted and harsh.
To get better Fuji OOC colors with RAW file converter EX2, you have to dial down the demosaic sharpness to 0 (Manual ) and a slight push of contrast gets you a little more pop.
I tried to match the output of Irident Developer but that is difficult. ID is that good. There are textures that EX2 will handle better (pink, slight red cloth that is clipping easily with other RAW converters) but ID has a very good compromise between sharpening and noise reduction. I can offer samples if you guys want.
Following settings is my new attempt to ballance out noise and sharpness with high ISO images (ISO2500 - 6400)
Sharpening
  • Demosaic sharpness 0
  • Outline emphasis 75, Detail emphasis 20, Type Pure Detail
Noise Reduction
  • Color distortion 25, Noise reduction 0, Noise Level 0, Noise cancel 0
OrdinarilyInordinate
OrdinarilyInordinate Veteran Member • Posts: 3,741
You keep saying that without any proof. I've used both a lot and don't see that when using the same "Normal Sharpening" in both, they produce identical amount of detail.  I've posted my results.  Please provide some proof of EX2's superiority. Yes, it's free, but DS7 provides a lot more options for editing, which is what I paid for (on a good sale) on top of EX2. I also use RawTherapee and PhotoNinja, and all have their pros and cons.
 OrdinarilyInordinate's gear list:OrdinarilyInordinate's gear list
Nikon Coolpix A Fujifilm X-T2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +4 more
stillman3 Contributing Member • Posts: 621
Adam Bonn has made a 4 part article on using RFC
https://adambonn.com/my-love-affair-with-the-fujifilm-x-pro1/xp2-thirty-seven/
This is very useful.
Cheers Eric
Tim Simmons
Cheers Eric
That's the tutorial that got me comfortable enough to go ahead and purchase Silkypix Developer Studio Pro 7. Now if there could be more guidance on that version...
RMGoodLight
Just for sience I compared the OOC, Lightroom, Irident Developer and EX2 images. Here we go.
All images got the same treatment: +0.7EV, Astia profile.
LR: color noise reduction 15, sharpness detail 100, mask 10
Irident Developer: color noise 6, luma noise 3, sharpness reveal
EX2: my latest settings for sharpness and noise reduction
ISO3200, left top ID, left bottom OOC, right top LR, right bottom EX2
ISO1600 left top ID, left bottom EX2, right top LR, right bottom OOC
The difference with the wood of the seat is very interesting.
ISO2500  left top ID, left bottom OOC, right top LR, right bottom EX2
ISO5000 left top ID, left bottom EX2, right top LR, right bottom OOC
ISO200 left top ID, left bottom EX2, right top LR, right bottom OOC
This one is interesting because of the dark shadow part of the jeans. You can see that LR crushes the blacks and the film simulation of ID posterizes the dark parts so that both loose shadow detail here. You can see that the yellow strings are not yellow  with LR and OOC anymore too.
Another interesting one is the handling of red cloth. No the EX2 example is not noisy it is showing cloth detail that the others wipe out.
ISO1250 left top ID, left bottom EX2, right top LR, right bottom OOC
This one is to show how fine hair is handled. ID seems to get along better with those fine details than the others.
My impressions: The OOC does very good most of the time. It has the best color of all and balances noise and sharpness well. Good if you don't want to postprocess.
LR looks good on the first view with sharper details than the OOC images but it has a paintbrush effect to the images. They look realistic but painted at the same time. The black crusching is an issue.
ID does a very good job when it comes to detail and noise. It produces the finest details but EX2 is better on some textures. The colors are close to the OOC but lack some refinement to show more graduations.
EX2 does very good too. My settings produces a grainier look than the ID images but sharpness is up there with ID. It shows more shadown detail than LR and colors are more like the OOC than with ID.
Overall the samples look very similar (on the first look).
What do you think?
bs1946
bs1946 Veteran Member • Posts: 7,778
If you create a custom Taste, won't it automatically apply the setting you want?
Bill S.
billschaffel.500px.com
instagram.com@billschaffel
“Sharpness is a bourgeois concept” - Henri Cartier-Bresson
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
Adam Bonn
Adam Bonn Forum Member • Posts: 62
What do you think?
Astia is, IMO a tough sim with a dark shot, as it has hard shadows (despite the "soft" rhetoric by Fuji) I'm not personally convinced that Adobe's Fuji film sims have all that much to do with Fuji... (no edvidence, just a hunch)
LR seems very sensitive to sharpening settings... there's certainly no one size fits all!
some times in LR, I find that a larger radius, moderate detail, and 30-40 on the sharpening slider works better
Others will have their own settings I'm sure.
 Adam Bonn's gear list:Adam Bonn's gear list
Fujifilm X-Pro2
Adam Bonn
Cheers Eric
I feel strangely scared that I've somehow led you down a dark alley ;D
I use SP7 Pro a lot and have done for about 7 months, there's still things I can't really get my head around in it.. When I get it singing, I really like it though.
I'm not really obessive about pixel peeping (fair play to those that are, it's just not me) so I wouldn't have any specific sharpening settings to offer. My opinion is that the natural sharp performs better than the RFC engine though.
It also seems (a lot of the time) to make a better job of artifact control with one of the Fuji sims than a native one
If you're performing highlight recovery, the highlight controller sliders can be useful, they seem to work better and give you more with the normal highlight slider rather than the HDR one
conversely, the HDR shadow slider seems to have far more to give than the normal shadow slider
If you're playing with exposure push, then there's definitely a relationship to balance between NR and demosaicing sharpness or else it seems to run out of colour gamut, it's not like (say) LR when you can 'just' bump the exposure slider 3 stops and then deal with the noise
Base ISO shots, I zero out all of the NR sliders, I find the colour noise one in particular to be far to aggressive at base ISO
Some one earlier in the thread asked about changing the defaults it uses with images, I cover this in my artcile that's linked in this thread by someone else, but basically, make a taste and set it as the default.
Make any sharp/NR/demosaicing changes you want at the very end or the very begining, these take the longest for SP to apply and keep you waiting quite a while for the file to preview... although you might very well have a better computer than I do!
I wrote the article about RFC because info on it seemed sparse and I read to many people claiming it "didn't have many features" and I thought, well it's far from the last word in image manipulation, but it has a ton of decent stuff for the tog that can expose well in camera and it's free.
I didn't realise that anyone had actually read it
Then I saw this thread in my site traffic stats and thought I'd say hi and see what you were all saying.
If anyone has taken any benefit from that RFC article, then I'm delighted, it was a real PITA to write!
Fujifilm X-Pro2
Adam Bonn
Cheers Eric
Thank you Eric
Fujifilm X-Pro2
Tim Simmons
Definitely not a dark alley. Silkypix gives me great renditions of my Fuji X-T2 files. Thank you for your help with your writing.
third son
third son Veteran Member • Posts: 3,422
It would be interesting to see a comparison between the ITX and Silkypix RAW converter on busy foliage.
-Paul
 third son's gear list:third son's gear list
Nikon Z6 Nikon Z7 II Fujifilm X-E4 Fujifilm XF 14mm F2.8 R Nikon AF-S Nikkor 70-200mm F4G ED VR +20 more
Adam Bonn
-Paul
Do you mean the ID X-Trans DNG convertor?
I suspect that XID would edge it, especially on mid to far distance objects
Give it a go - SP V7 has a trial usage period, XID is trial forever with a watermark and RFC is completely FOC
Cheers
Adam
Based in Porto, ALWAYS keen to collaborate with local photographers. Contact me!
http://adambonn.com - home of quite possibly the most verbose Fuji X-Pro series articles on the internet
Fujifilm X-Pro2
third son
Adam Bonn wrote:
-Paul
Hi Adam....I read your blog with regards to RFC after I had been using it for a while.  Thanks for the terrific write up!  I also tried the ID X-Trans DNG converter-->LR6. I don't see a lot of difference myself.  I also looked into RawTherapee-->LR6 or DxO Pro 11.  Photoninja also seems to do pretty well but I didn't want to pay $100 for just a demosaicing tool.
I figured the Silkypix RFC was designed for my XT1 so went into it with a preconceived notion that it should be pretty good.  This bias may have swayed my decision not to purchase the XID-->DNG converter at this time.
That is also why I asked if anyone else had made that comparison.
-Paul
Adam Bonn
third son wrote:
Adam Bonn wrote:
-Paul
Hi Paul,
Thanks very much.
The problem with this sort of thing is that it can be user subjective, very dependant on what screen we use and ultimately very much based on how tolerant we are on imperfections within our images.
How often do we see someone post an image they consider to be sharp only to be debunked by someone else?
Digital sharpness is effectively micro contrast (IMO) and when we sharpen a shot we can easily face the dilema of some bits looking great and other bits looking too crunchy, so do we downgrade the great bits to merely good and lose the bad, or do we decide that the bad bits are unimportant and great should remain?
This is why sharpening is an image-by-image affair and not a 'hey guys if you set your sharpening to XYZ on all your shots, then it's fantastic' like we often see written on the net...
Sorry a bit of a philosophical digression there
I've played a LITTLE bit with XID, made some dngs and put them into SilkyPix
My OPINION?
it's win some, lose some, draw some tbh
XID (for me) beats SP V7 with mid to far away fine detail, I need to zoom in, but to my eye it's there for sure (OMMV)
To my eye XID is APPROX equal to SP v7 on close up stuff, again OMMV
To my eye XID is a BIT worse than SP v7 on high ISO stuff where it also brings out a bit of noise and NR removes any detail advantage
But I haven't played with XID extensively and there's bound to be better settings for different shots, both in XID itself and in the app that one uses to edit the dng
There also seems to be a lens connotation as well...
XID gives me more from my 35/1.4 (compared to SP v7 in the conditions outlined above) than it does my xf18. This is quite possibly because the 35 is sharper than the 18 so there's more scope for fine detail
Like you say $100 for PN that you'll most likely only use for demosaicing is a lot
But IMO $30 for a demosaicing tool that works better on a handful of shots is probably worth getting, but I'm going to sleep on it for a bit and wait to next month
Cheers
Adam
Fujifilm X-Pro2
third son
Hi Adam,
I am with you in that I don't batch process my files but take time to tweak each one to get the scene I experienced when I was there.  The problem with photography is that the experience of "being there" cannot be conveyed since the viewer can't feel immersed in the subject matter, that is what it felt like all around you when the shot was taken. We try to get close when we process an image to convey that feeling to others.  I do it to remind myself why I took the shot it in the first place.
Philosophy aside....I will be watching with anticipation when IXD becomes a clear winner.  I feel Brian has done a great job with what he has produced so far.
-Paul
