Canon EOS 500d external mic not working? help
Started Dec 9, 2016 | Questions
MikkelPrimdal New Member • Posts: 2
so the other day i recieved a jack adapter so that my RØDE videomic pro fits into my Canon EOS 500d but when i record with the microphone plugged in nothing happens, it still uses the build in microphone. What can i do to fix this?
Canon EOS 500D (EOS Rebel T1i / EOS Kiss X3)
brightcolours Forum Pro • Posts: 15,885
Re: Canon EOS 500d external mic not working? help
What do you mean by "jack adapter"? What kid of plug does your microphone have and to which kind of plug does it adapt? The 500D does not have a microphone connection.
kreygscott
kreygscott Senior Member • Posts: 1,285
It appears that the Op plugged his external mike into the remote socket. This is why you should READ your camera manual.
 kreygscott's gear list:kreygscott's gear list
Canon PowerShot S110 Canon EOS 5D Mark II Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 17-40mm f/4.0L USM +9 more
OP MikkelPrimdal New Member • Posts: 2
the canon eos 500D has a 2,5 mm jack plug thing, and my microphone has a 3,5mm so i got a adabter cable so that it fits in. But its still using the build in microphone.
Olga Johnson Forum Pro • Posts: 24,360
That is probably because that is not a connection for a microphone but merely a connection for a remote control. See the last images on this page which explain what that connector is for.
https://www.dpreview.com/reviews/canoneos500d/5
Olga
kreygscott
One would have thought that the OP would have as suggested in my reply, "read the manual" or at the least look it up online.
