Some help with my new 10-18mm IS STM please?
Started Dec 7, 2016 | Discussions
Dareshooter Veteran Member • Posts: 5,842
Re: Some help with my new 10-18mm IS STM please?
jvceac wrote:
I said I didn't know if HTP would have any negative impact on sharpness but wondered if it could. ISO 200 in all of the OP's samples leads me to think he might be using HTP.
Wether he is or isn't using HTP it will have no effect on sharpness not sure  how you even think it would. Contrast or even the lack of it may affect ones perception of sharpness but that's not what the OP is seeing. He seems to have been unlucky enough to get poor copy,it happens.
bent christian Senior Member • Posts: 1,663
trulandphoto wrote:
bent christian wrote:
Looking at the two full-resolution photos, I can't find anything in focus. Absolutely nothing. The issue appears to be something other than than diffraction at f/11. Diffraction would be minimal at this aperture in a crop sensor.
Like I said, diffraction starts on this sensor at f/5.9 at normal focal lengths. super wide like this would be even larger aperture.]
Diffraction does not present itself like this in crop sensors at f/11.
Some areas would still show focus.
"focus" and softness are different things but can be confused. Diffraction results in softness. At 10mm and f/11 on a crop sensor you could almost focus anywhere and the entire shot is "in focus."
Even if I defocus my lens?
The fact that you don't see anything "in focus" indicates it's not a focus issue.
Ummm....no. It does not indicate that definitively at all. If the lens isn't focusing correctly or the user is in error, it would be entirely possible to capture nothing in focus.
No it wouldn't be. The range of focus for a crop at 10mm and f/11 is like from 18 inches to infinity. If you can manage to get nothing in focus in that range you're special indeed.
G'night.
You are operating under the assumption that the this lens was focused properly.
dave_bass5 wrote:
Although this doesn't help much ive just taken a distance shot at f/11 with mine on my 80D. I know its not quite the same thing but 100% inLR shows very, very acceptable sharpness. This is what i would expect of this lens so i suggest you get yours replaced and try again.
Yes. F/11 can offer at least acceptable sharpness on a crop sensor if the lens is functioning properly. This issue does not appear to be diffraction.
gimp_dad Senior Member • Posts: 2,693
G'night.
Like most modern lenses this lens can have focus set beyond infinite.  This is how you get nothing in focus.  Happens all the time due to either errant manual focus or AF issues with lens/camera combo.
dave_bass5
dave_bass5 Veteran Member • Posts: 7,342
No, i dont think it is either.
Have we covered using IS on a tripod yet? Or even camera shake.
I'd really like to see more other shots, with more contrast.
Someone said earlier that these are too small to be out of camera shots, could be a resolution thing as well.
 dave_bass5's gear list:dave_bass5's gear list
Canon EF 24-70mm F2.8L II USM Canon EF 35mm F2 IS USM Canon PowerShot S110 Canon EOS 5D Mark IV Canon EOS M50 +10 more
ispyej
OP ispyej Junior Member • Posts: 29
Hi guys,
I appreciate all your comments. I since took some photos with several different settings of the same landscape and ensured my focus was correct. I was experienced the same issue. Since more than one person has recommended to return the lens, it is what I have done.
Better to be sure than always wonder, I suppose.
Dareshooter, great to hear you live close to the Brecon Beacons. It's such a wonderful area. I'm studying at Cardiff University.
Have a good weekend everyone. Thank you all again!
 ispyej's gear list:ispyej's gear list
Canon EOS Rebel T6s Canon EF-S 55-250mm f/4-5.6 IS STM
dave_bass5
An exchange is probably for the best. If nothing else for piece of mind. Good luck.
Ive been amazed at the quality of the STM lenses ive brought since going back to crop this year. I have 3 now and id put them up against any of my L lenses for general shooting.
ispyej wrote:
Hi guys,
Your welcome,hope you get it sorted out soon.If you go for an exchange could you report back with your findings.
I live in the valleys and the Beacons are a ten minute drive away. My son did his degree in Cardiff too but that was a long time ago,he did applied biology,what are you studying ?
You to and take care.
Best Regards,
Dareshooter
Jon_T
Jon_T Veteran Member • Posts: 6,407
ispyej wrote:
... I used f/11 because I read that landscape photos will be at their best between f/11 and f/16, so that a lot of the photo can be in focus...
Yes for FF (full frame) sensors. With a APS-C 1.6X crop sensor f/11 has the equivalent DOF of f/17.6 with a FF sensor. Cans use sites like the one HERE to check equivalent DOF and diffraction aperture for different types of sensors.
I think its good idea that you returned the lens prior to the end of the return period.
However agree with others that the amount of haze could of affected AF accuracy. I downloaded your above image and viewed in DPP 4 and shows you were using multi-AF points.
For the bulk of my shooting with optical viewfinder I prefer single center AF point.
Also played around with your image in PSE 14 with its new Haze Removal tool and did some sharpening -- sill soft when 100% pixel peeping but a slight improvement viewing at smaller size.
Jon
Kevin Macza Regular Member • Posts: 287
ispyej wrote:
I have had some really great photo opportunities recently, but have a concern about my 10-18mm. I have shot several photos on it now, but none of them seem as sharp as other images I've seen online shot with the same lens. To emphasise, I can't seem to find any point on the photo that is sharp, as I zoom in on the photos it all seems a little out of focus.
With my 70D, the 10-18mm produces images with sharp focus in the center of the frame between f/4.5 - f/8; however, details become more blurry toward the edges of the frame (mitigated somewhat as you stop down)  As other have said, there could be some diffraction effect at f/11 causing general loss of detail.  But still, it does appear as if nothing is really in sharp focus in your images.  Definitely worth trying another copy of the lens.
 Kevin Macza's gear list:Kevin Macza's gear list
Panasonic Lumix DMC-ZS15 Canon EOS 70D Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EF-S 18-55mm f/3.5-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +1 more
Just had a look through my 10-18mm photos and found that most of the landscapes shot above f/8 were not very sharp, with somewhat mushy details. From my own experience, lens performance is optimal across the frame at f/7.1, though somewhat sharper in the center at wider apertures. This suggests that diffraction effects may at least partially explain the OP's results.
Steve Balcombe Forum Pro • Posts: 15,582
Here is the correct answer...
ispyej wrote:
Hi guys,
Pity you've done that as there was almost certainly nothing wrong with the lens. I checked the two images you re-posted at a larger size, and in both cases they include the focusing distance in the maker Notes of the Exif data. The second one is focused at 5.53-6.56 m, and the first one is 1.19-1.4 m. It's not really possible to know how you did that, but maybe you half-pressed the shutter while still pointing at the ground in front of you? I've no particular reason for suggesting that other than it is one way to make that happen.
There is so much depth of field and so little background blur when shooting a wide angle lens at f/11 that the overall effect is an image which is very soft all over, rather than being obviously out of focus, and nothing is in sharp focus because the images have no foreground.
Where do I claim my prize?
It is definitely a focus issue, see my other response.
BTW - diffraction softness is certainly visible at f/11 on a crop body, but it wouldn't make an image as soft as these. I use f/11 sparingly, but when I have to use it I get good enough results.
Re: Here is the correct answer...
Steve Balcombe wrote:
ispyej wrote:
Hi guys,
Um. On APSC FL of 10mm at F11 aperture hyperfocal distance is 0.48m.  The near end of the depth of field at 1.2m would be about 0.32m and the far end would be infinity. In other words this exif data you found is useful but actually proves the opposite. Focus was correct and the lens must have an issue.
ispyej
Dareshooter, I'm studying economics. Final year now. Since I'm back from Brecon and starting to get busy with assignments/exams for January, I probably won't get a replacement until the new year. I'll make sure to buy it while the cash back off is still on, though!
Jon, interesting results you got there from the haze effect, thanks for sharing. It would be nice to get shots without having to rely on post processing afterwards, though. I will make sure to try a single central focus point next time. Since I'm still learning the camera, it was the easy option for me to get the camera to set the points automatically.
Kevin, f/7.1 will be in my mind from now on when shooting landscapes, thanks.
Steve and gimp_dad, I didn't even know that you could get this kind of information from my photo. That's pretty cool. It's all a bit too technical for me right now and it might be a pity that I returned the lens, but better safe than sorry at this point in time (yesterday was my only opportunity to return). I'll have to do some reading on hyperfocal focusing.
mouzhik
mouzhik Regular Member • Posts: 404
Looking at the two full-resolution photos, I can't find anything in focus. Absolutely nothing. The issue appears to be something other than than diffraction at f/11. Diffraction would be minimal at this aperture in a crop sensor. Some areas would still show focus. If the OP is confident in their skill and that no user error has occurred, request service on this lens.
+1
it's simply out of focus, sorry to say that.
Have you taken some landscape shots with your other lens on this location?
 mouzhik's gear list:mouzhik's gear list
Canon G1 X III Ricoh GR III Canon EOS 5D Mark II Canon EOS Rebel SL1 Canon EOS M6 +13 more
