Re: 5th diffraction spike explained! (well sort of)
Lyle Aldridge wrote:
It's difficult to believe that experts examining the scope could not identify the cause of such an artifact. There may be a clue in the fact that your four "normal" spikes are also doubled. That usually means that the opposite spider legs are not exactly opposite from each other.
I agree with Lyle's comments above. Not every telescope owner or sales person is necessarily an expert. But did those "experts" assessing your telescope really try the telescope at night, examining the diffraction pattern of an out-of-focus, bright star? That's really the best way to determine what is causing the artifact. Whether or not these experts can determine the cause, there is something causing the spike. If you can find that cause, then you'll be an expert in that area. Your other photo showed the 5th spike only on one side of the field of view. What that means is only from that position in the FOV does a star see the obstruction in the light path. From other positions in the FOV the obstruction is not visible, which is a clue to the cause.
The doubling of the 4 spider diffraction spikes is easier to remedy. Just adjust one or the other of each offending pair of supports so that their diffraction spikes overlap. There is usually enough extra diameter in the hole in the tube to move the support studs a bit to the side. If not, make the hole larger.
Another "solution" is to just ignore the effect. Overall your photos are quite nice, showing great progress. But in your obsession if these spikes bother you enough, get a curved vane support spider. One of these will distribute the diffraction effects of the supports evenly around the entire 360° perimeter of the central spot. The effect is similar to that produced by any of the refractor, Schmidt-Cassegrain or Maksutov telescopes, which have no spider support diffraction issues. Here is a nice discussion of curved spider supports:
Newtonian Curved Secondary Mount
A 3-vane spider is another option. This will give less total diffraction spread around in 6 spikes at 60° intervals. Some people may prefer that pattern to the usual 4 spikes. With the 3-vane spider there is no problem with double spikes since the 6 spikes don't overlap. The following graphic shows the effects of various methods of supporting the secondary mirror.
Diffraction Spike Comparison
