Sharp a a razor
Started Nov 26, 2016 | User reviews
perry rhodan
perry rhodan Senior Member • Posts: 1,964
Sharp a a razor
After reading dozens of reviews and looking at samples I knew what to expect. NOT! After only 24 hours the single word is SHARP! 100D gets a new life and the M3 sensor shines with this lens. Will update anytime later. Scoring only as impression.
Here for the forums.
Canon EF 100mm f/2.8 Macro USM
Telephoto macro prime lens • Canon EF • 4657A006
perry rhodan's score
5.0
Average community score
4.8
Canon EF 100mm f/2.8 Macro USM Canon EOS M3 Canon EOS Rebel SL1 (EOS 100D)
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Re: Sharp a a razor
Canon's 100mm f/2.8 macro is a great lens and I think 100mm is the "sweet spot" for general macro work. You should buy a lens hood, though, for the usual reasons.
I've used one for years and agree it is excellent. I do wish I had spent a few extra bucks for the IS version to make hand holding a bit easier, but otherwise the two lenses are pretty much equal optically.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
perry rhodan
OP perry rhodan Senior Member • Posts: 1,964
Re: Sharp a a razor
Lovely shots, Thanks for posting These!
Price difference in EU is around 400 euro. 😏
Zeee Forum Pro • Posts: 25,641
Re: Sharp a a razor
There is a newer version. I had versions.
https://www.bhphotovideo.com/c/product/647011-USA/Canon_3554B002_EF_100mm_f_2_8L_Macro.html
I have to ask. How do you get that onto the M3? You must be using a lens adapter?
 Zeee's gear list:Zeee's gear list
Canon EOS R7 Canon EOS R6 Mark II Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +1 more
perry rhodan
Re: Sharp a a razor
Yes using the EF to efm adapter works really nice.
Re: Sharp a a razor
Thanks. I'm thinking about the M5. Since the lens is physically further from the camera does this change anything? I'm curios to how it can still focus properly.
hotdog321
Re: Sharp a a razor
You're welcome!
perry rhodan
Re: Sharp as a razor ;-)
It is focussing ok with adapter. Infinity and close focussing is no problem. The real gripe I have with the M3 and (after playing with one for an hour in shop) the m5 is the unacceptable AF speed . In 2011 it would be ok for a MILC, but in 2016 it's NOT!
BTW I was astonished about IQ of the 15-45 efm. In a bad way. At closer range (under 1m) IQ is mediocre. Only at around F8 it Gets a bit better. I tried a second one in shop, but it was the same. My efs 10-18, 18 -135 usm and my ef 100 usm macro and 50 stm were very sharp.
BTW I'm using fill flash a lot and have extensively used it on all kind of camera's . The M-line so far is mediocre in fill flash. Quite a surprise to me because all the canon DSLR's I had/have starting with the 20D are/were very good and reliable. Currently I'm using nissins (I40 and I60) on Fuji (X30), Canon (100D and 80D) and Sony gear (hx50). The 100D and 80D are superior to all I used before. Including the Nikon D7000. Only the Fuji X30 works as good in fill flash. Wireless flash with nissins works perfect even with the 100D. The nissin i40 needs some small piece of tape to prevent the exposure compensation dial from turning unwanted. From me it gets a 10/10 rating even with this minor gripe.
BTW my M3 is going back due to unacceptable AF speed, no more M for me  See my other post in the Canon eos M thread.
Thanks for the info.
