Canon T5 Serial Number missing in EXIF
Started Nov 25, 2016 | Discussions
tnsantos
tnsantos Regular Member • Posts: 108
Hi, I bought a brand new Canon T5 but I noticed that it is not recording serial number in the exif data. It appear as zeroes. I tested a cr2 file in dpp and it shows camera number 00000000. The serial number printed on the label of the camera matches the one printed in the box. Should I care about it os is it better to rerurn it?
 tnsantos's gear list:tnsantos's gear list
Canon EOS 1200D Canon EF-S 18-55mm f/3.5-5.6 IS STM Canon EF 50mm F1.8 STM Adobe Photoshop Lightroom 5 +1 more
Canon EOS 1200D (EOS Rebel T5 / EOS Kiss X70)
Exit10 Senior Member • Posts: 2,264
Re: Canon T5 Serial Number missing in EXIF
Maybe you can post a full size jpg straight out of the camera?
It would be easier to respond an example.
 Exit10's gear list:Exit10's gear list
Canon EOS Rebel T6i Fujifilm X-T3 Canon EF 200mm f/2.8L II USM Canon EF 24-105mm f/4L IS USM Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
tnsantos
OP tnsantos Regular Member • Posts: 108
tnsantos wrote:
Hi! Here we go:
https://dl.dropboxusercontent.com/u/2651862/Canon%20T5/IMG_0018.JPG
Thank you!
I think you were looking at the lens serial number which is all zeroes - the camera serial number is in the EXIF and is non-zero.
tnsantos
Exit10 wrote:
tnsantos wrote:
Hi! Here we go:
Thank you!
It is the opposite. The lens serial numberr is non-zero and the body serial number is all zeroes. Weird.
tnsantos wrote:
Exit10 wrote:
tnsantos wrote:
Hi! Here we go:
Thank you!
Yes - you are right - you do have something called "Internal serial number" populated but not sure how that relates to the camera.
tnsantos
This is weird:
exiftool.exe IMG_0456.CR2 "-*serial*" -a -G1
[Canon] Internal Serial Number : ME0075136
[Canon] Lens Serial Number : 000030911f
[ExifIFD] Serial Number : 000000000000
[ExifIFD] Lens Serial Number : 000030911f
It is recording the Internal Serial Number as you said, but Serial number is blank. Maybe a firmware bug or camera body bug?
