Panasonic G85 from an Olympus user
Started Nov 20, 2016 | Discussions
pannumon Veteran Member • Posts: 4,130
Re: Kit lens and built-in flash
Michael Meissner wrote:
I was doing a quick picture of our cat sitting under the Christmas tree, and I grabbed the G85 with the kit lens (Panasonic 12-60mm) lens attached. I had the lens hood mounted normally, and I noticed that was a shadow where the lens hood blocked the flash.
Yeah, yeah, yeah, reversing the lens hood for indoor shots fixed the problem, but would have thought the engineers would have made the flash high enough that the kit lens hood would not interfere.
Don't worry, this is normal, and many would claim this as an user error.
The further the flash is from the lens/sensor, the more shadows the flash will cause to the recorded image. In general, it's better to have a small point-like flash (built-in flash) close to the lens/sensor. External flashes produce half-shadow (penumbra), that looks less distracting, even if the distance to the lens/sensor is larger.
I'm pretty sure that if you use 12mm and the smallest focusing distance, the lens itself will block the flashlight, just like the lens hood. It's very difficult to get completely rid of this problem. The engineers of course are trying to find the best compromise for this. Bouncing the flash is a good option, but usually that means external flash (you can do it with some rangefinder-style Panasonic cameras, though)
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
Ron Joiner
Ron Joiner Contributing Member • Posts: 989
Of course, until the 14-150mm mark II and 12-40mm came out, Olympus 'solved' the problem by not providing lens hoods. However, generally the cameras with the FL-LM1 or FL-LM2 had the flash high enough that the standard lens hood for the lens did not seem to block the light.
My pet peeve as well. I just reverse the hood but should not have to as you say.
 Ron Joiner's gear list:Ron Joiner's gear list
Panasonic Lumix DMC-GF1 Olympus PEN E-PL5 Panasonic Lumix DMC-G6 Panasonic G85 Olympus Zuiko Digital ED 50mm 1:2.0 Macro +8 more
Aberaeron Forum Pro • Posts: 10,184
I often use the G7 with the 14-140 lens and often get caught out by this when I haven't got my Nissin flash with me. Luckily I seldom take more than one or two flash shots without chimping to check exposure, so notice it almost immediately. No bother just to remove the hood and put it in my pocket. The least of my problems usually.
JosephScha Veteran Member • Posts: 7,249
I find that I remove the lens hood on the 2nd picture shot with flash
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
rashid7
rashid7 Veteran Member • Posts: 7,011
i discard all my lens hoods, except on my longest tele.   They are only an inconvenience, and w/ small gear it is easy to shade front lens element w/ my hand!  The protection isn't worth the hassle!
Keep it fun!
danieljcox
danieljcox Senior Member • Posts: 1,194
Could not agreee more. Great advise.
 danieljcox's gear list:danieljcox's gear list
OM-1 Sony a9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Leica Nocticron 42.5mm +11 more
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
Sorry, could not disagree more, bad advice! The lens hood not only protects from lens flare but also - and foremost - form dirt, rain and shocks. And they come free with Panny lenses...
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
rashid7
I always read this (& i suppose it is true) but in 5 yrs of serious photography i have never missed them.  They are cumbersome and slow me down.  My hand does a much better job of shielding sun w/ all but a few long tele lenses.  But of course, your mileage may vary, he he.
Keep it fun!
Roger Engelken
Roger Engelken Veteran Member • Posts: 5,558
Re: Panasonic G85 from an Olympus user
I just purchased a GX8 to compliment the cadre of Olympus camera bodies I have. Why not try something a bit different that uses the same lenses I already have. So far, so good, day three.
I went out today with the m.Zuiko 12-40 attached, and the pair makes a fine combo.
I do look forward to learning more about how this Lumix camera handles, though so far it seems to be doing just fine.  Even the menu is intuitive.
 Roger Engelken's gear list:Roger Engelken's gear list
Olympus PEN E-P5 Olympus E-M1 Olympus OM-D E-M10 Panasonic Lumix DMC-GX8 Olympus E-M1 II +29 more
Michael Meissner
OP Michael Meissner Forum Pro • Posts: 28,013
Strap lugs
I'm now in Hawaii and using the camera more, so I thought I would update my thoughts on the camera.
One minor annoyance is that the little plastic guard on the triangles connecting to the strap lugs keeps falling out.  Perhaps if I only attached the strap and never took it off, it would be fine, but it does seem to be mis-designed.
On the  E-M1, the plastic part is around the strap lug, while the bare part of the triangle is where you attach the strap, while on the G85, the plastic part is where you put the strap.  After it has fallen off a few times, I'm not re-attaching the plastic part.
That being said, I hate the triangles in general.  I wish Olympus/Panasonic would go back to making the strap attachment part of the body at the top, so the lug doesn't protrude when you hold the camera, and it is more secure.  Olympus did this for some of the older DSLRs (E-510/E-520/E-620), and I wish they would go back.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
