Disappointment with Panasonic gx7
Started Nov 18, 2016 | Discussions
robmarshall77 Junior Member • Posts: 27
Hi everyone
I'm new to the forum and this is my first post.
I have a Panasonic gx7 which I purchased used at a very reasonable price. I also bought the 14-45mm short zoom with IS (which I heard was one of their better kit lenses). I was quite excited, thinking I'd got a real bargain and recently went on a trip to Edinburgh where I took a few jpegs. I must say that I'm a bit disappointed with the results.
The photos are really only snapshots (composition pretty awful etc) but they look pretty soft and flat to me. I think my hands are steady and I don't think the exposure is too off but somehow I expected more. The shots are straight out of the camera.
In short, what do people think is the way to get better results out of this camera? Should I better lenses and only shooting raw? Am I encountering the dreaded shutter shock I've read about? Is something like Canon eos700d going to give me better image quality? One particular type of shooting I'm interested in is photographing swing dancing events (my big hobby) so low light capability and reasonably good focus tracking are important to me.
Thanks in advance for your comments.
Rob
Panasonic Lumix DMC-GX7
jalywol
jalywol Forum Pro • Posts: 12,301
Re: Disappointment with Panasonic gx7
robmarshall77 wrote:
Hi everyone
What focus mode are you using?  The in-focus areas are not where you think they should be in these shots.  You should use S-AF with single point focus, not multi-point, so you have control over where the camera actually does focus.  Also, turn off Face Detect for anything scenic with no people in it.
Flat is relative. What metering settings are you using?  You can also adjust the shooting profile; there are a bunch in camera (Standard, Nature, Vivid, etc.).  Remember, also, post processing is your friend....this isn't an iPhone.
You need to get faster lenses if you are going to be shooting in lower light.  Also, don't stop down beyond f8...you get into diffraction territory once you do that.  Also, most of the M43 lenses are pretty close to their sharpest either wide open or stopped down one, maybe two stops.
If you are in shutter shock territory (1/80-1/200ish) use the E-shutter, unless you are shooting motion, in which case you can't.
If you want good focus tracking, the GX7 is not the camera for it.   It does have excellent S-AF capabilities, even in low light, so if you are willing to use it that way, then you will probably do fine.  Otherwise, a more conventional DSLR with PDAF will make much more sense for your target uses.
Hope this helps,
-J
Gerry Siegel
Gerry Siegel Veteran Member • Posts: 3,244
First off, there is nothing wrong with the GX 7 and the lens, though not the finest, is not a bad lens. So get that part out of your head. Settings, and choice of exposure and steady hand holding even with IS will help. Do some test situations under different settings before you give up on this fine camera. I have two of them.  It produces excellent JPEGs in my opinion if that is your choice..
 Gerry Siegel's gear list:Gerry Siegel's gear list
Panasonic ZS100 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 +4 more
OP robmarshall77 Junior Member • Posts: 27
Thanks a lot for your comments.
In reply to your points, I think the metering mode was centre-weighted (I think I read somewhere that this may be better than evaluative metering for general shooting).
The focus mode was definitely single shot with single area enabled. I'm not sure what you mean by the area in focus in these shots is not where I expected it to be. There are no close subjects in these shots and no shallow depth of field and with these apertures I expected everything to be pretty sharp.
I take your point about tracking auto-focus. A Dslr may be a better way to go here but I haven't tried this out as I needed didn't have a proper flashgun with me. Also, do you think raw will allow me get more punch out of the camera and lens?
Once again, thanks for the quick response.
Thanks a lot Gerry.
Obviously I need to get out and do more shooting. I've read good things about this camera. I've just received the Panasonic 25mm f1.7 and with my new flashgun (Nissin i40) I'm excited about trying to capture some dance shots tomorrow night. I'm sure I have a lot to learn and won't give up on the gx7 just yet!
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,435
5
Don't listen to all the advice.  It's a fine camera and the way to get the best out of it is to take loads and loads of pictures, learn from your mistakes and take loads and loads of pictures again.  I have a GX7 , I'm not a great fan but that is more to do with me than the camera.  It is actually very good and for the examples you show is quite capable of producing just as good results as just about any other camera out there.
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
(unknown member) Veteran Member • Posts: 3,098
#1 and #3 are difficult shots to get right, with a lot of DR. I believe #1 has focus on the graves, but and that is to far back to get everything in focus; try to us a DoF table, helping you were to focus and to get the most part of the image sharp.
Composition wise, all three can improve a lot, especially #2 and #3 look like random shots with no clear subject.
The camera is capable to produce crisp images. What also might help is to shoot raw instead of jpg. Especially for #1 and #3, you have a lot more room to bring out the shadows or recover some highlights.
Of course, the 14-45mm is a nice lens - on of the better kit lenses, but investing in a better lens might also help. But... I would practice first, a lot, like one of the previous posters replied as well.
For shooting dance events in low light, it might not be the best choice. You may need a faster lens.
Just some examples to show the gx7 can take crisp images (shot raw and post in Lightroom).
Thanks pocoloco and previous posters.
I notice pocoloco you have Olympus em1 in your gear list. How does this compare to gx7 as a camera. People seemed to compare the two on similar playing field but em1 is much pricier here in the UK as a used body.
Also, I like the colours in your architectural shots. What picture profile did you use and did you do a lot of alteration in post processing to get the look you were looking for?
MOD Tom Caldwell Forum Pro • Posts: 46,352
I have a GX7 and it is a very good camera, so good that I feel no real compunction to upgrade to a GX85 which obviously is a more advanced camera in many ways.
Short of something wrong with the camera/lens I think it has to be camera settings and/or technique.
I very rarely use flash even for darker subject matter.  Frankly the use of flash requires its own set of skills and not using it often means that I don't acquire them.  But of course dancing in less than optimal light is going to push your ISO quite high to get fast enough shutter speeds so the correct use of flash might come in very useful.  A better way is to invest in a really fast lens - but "bang" goes your bargain investment
I tend to use pinpoint focus to make sure that the camera does focus on the precise point that I wish it to select.  Furthermore you can use the optional point and touch focus and capture.  I don't do this often but it can be a very useful tool in some situations.
Also vary your EV according to subject matter - this may introduce some "life" where the normal slightly negative setting is sometimes too sombre.
Tom Caldwell
I have both.  They are both good cameras and I rate them as "equivalent".  Each has its particular advantages but I tend to use the GX7 more as I find it a more pleasant camera to use with Its control layout better tuned to how my brain works..
The E-M1 has a better evf (for some) but it can suffer from sunburn.  Some simply don't like the smaller evf on the GX7 but it has not been a problem to me.
Swapping cameras is not going to make your problems go away, practice might.
Tom Caldwell
ISO 1 Million Contributing Member • Posts: 691
Low light shooting and good AF tracking is precisely what most M43 cameras and definitely the GX7 are not good at.
You can alleviate the low light shooting issue with a faster prime lens but I'm afraid good AF tracking is going to be a touch one to remedy with that camera.  Mine was basically useless so I never used it.  My GX7 was shot exclusively in AF-S mode.
 ISO 1 Million's gear list:ISO 1 Million's gear list
Fujifilm X100V Sony a9 Sony a7R III Voigtlander 15mm F4.5 Super Wide Heliar Sony FE 55mm F1.8 +6 more
RickPick
RickPick Senior Member • Posts: 1,332
Thanks a lot Gerry.
I have had some good night and indoor shots from the GX7 at up to ISO 3200 (without flash), though I normally wouldn't go over 1600. If you're shooting dancers, you will need to get the shutter speeds up unless you want to get that swirly motion effect. Please get as many shots as you can, trying different settings and without as well as with flash. I'm sure it's a matter of experience. One specific point - try to be conscious of exactly where you want the main focus point to be. If necessary change the focus box to a smaller size to ensure the camera does focus there. In your churchyard photo I thought the focus point should have been on the nearest gravestone. At f4 or so not everything will be in focus with the depth of the scene you have there, far from it, so you must ensure that your main subject is.
Note that you cannot use the electronic shutter with flash and also that certain types of indoor lighting can cause banding to appear in photos made using the electronic shutter.
 RickPick's gear list:RickPick's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +4 more
larsbc Forum Pro • Posts: 18,282
Hi everyone
I've shot with the 14-45 for a number of years and it's a good lens.  I also find my GX7 to produce results that are better than my Nikon D300 and that Nikon was certainly good enough for pro work (as are most cameras, really).  So, assuming your lens and camera are up to the standards for those products, then they should be fine.  What image format were you photographing in?  JPEG FINE?  They look ok to me.  If they appear flat to you, then perhaps you should make some adjustment to your camera's picture settings to bring them closer to your tastes?  Myself, I only shoot in raw and don't have any complaints.
I think you would probably be better off with a DSLR.  Swing dancing is exactly the kind of thing that m43 is not particularly well suited for.  DSLRs tend to have better continuous AF tracking systems than mirrorless cameras, generally speaking.  They'll also perform better in low light, again, generally speaking.
curiosifly Senior Member • Posts: 1,219
To the OP:
I agree your shots look flat. There could be a few different reasons, but the two main reasons I see is :
1. lack of composition (no clear subject in the picture and lack of pleasing leading line/pattern (either geometry or color), and too busy background).
2. postprocessing.
Try to find a scene similar to what pocoloco posted above and take the same picture. If it does not look as pleasing, try to work out the reason (composition, exposre and postprocess). Once you figure out the process to take similar pictures, you would have a better idea about whether you need a different camera.
ciao
mg_k Veteran Member • Posts: 3,221
Thanks a lot Gerry.
Before you get out and shoot more disappointing photos stay home, learn and understand all the various functions of your camera first.
 mg_k's gear list:mg_k's gear list
Ricoh GR Canon EOS R Canon RF 24-105mm F4L IS USM
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
You need to work through the instruction manual, rob
That is actually better for you than having people on the forum explain stuff step by step. You work through it, it becomes aprt of you.
The GX7 is an excellent camera; I use it all the time. The 14-45 lens excellent too, although a lot bigger and heavier than the current 14-42 II which is at least as good a performer, maybe better.
You can do better. Try concentrating on getting some significant pictures instead of just snaps; they will focus your energies and help you isolate what you want the camera to do and how to do it.
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
Re: You need to work through the instruction manual, rob
Thanks very much, guys. These are all very useful comments. Let's see if I can produce something better with more practice.
Tony Collins Senior Member • Posts: 1,737
There is nothing wrong with the camera, but like evey other skill, having the right kit is only half the job.
You need to learn how to take pictures you are happy with. It won't come from just pointing and clicking. Every photographer needs to especially understand lighting and composition - far more than camera settings. If your images look flat, it is probably because you have flat lighting. Shooting in the middle of the day rarely gives good light, unless you understand how the environment modifies the light.
As an experiment, try getting out on a bright day shortly after sunrise, or shortly before sunset - the so called golden light. If you do, I'm almost certain you will be happier with your pictures.
Study photographs or even paintings that you like. What is it you like about them. Look at the lighting and composition. Try to emulate the ones you like best to understand how to do them.
As another experiment, try to find a subject, and then reduce it to the simplest most uncluttered composition you can. Simplify then simplify some more.
And enjoy the process. Each time you take a picture you really like, you'll realise it is better than the ones you liked a few months ago.
Tony Collins
 Tony Collins's gear list:Tony Collins's gear list
Panasonic Lumix DMC-GF1 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Samyang 7.5mm F3.5 Fisheye Panasonic Leica 100-400mm F4.0-6.3 ASPH +1 more
alcelc
alcelc Forum Pro • Posts: 19,003
Type of shooting and m-shutter
Hi everyone
Rob
According to your samples, they are nicely exposed (likely 0ev in A mode, purely upon the defulat setting of the camera?), good contrast and personally I'n happy with its color randering for its type of shooting...
Focus looking not sharp enough might be explained in 2 aspects.
Firstly images covering a wide scenery without main object would be hard to determine where is the exact focus point (likely at infinity: wall of the dinning hall, tombstone at bacjground and the sky?) or difficult for viewer to find a focus point. Most other objects that would give viewer a point of reference to judge focus in these images were probably either not aimed, at the edge, or relying on DoF.... Take picture of a pot of flower, your pet, portait etc in closer range, you might find the difference in sharpness from the combo you used.
Secondly, from EXIF you shot all of them in M-shutter. Although no obvious shutter shock be detacted, you might see improvment in sharpness (might not material, but under close inspection there is always difference) on using e-shutter. If not shooting under floucense lighting nor fast moving objects, e-shutter is a perfect match for GX7. (Note: IMHO even GX7 and GX85 share the similar sensor, no AA filter of GX85 and better algorithum would see an obvious improvment in sharpness, which is also less digitalized and more comfortable/natural!).
Of course 14-45 is the first generation standard kit lens, for my copies I ranked it in front of the generally applused 12-32. However, we must understand it is a kit lens. When comparing to many more times expansive lenses, they of course would deliver improved IQ. IMHO 14-140 M2 would slightly be better than 14-45 and so as 12-35 f/2.8...
Sorry I'm not a prime guy.
Albert
