Samyang 7.5mm problems with E-M5ii
Started Nov 16, 2016 | Questions
Mettaman
Mettaman Forum Member • Posts: 85
Hi there,
I have an E-M5ii and I've just borrowed the Samyang 7.5 from a friend. I actually used to own this lens when I had an E-P5 and it worked fine.
However, on the E-M5ii the IS isn't working at all. The image is steady until I half press the shutter. When I do press it the image starts jumping all over the place.
Any ideas?
 Mettaman's gear list:Mettaman's gear list
Ricoh GR II Olympus OM-D E-M10 II Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Panasonic Lumix G Vario 35-100mm F4.0-5.6 ASPH Mega OIS
Olympus PEN E-P5
mshine
mshine Regular Member • Posts: 195
Re: Samyang 7.5mm problems with E-M5ii
Have you set the correct focal lenght?
With a manual lens, you have to set it by yourself for it to work properly (in the IS menu).
BTW: Panasonic has a clever implementation on this problem. Camera asks if the IS focal lenght is correct when turning camera on with a manual lens.
http://www.flickr.com/photos/elahtine
You see things, not as they are, but as you are.
Mettaman
OP Mettaman Forum Member • Posts: 85
That's done it. Thanks.
