Anyone with experience of 15-85 (and ideally 17-55mm, too)?
Started Nov 12, 2016 | Questions
Matthew46 Junior Member • Posts: 41
I must begin by apologising as, looking around, there have been quite a few threads comparing these two lenses – there are just a couple of things, though, that I haven't been able to find out and I'd be very grateful if someone with experience of the 15-85mm f/3.5-5.6 lens might be able to help, please? I'd also been considering the 17-55 f/2.8.
As it's such a long post (sorry), I thought I might be best to get my questions out of the way early on:
• Does the 15-85 feel unbalanced on an xxD-model camera? (I guess this would be even more pronounced with the 17-55? It's just that the handgrip on my 650D began to creak slightly whenever I had the 55-250mm STM attached to it and, ideally, I'd like to avoid it happening with my 80D, also.)
• My big concern with purchasing this lens is the reports of decentering – is there any need to be cautious about this, or did it only affect early copies of the lens? (I'd read some posts saying that it seems to affect every copy to some extent.) I'm just worried that it's a problem I might not be able to diagnose.
• Just a practicality, really: if I followed the advice of using a clear protective filter when shooting in a harsh environment, would a B+W slim filter cause vignetting at 15mm?
I should probably give a bit more background:
I read a great piece of advice on this forum – that, when shopping for lenses, you should think what it is you'd like to achieve that you can't with your current equipment. And it's here where I become very indecisive...
I've just upgraded from my four-year-old 650D/T4i to an 80D, which I'm absolutely thrilled with. The 650D was my first DSLR and I tried to learn as much as I could with the kit lens, an 18-55mm IS II, so it was never replaced. Over the years, I added a 55-250mm STM and 50mm STM.
I'd always been pleased with the 18-55mm... but, to be honest, the 50mm STM in particular spoilt me (although the 55-250mm never fails to impress) by showing me just how sharp a lens could be and what can be achieved with a shallow depth of field. I guess that I'm looking for a lens that gives you the "Wow!" that the 50mm does (even though my photographs are of dubious quality, I'm sure).
As I'm looking to trade in my 650D body and the 18-55mm, I'd be looking for a zoom lens that would cover at least the same range. Although I've enjoyed trying a bit of each style of photography, I've particularly enjoyed portrait photography – but then I do have the 50mm for this, so a walkabout lens would be ideal.
It seems to come down to the 15-85mm and the 17-55mm. I thought I was all set on the 17-55 but, perhaps unnecessarily, I was slightly swayed when I saw the lens comparison tool on The Digital Picture. Although it understandably only shows one copy against another, I was surprised to see the 15-85 seemed better throughout the range, particularly when both lenses are wide open (as seen here: http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=398&Camera=963&Sample=0&FLI=3&API=0&LensComp=675&CameraComp=963&SampleComp=0&FLIComp=2&APIComp=0)
I'm not a confident lens changer outside the house and, with the 18-55 and 55-250, I've often felt the need to choose between wide-angle and telephoto before leaving, so the idea of a lens that would bridge the two is very attractive (particularly as it goes down to 15mm). I'd wondered if pairing the 15-85 with the 24mm STM pancake might give me the best of both worlds. But I just wonder if I would regret not buying the 17-55 while I have the chance... I'm particularly cautious as either of these two lenses would, by far, be the most I've paid – and I'm unlikely to be able to reach that amount again in the foreseeable future.
Would you say that your experience of the 17-55/15-85 match the samples in the link?
Thanks in advance for any help.
ddixon Regular Member • Posts: 250
Re: Anyone with experience of 15-85 (and ideally 17-55mm, too)?
I've used a 15-85 with my Canon 60D for six years. Mine is a very good lens that my only real complaint about has been its slow aperture. You can get fairly shallow DOF with it but it's not a great lens for that. But it is a fantastic general lens - FF equiv. of 24-135 is great to have. But, just to be sure I recently rented a 17-55 for comparison. As you said, this is one copy against another, but I found that the lenses for all practical purposes were equal at equal apertures. The 17-55 has 2.8, and it's good wide open, but I had to stop it down to f4 to match the quality of the 15-85 at f4.
So, if the f2.8 (at slightly lower quality) is a high priority and you can live with the shorter tele range, it's an excellent choice. The 15-85 is slower, but I find it to be acceptably sharp even wide open - which is a good thing as I shoot it wide open 90% of the time. The 80D having better quality at higher ISO would work better with these lenses than the 60D.
I found both to balance well - the weight is about the same. The 15-85 is shorter, but the 17-55 is well balanced and I didn't notice the extra length. Never noticed any decentering, but my 15-85 does front focus a bit and the 60D doesn't have MFA. Probably should have sent it in to Canon but never did. Also never used a filter on it.
For lower light needs I do have the 24, 40, and 50 STMs which are also all good. My 50 is soft wide open but good by 2.2 and excellent by 2.8. The 40 is excellent wide open, with the 24 very good at 2.8 and excellent at f4. So, I've been doing your exact approach - 15-85 for versatility but a faster prime or two when needed.
My mistake was that in trying to get better quality I also rented a 6D
That was enough better that I have now gotten a 6D, 24-70 L f4 IS, and for low light the 35 f2.0 USM IS - all at great Canon Refurb special sales recently. I already had the 70-200 L f4 IS, and now just need to get a faster telephoto prime in the 85 to 135 range.
Hope this helps.
 ddixon's gear list:ddixon's gear list
Canon EOS R5 Canon EF 85mm F1.8 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 35mm F2 IS USM Canon EF 16-35mm F4L IS USM +3 more
Dave Sparks Senior Member • Posts: 1,350
I've used the 15-85 for some years now, first on my 40D and now on a 70D and I don't find any balance issues.  Nor have I had decentering problems with it.  When I bought the lens, I debated between it and the 17-55 but an analysis of thousands of my shots found a significant percentage in that 55-85mm range.  Also, I don't do much shooting that really requires the faster lens so the choice ended up being pretty straightforward for me and I'm quite happy with it.  I own a number of lenses but find that I don't like to switch much so this has proved to be a perfect walkaround lens for me.
 Dave Sparks's gear list:Dave Sparks's gear list
Canon G7 X II Canon EOS 90D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-200mm F4L IS USM +18 more
AdriaanMeijer
AdriaanMeijer Veteran Member • Posts: 3,047
I don't know the 15-85. I do know -and own- the 17-55mm f/2.8. As you have enough information about sharpness and the like, about handling:
  • The lens is wider and heavier to hold than the kitlens. I don't see any problem here. Hold the lens with your left hand, it's perfectly balanced, and grip the body with your right when needed.
  • The wideness of the lens sometimes blocks part of the light of the build in flash, especially WA and/or close by.
All in my humble opinion of course!
If I seem to talk nonsense or you can't understand me, it's probably my English
 AdriaanMeijer's gear list:AdriaanMeijer's gear list
Canon EOS 7D Canon EOS 600D Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-200mm F4L IS USM Canon EF-S 18-55mm f/3.5-5.6 IS II +5 more
stratobill Senior Member • Posts: 2,081
First off, in that example you are comparing the 17-55 at 2.8 and the 15-85 at f4.5, if you equalize the f stop they 17-55 begins to look pretty good!
I had both lenses at the same time, and I mostly used the 15-85 for travel, and the 17-55 for low light (I did a lot of theatre shooting at the time).
I think the 17-55 is a bit better in the IQ department, but the increased range of the 15-85 is a huge convenience! So that is your dilemma, faster lens versus better range.
I used them on Rebel bodies and the lenses were front weighted quite a bit. Should be a much better balance on an 80D.
 stratobill's gear list:stratobill's gear list
Canon EOS 6D Canon EOS Rebel SL2 Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +4 more
Damoo Senior Member • Posts: 1,102
I have used the 15-85mm on my 7D a lot. It's been 4-5 years since I moved to full frame.
I. Never felt anything wrong with the balance.
II. IQ is not its strength. Lot of CA, excessive distortion.... but a sharp lens. 15mm is quite wide. Very fast AF. Not 4 stops but perhaps 2 stops of IS.
Some stellar choices available today for crop zooms like the sigma 15-30mm f1.8 art.
Not worth spending money on the 17-55mm f2.8 or the 15-85mm canons.
 Damoo's gear list:Damoo's gear list
Leica M Monochrom (Typ 246) Olympus OM-D E-M5 Canon EOS 6D Sony a7S Canon EOS 5D Mark IV +16 more
dave_bass5
dave_bass5 Veteran Member • Posts: 7,342
When i had my 60D (and 30D before that) i used the 17-55 almost all the time. I did end up selling it to get the 15-85 as I wanted something smaller, lighter and with a quieter IS. The 15-85 was this lens and i never once missed the IQ of the 17-55. Id say, as do others, that the 15-85 is just as good IQ wise. What it loses is of course having f/2.8 but i felt everything else was in favour of the 15-85.
The only downside, and for me it was quite a pain, was lens creep. It was quite bad by the time i came to sell it. The 17-55 had none of this for me.
I went to full frame about 4 years ago so sold all my EF-S gear, but not before trying to buy another 17-55. I had two that were decentred and gave up, and got a 5Dmkiii lol.
Now i have a 80D i wanted to get the 17-55 again. I actually got it a few days ago. So far im not over the moon with it. Ive been using a 18-135 STM and 10-18 as my daily lenses, and have been over the moon with these, even thoug hi still have my 24-70 f/2.8 mkii.
I tried the Sigma 18-35 f/1.8 and couldn't get a reliable AF with it. Its very sharp when it does nail AF, but i had a lot of soft shots with it and had to give up.
So,  the 17-55. It has everything gi need, on paper, but ive not seen anything that makes it stand out IQ wise, over the cheaper lenses i own.
That being said, at this time of the year here in the UK we have a lot of gloomy days, so having f/2.8 and IS will be very welcome, and its these two features im missing on my other lenses so ill stick with it, even if it means not having stellar IQ. At least this lens isnt decentred.
 dave_bass5's gear list:dave_bass5's gear list
Canon EF 24-70mm F2.8L II USM Canon EF 35mm F2 IS USM Canon PowerShot S110 Canon EOS 5D Mark IV Canon EOS M50 +10 more
(unknown member) Forum Member • Posts: 83
To me the crux of your issue is that you want a significantly wider range that will not require you to change lenses in the field.  The two lenses that you have indicated do cover a slightly wider range than your current 18-55, but certainly in the case of the 17-55 barely so.
As you may see from my profile I have a lot of Canon gear, including at one time a 17-55mm lens. I was frankly disappointed with the IQ and sold it. I have actually two 15-85mm lenses and like them both because of the sharpness of the images they produce and the wide range they cover, especially from the wider angle end. This lens has been described as the "secret L series lens" because of the way in which it handles a very challenging focal length range. Getting a lens with that extra 3mm on the wide end requires a lot of engineering and while the lenses have some compromises they can easily be ironed out in post processing with lightroom or Photoshop. ANY zoom is a compromise and it is unfair to compare it to say a prime lens.
I would seriously suggest you look at the Canon 18-135 IS STM lens.  It comes as a kit lens with many XXD cameras and is generally regarded as a good lens of its type.  Again it will cover a wide range, but that seems to be what what you are seeking and the two units I have owned have rendered excellent results.  The question of choice between the 15-85 and 18-135 would be where you want the extra reach?  If it is at the telephoto end, which you seem to indicate then the 18-135 IS STM is a good unit to consider and you may well pick one up second hand from someone who got it with a kit.
I was intrigued with your comment that your camera body creaked. My question would be why it should do so if you are holding the camera in the "approved manner": I.e. placing your left hand under the lens, thus carrying the weight of the lens and body, leaving your right hand to lightly manipulate the controls on the body. Consequently the grip should not be taking any significant weight except when you are porting the camera.  I still have a 650D and even with a hefty 70-200 L lens on it has never made even a whimper...
We are not remembered for the gear we use, just the images we capture or create.
I have the 15-85 and the 18-135 STM - got it in a kit with the 70D, thinking that the extra range would be nice.  But I prefer the image quality of the 15-85 over the 18-135 - it subjectively just looks better to me so the 18-135 sees virtually no use.  I'm just keeping it as a backup and with hindsight I would have bought the 70D as body-only.
plantdoc Veteran Member • Posts: 4,339
My experiences with the 15-85, 17-55, and 18-135 stm is that they will all produce very good images suitable for 13 x 19 prints or even larger, IF...  They are not decentered, which may occur only in a limited portion of the zoom range. I had this issue with the 15-85 at wide angle. One of 2, 18-135mm  stm had a noticeable problem in mid range wide angle. Also, if they focus properly and consistently. 17-55 needed a trip to Canon because it would not focus accurately on 3 different bodies at wide angle except in live view. The 15-85 needs MFA corrections and is not accurate on 2 different Rebel T series bodies. Front focusing frequently. Maybe I am just unlucky with lens purchases or I examine them too closely. i also realize that with 18-20 megapixel cameras you don't need perfection at 100% view to have excellent prints.
Greg
Macabron
Macabron Regular Member • Posts: 121
The range of the 15-85, becomes addictive!  Those extra 3mm in the wide end make a very, very big difference. You can crop to get closer to the 18-135mm, but getting a wider shot is always a pita. It is a little slow at 85mm, but you have your nifty fifty for portraits. Mine was very sharp and the IS was excellent.
Dave Sparks wrote:
I have the 15-85 and the 18-135 STM - got it in a kit with the 70D, thinking that the extra range would be nice. But I prefer the image quality of the 15-85 over the 18-135 - it subjectively just looks better to me so the 18-135 sees virtually no use. I'm just keeping it as a backup and with hindsight I would have bought the 70D as body-only.I
When buying anything, I always define exactly what I want out of the device or service I am considering, and then work back from there. A major issue is what is your output format going to be? There is a huge difference between producing output for electronic media and that for producing high quality large format prints, and in between those lie a wide range of output options.
I like both the 18-135 and 15-85mm lenses for their purposes, but as I said in my previous post the question is at what end of the range do you want the extra capability. If you want an improvement at both ends over the 18-55 then IMHO the 15-85 is the way to go. If, as I interpreted it, you want to have more reach at the telephoto end without swapping to your 55-250, then I would recommend the 18-135mm unit for that purpose or go for the excellent Sigma 24-105mm F4 DG OS HSM Art lens that has outperformed Canon's own L series 24-105 (MkI) unit in tests.
With a respectful nod to Dave's comments, which are absolutely validly based on his experience, my experience was that I did not have the same issues with my 18-135mm lenses, although I took good care to test them rigorously before purchasing.  I use a wide range of gear, from modest consumer level cameras to FF professional bodies and lenses.  The one thing I would recommend is once you decide on what you want the les to do, buy the best quality glass you can afford.  Bodies change with monotonous regularity but lenses last for a long time and I have excellent results with a good lens on a modest body.
Whichever way you go, good luck with your choice and let us know how it works out!
OP Matthew46 Junior Member • Posts: 41
I just wanted to thank everyone for your incredibly helpful advice – and to apologise for my rudeness in only just now replying.
After reading everyone's replies, I'd thought that I was certain to go for the 15-85mm. But, I hope you won't think I did think something foolish – at the last minute, I decided on the 17-55...
Like dave_bass5, I too live in the UK (and, to make things worse, near ever-overcast Manchester), and I came to realise just how useful being able to use f/2.8 on my 50mm STM has been. (As ddixon mentioned, the 50mm seems quite soft at f/1.8 – I inadvertently came across this chart and was surprised to see how much sharper it becomes at f/2.8: http://www.lenstip.com/444.4-Lens_review-Canon_EF_50_mm_f_1.8_STM_Image_resolution.html)
I think that, knowing I could foreseeably only purchase one of the two lenses, I eventually realised that I would use the 17-55 more frequently, even though the 15-85 would be the best lens for if I were travelling somewhere. I realised that this probably happens much less frequently than I take indoor or low-light shots, though.
I suppose another factor was, with how many times I've read that the 17-55 is perhaps the best EF-S lens, I would have forever wondered if I should have gone with that while I had the chance.
I really am sorry to have gone a different way to what I'd indicated – but I wouldn't want it to seem as though your advice has been wasted. If ever I'm in a position to purchase the 15-85, I feel much more confident in knowing that I'd be buying an excellent lens.
About my 650D's handle squeaking... I think you might well be right. I purchased the 55-250mm not too long after the body and, being my first DSLR, I suspect I made the mistake of walking around holding the 650D by its handle alone, only bearing the weight across both hands when taking a shot. It's something I definitely won't be repeating with my 80D!
I'd been considering the 18-135 for a while (it looks like a fantastic lens) but, when I found out about the 15-85, I realised that I'd perhaps find the extra 3mm at the wide end more useful than 135mm. It's still a lens I'd certainly bear in mind for the future, though.
On a more positive note, I'm utterly amazed by the 17-55. I can't believe how sharp it is – and, against what I'd been expecting, at f/2.8. And I really like its bokeh, too. I had an exam yesterday so, with the build up to that, I haven't managed to use it, or the 80D, as much as I'd like, but I'm looking forward to spending more time with it now.
Thanks to everyone for allaying my fears about lenses of this weight feeling unbalanced, too. The 17-55 feels reassuringly weighty on the 80D and perfectly in balance. I really couldn't be happier with it.
Thanks again to everyone for your help.
This might be the most valuable piece of advice I take away from this thread – don't try a 6D!
That's great.  The main thing is that you are happy with your choice and have gained from the discussion.  Certainly the 17-55 has a great max f-number, and I am glad you got a sharp one.  All the best with your shooting in the future.
cheers:  Trevor
totleytom Contributing Member • Posts: 564
I've got the 15-85 and have had it for some years. I've used it on a 500D; 60D; 100D; and currently a 750D. As that progression has been made, I've become increasingly dissatisfied with it. You'll note that the resolution of those bodies increases from 15mp to 18mp and now to 24mp. On the most recent body, I don't find it sharp enough.
It might just be a focusing issue but I don't think so - I know what a mis-focused image looks like and these aren't like that. I have a feeling that mine is simply not that good - slight centering issues, perhaps? - and the 24 mp sensor on the 750D is revealing that in a way the older bodies didn't. My 18-55 STM is almost as good, in fact, and the little 24mm STM prime is heaps better.
My 6D + 24-105 combination knocks the 750D + 15-85 out of the water.
 totleytom's gear list:totleytom's gear list
Canon EOS 90D Canon EF 70-200mm F4L IS USM Canon EF 40mm f/2.8 STM Sigma 17-70mm F2.8-4 DC Macro OS HSM | C Canon EF-S 24mm F2.8 STM
Interesting comments Totlytom!
One of the revealing things that the website DXO Mark (https://www.dxomark.com) website shows is that the performance of lens varies with different bodies, which is logical, but I was surprised by how much it varies. You might find it interesting to try the site using the various combination of lens and body to see what they show.
The EFS 15-85 has a major challenge in that it goes from a very wide angle to a moderate telephoto, making it in effect a super zoom. The 24-105 L has a much less challenging range of focal length because it avoids the wider angle range, and of course it ISan L series lens!
I have two each of the 15-85's and 24-105's and I use them both depending on the type of image I am trying to capture and for what purpose. I tend to keep the 24-105's for my 7D and 5DIII bodies, and use the 15-85 on my 60D and 80D bodies - where they render good results for my purposes.
I would expect that a full-frame body combined with an L-series lens would offer a significant improvement, as you have experienced. That said, there is a bit of a myth that non-L series lenses are by definition, lower quality, especially EF-S class lenses. The nature of the optics design of these lenses immediately makes them lighter and cheaper than those for FF bodies, especially if compared against the L series lenses, which are not primarily meant to deliver optimum results for cropped bodies, with the possible exception of the 7D models. Many of the newer EF-S lens actually use high quality glass combined with composite components to make them lighter and cheaper, but they tend to feel less impressive than the non-EF-S units.
As I maintain what is the best for a particular photographer is dependent on a combination of things: what the budget is, what kind of photography one engages in and especially what kind of output is required.
Ronomy
Ronomy Veteran Member • Posts: 4,062
I borrowed the 17-55mm and liked it but thought it was a bit soft at F2.8.  So I bought a Sigma 18-35 F1.8 ART which it crazy sharp especially wide open.
But for general purpose use like parties at home in close quarters I like to be able to shoot wide and also portraits without changing lenses so I picked up the 15-85.  I don't need the narrow depth of field so this lens is perfect.  Love having 24mm equivalent at parties and where I want everyone in focus.  It focuses accurately in low light too.  I can capture the entire room and also take nice portraits in the 60-85mm range.
 Ronomy's gear list:Ronomy's gear list
Canon PowerShot SD800 IS Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-FZ200 Canon EOS 7D Canon EF-S 15-85mm f/3.5-5.6 IS USM +6 more
