Monochrome sensor conversion... seeking advise
Started Nov 7, 2016 | Discussions
Johannes Zander Regular Member • Posts: 467
I have allready removed the cover glas from the sensor of a nikon V1 with a hot air rework station.
Now I want to remove the Bayer filter.
I would like some response with advise from people how did a successfull conversion.
What solvents or abrasive cleaners did you use? What tools did you use?
Did you us a demosaicing software? How did you process the files?
Thanks for any advise.
Nikon V1 sensor with removed cover glas.
https://www.flickr.com/photos/jz_in_germany/
 Johannes Zander's gear list:Johannes Zander's gear list
Nikon 1 V1 Nikon D4S Nikon Z6 II Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 24mm f/1.4G ED +21 more
Nikon 1 V1 Olympus Air
petrochemist Veteran Member • Posts: 3,619
Re: Monochrome sensor conversion... seeking advise
I've never heard of anyone doing this conversion themselves it is a VERY major job.
Removing the hot mirror is fairly common, going beyond that is asking a lot!
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
TillmanB
TillmanB Contributing Member • Posts: 501
You know photoshop has a black and white setting.
Just kidding, I don't have anything constructive to add to this, I've read that the bayer layer is not easily removed and decided against trying to do this with one of my cameras a few years back but I'm interested to see if you manage to do it.  Good luck!
BobORama
BobORama Senior Member • Posts: 2,842
Confession: The last time I had to do this was 10 years ago.  So maybe dated info.  But this is a no-harm, no foul "better living through chemistry" method that may help.
Acetone, benzene, gasoline, zylene paint thinners will dissolve several of the classes of polymers that microlenses lenses and CFA resist material are made from.  It will not attack the underlying silicon substrate or SiO later that may also have been applied as a hard coating.
You can easily test this.   Make a small disk out of white paper, about the size of a dime.  Place this on the center of the sensor.  A drop at a time, add your [ favorite solvent  name here ] till the paper is saturated, and the solvent is kept in contact with the sensor.  As the solvent evaporates, add another drop to keep is sopping wet.  Whatever keeps the solvent in contact with the surface but not flooding the rest of the sensor.
If you are a Nervous Nelly type or using a smelly solvent like gasoline, or have a twitch, do this OUTSIDE - otherwise it is surely harmful to you, your marriage, your liver, and olfactory facilities.
Keep it "topped off" for a while, like 5-15 minutes.   Then test with the Q-Tip.  The coatings should slough off.    One of these solvents will take care of business.
I don't like the scratching off method as mishaps can occur.  It works, per YouTube.   With chemicals, you can always resort to scratching if they fail.
Just the solvent absorbing into the plastic will make it swell which usually de-laminates it from the substrate.
 BobORama's gear list:BobORama's gear list
Pentax K-5 Pentax K-1 Sigma 10mm F2.8 EX DC HSM Diagonal Fisheye Pentax smc DA 18-55mm F3.5-5.6 AL WR Samyang 14mm F2.8 ED AS IF UMC +9 more
Benzene is a very nasty chemical to play with - very carcinogenic, so that It's concentration in many hydrocarbons is controlled to under 1ppm.
Toluene or Xylene (not zylene) are better options - and definitely do it in a well ventilated location, all of them have health hazards. Gasoline is probably more easily available and will typically contain about 30% of either Toluene or Xylene.
OP Johannes Zander Regular Member • Posts: 467
Thanks BobORama and petrochemist, good information and advice.
Before I read your response I allready tried the abrasive method. Well, with partial success.
As you can see, the sensor is not fully dead yet. I scratched the sensor. Also I must have damaged some of the gold wires. And since I removed the hot mirror filter, which is quite thick, the AF is off. The exposure is off also.
This is not a big loss, since I used a sensor from a broken camera I bought through Ebay. I will try to get another one for cheap.
The next sensor I will treat with Toluene.
I will post again, if there is progress.
Bayer Filter and micro lenses partially scratched off a Nikon V1 sensor.
Meuh
Meuh Veteran Member • Posts: 3,184
Any reason why you wouldn't buy a Sigma Merrill and use that in B/W selecting the blue channel only?
I know about the marrills and using the blue channel for B/W, but...
Merrills cost 400-500 EUR here in Germany used, the V1 I got for 80 EUR and I can change lenses.
Meuh
True I was lucky and got my dp3M for £330, kinda got hooked after that although I use them for color but did a few nice B/W's at times from them.
BobORama
Of course God only knows what fresh hell that will cause.  But we are rooting for you!
I like the bottom of the picture, reminds me of poorly processed Polaroid film.
In terms of the wires, they may just be shorted.  Get a 10x loupe and inspect them.  If any are touching each other you can separate them gently with a fine sewing needle.  You may be able to salvage they can take a fair amount of abuse.
BobORama
On the next one protect the wires with epoxy.
Strong-Bond 113 you can get in 2.5 or 5 gram pouches cheap.  This produces a very hard plastic when cured at room temperature - do not use the elevated temperature cure which reduces cross linking and also hardness.   Wait a week before applying solvents.   It might also protect things well enough so you can be more aggressive with your scraping, which actually looked like it was working.
Enginel Contributing Member • Posts: 946
So it's a sensor transplant?
Do I correctly understand what you removed sensor from faulty camera, shaved it and put it in working camera? That's almost like camera with interchangeable sensors, cool.
khunpapa
khunpapa Senior Member • Posts: 2,666
The astronomer is bolder than we think !
http://www.jtwastronomy.com/tutorials/debayer.html
Part I
https://www.youtube.com/watch?v=huTFrjfBzEw
Flashes of my Memory.
 khunpapa's gear list:khunpapa's gear list
Sigma DP2 Sigma DP3 Merrill Olympus E-M1 Panasonic Lumix G X Vario 35-100mm F2.8 OIS Sigma DP1 +10 more
Part I
Why would they do this, because they remove CFA with microlenses (on front-illuminated sensor), QE will surely be not any better than it was
Part I
Astronomers are working with dim light, and for nebulae are also needing a narrow wavelength range. Removing the Bayer filter allows all the sensor to be used for capturing those elusive photons, rather than just blocking around 3/4 of them (for Ha imaging at 626nm, with the hotmirror removed). Even Green O-III nebulae would have 1/2 the photons blocked by the Bayer array.
With exposures often totaling hours rather than just seconds a 4 fold sensitivity gain is understandably desirable.
bclaff Forum Pro • Posts: 13,925
Part I
We're frequently careless about what is meant by QE.
Here in the fora we generally mean of the entire stack and not just the pixel.
So removing the cut filter improves QE.
And removing the Color Filter Array (CFA) improves QE.
But removing the micro-lens degrades QE.
It appears that the net result is improved QE.
I'd love to do my usual tests on a modded camera.
So if anyone is willing to take the required raw images they should contact me.
Bill ( Your trusted source for independent sensor data at http://www.PhotonsToPhotos.net )
Photons of different energy (wavelengths) penetrate the silicon to a different depth.
Using only the blue (top) plane would not capture all the visible wavelength; only predominantly blue. You'd miss the green and red wavelengths that penetrate deeper.
These sensors have bad SNR overall and probably dark current as well (probably 2 layers could have been just fine). And they are attached to quite rare mount.
Removing IR cut filter is (reversible) and completely separate from scratching top of sensor. So only CFA/microlens need to be considered.
D Cox Forum Pro • Posts: 32,980
The top layer is miscalled "blue". It is panchromatic with a blue bias. There is no filter in front of it to remove the red and green, but some of the green and red photons do pass through it.
I was able to take three photos through Kodak colour separation filters, convert them all to monochrome as "100% blue", and recombine them in Photoshop to give a normal full colour image.
Sigma fp
