Life expectancy of Mirrorless Camera Bodies
Started Nov 5, 2016 | Polls
eques Veteran Member • Posts: 4,115
My G1 and G2 lost the soft plastic cover around the VF, my GX7 had a major repair after one year of use, the other had some (yet?) isolated problems and might soon be dying after 2.5 years.
So, what average life expectancy do you think a modern M43 camera body has?
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
POLL
less than 3 years
9.1% 3  votes
between 3 and 5 years
36.4% 12  votes
between 5 and 7 years
27.3% 9  votes
more than 7 years
27.3% 9  votes
  Show results
Panasonic Lumix DMC-G2 Panasonic Lumix DMC-GX7
Jon555 Veteran Member • Posts: 7,721
Re: Life expectancy of Mirrorless Camera Bodies
My GF1 is still good, although I don't use it any more, so that probably helps.
 Jon555's gear list:Jon555's gear list
Nikon Coolpix 950 Fujifilm FinePix Real 3D W3 Sony RX100 V Canon EOS 5DS R Panasonic GH5 +31 more
(unknown member) Senior Member • Posts: 1,505
4 years and counting for my e-m5. it's love, though it has had a rough life in my hands, and with no airtight lens at all (refractor telescope) on 98% of the time. And still kicking.
drj3 Forum Pro • Posts: 12,634
Pre Mirrorless - E510 - 8 years and still works, E5 - 6 years and still works
E-M1 - 3 years - over 200,000 shutter activations - still works
I think the cameras will work longer than batteries for them are available.
Unfortunately, they will all probably work longer than I will.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
MarkDavo
MarkDavo Senior Member • Posts: 2,458
E-M1 - 3 years - over 200,000 shutter activations - has never looked or felt like giving up.
Cheers, Mark
Always learning
 MarkDavo's gear list:MarkDavo's gear list
Olympus OM-D E-M1X Canon EOS R5 Canon RF 100-500mm F4.5-7.1L IS USM +1 more
NZ Scott
NZ Scott Veteran Member • Posts: 5,201
E-P3 three years plus, GM5 only 14 months
My E-P3 was retired to the back of my cupboard after three years and 50,000 shots. It still works fine. The mode dial fell off once, but luckily I felt it land on my foot and was able to recover it / glue it back on.
My GM5 started having problems after just 14 months and 10,000 shots. The on-off switch has become very stiff, the rear scrollwheel stopped working and the metal sheath fell off the 12-32 kit lens. Although annoyingly semi-disabled, it is still my main camera two years after purchase.
S
 NZ Scott's gear list:NZ Scott's gear list
Sony RX100 VII Olympus PEN E-P3 Panasonic Lumix DMC-GM5 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH +14 more
G1Shooter Contributing Member • Posts: 685
eques wrote: So, what average life expectancy do you think a modern M43 camera body has?
Time is irrelevant, but actual usage is relevant. If I only use my M4/3 once a year at Christmas for 10 shots, it should last forever.
 G1Shooter's gear list:G1Shooter's gear list
Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-40mm F2.8 Pro +1 more
