OK - got a flash with NX500 question or two
Started Nov 4, 2016 | Discussions
Ben Herrmann
Ben Herrmann Forum Pro • Posts: 21,163
Hey you NX die-hard Homies...
I know this is such a simple scenario, but I'm having a typical monthly brainfart and I need an assist here.
I have not yet used an external flash with my NX500 (I had previously always used the Metz 44 AF TTL dedicated for Samsung on the NX300 and NX30).
I wanted to shoot external flash today with the NX500, but nothing would function. I noticed that the "External Flash Settings" menu item in the NX500 was shaded out.  I have my regular flash to "fire always".  Yet with the Metz 44 AF attached (and on), it will not fire at all - regardless of what I do.  I keep wondering why my External Flash Settings menu item is grayed out and I don't know how to turn that on so I can adjust where needed.
My settings include Aperture Priority, AWB, Auto ISO (even tried regular different ISO's), RAW mode.  I can't think of anything else that would prevent my flash from firing with the NX500.
Do I have a defective flash - or a defective NX500?  Or a defective Ben Herrmann
Semper Fidelis...
Ben Herrmann
US Marine Corps (Retired)
North Carolina, USA
 Ben Herrmann's gear list:Ben Herrmann's gear list
Canon EOS M Fujifilm X-E2S Fujifilm X-T2 Fujifilm X-T20 Canon EOS M6 +4 more
Samsung NX300M Samsung NX500
markyboy81 Veteran Member • Posts: 4,778
Re: OK - got a flash with NX500 question or two
Have you tried a different set of batteries?
Although that probably wouldn't explain why the settings would be greyed out..
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
CyberDEL
CyberDEL Regular Member • Posts: 234
No, there is nothing wrong with your flash. Your flash, Metz 44 af1 (or it's af2?) can work wireless, only as a slave flash and only with cameras that support the wireless A-TTL system of Samsung NX, and that's only NX1 and NX30. These cameras have a built-in pop up flash that is able to work as a master flash. Unfortunately the small flash of your Camera, SEF 8, can't work as master.
There are wireless settings on the menu, which are disable now, just to work with Samsung SEF580 flash, which can work as a master on your camera to control slave flashes wireless.
The JJC FC-NX TTL-Off-Camera Flash Cord it's the cheapest way to use your flash off camera.
Dimitri D
https://www.flickr.com/photos/135820506@N02/ My Flickr Photostream
 CyberDEL's gear list:CyberDEL's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 20mm F2.8 Pancake Samsung NX 85mm F1.4 ED SSA +21 more
Finder80
Finder80 Regular Member • Posts: 267
With external I assume you mean with the flash on the hotshoe and not wireless as a previous poster suggested?
You mentioned using aperture priority mode, perhaps the shutterspeed exceeded the sync speed? I think that was 1/200th of a second on the nx500. Try setting it to S or M and keep the shutterspeed below the sync speed.
 Finder80's gear list:Finder80's gear list
Samsung NX500 Sony a7R II Fujifilm X-T3
eSteeS New Member • Posts: 10
Hi Ben,
please find out and try:
Firmware Update for both the NX500 and the 44-AF-2.
But it might not work with the 44-AF-1!
I cant promise you, but I read somewhere these days this solution, and it says it will work exclusively only with the NX 1, 30 and 500.
I wish you good luck!
eSteeS
PS I worked with the US army as an trainer here in Germany in  2004 and 2005
Ben Herrmann
OP Ben Herrmann Forum Pro • Posts: 21,163
Thanks for the belated advice...
Wow, I had forgotten about this old post - but I did solve this issue way back then (can't remember what I did, but it worked).  All has been fine now...
Sincerely,
Bernd ("Ben") Herrmann
Fuquay Varina, North Carolina USA
Ogard New Member • Posts: 12
Re: Thanks for the belated advice...
Just to be clear, is it possible to use a metz 44 af-2 off camera with an nx500 with a-ttl mode?
The wireless flash menu point is greyed out, and I cant seem to fing a solution.
 Ogard's gear list:Ogard's gear list
Samsung NX mini Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samsung NX 85mm F1.4 ED SSA +8 more
You need a commander compatible flash - either built in (NX1, NX30) or SEF580A or, apparently, Metz 44 af-2 but I don't have it to confirm. Slaves can be Metz 44 af-1 or af-2, or SEF580A (not sure about SEF42A).
Small SEF8A flash can do nothing for ATTL slaves.
