Infrared images with new GoPro Hero5 Black
Started Nov 1, 2016 | Discussions
PaulIllsley New Member • Posts: 3
I conducted a quick test and found the new Hero5 Black is capable of recording infrared images: http://www.paulillsley.com/GoPro_Hero5_Infrared
Martin Meier Contributing Member • Posts: 640
Re: Infrared images with new GoPro Hero5 Black
You can change EACH lens of action cams, using M12 lenses.
Unscrew original lens, screw in the new lens, connect HDMI to tv,
adjust sharpness.
Often they are delivered with filters or without IR cut filters.
M12 lenses you get with or without IR cut filter
IR cut filter in front of action cam with lens without IR cut filter
interchangeable lenses are no problem with action cams
M12 lens without IR cut filter ... use superglue to add an IR cut filter
 Martin Meier's gear list:Martin Meier's gear list
YI M1 Panasonic Lumix DC-GX9 Fujifilm X-T30 Fujifilm XF 16-80mm F4 +1 more
