Would you buy EOS M/M2/M3 sized FF mirrorless cam?
Started Oct 30, 2016 | Polls
crashpc Veteran Member • Posts: 7,235
Wow, M forum really goes these days!
It seems there is more and more discussion about FF Canon MILC. Opinions about how it should be done differ greatly, some don't even see a point to it, because small is not usable, and MILCs are not that evolved anyway. Canon could also use current EF mount.
I would like to know how many people would buy Small FF mirrorless camera, with current set of defficiencies like size, controls, need for adapters etc. Is it really absolute niche?
 crashpc's gear list:crashpc's gear list
Canon EOS M10 Canon EF-M 15-45mm F3.5-6.3 IS STM
POLL
Yes, small, pocketable black box with a shutter button and touch UI would be sweet! Native pancakes too!
20.0% 6  votes
It would have to have some additional features (EVF,Tilting screen, better controls), and it needs to be cheap (+-$1200)
33.3% 10  votes
No, I don't want to use tweezers for my gear.
10.0% 3  votes
It needs to stay EF mount and fully compatible, and FAST!
26.7% 8  votes
None of these / Let me write my opinion.
10.0% 3  votes
  Show results
Simion1 Regular Member • Posts: 115
Re: Would you buy EOS M/M2/M3 sized FF mirrorless cam?
I sold all my DSLR gear, everything, and bought an EOS M because I was fed up with the size and weight of my camera equipment.
When I would go abroad my entire hand luggage was camera equipment and by the time I reached my destination my shoulder muscles would be aching like a b#*tch. Likewise, after a whole day shooting my left bicep would also tell me to pack it in. For me my camera equipment became an inconvenience and a burden and I found myself just not bothering to take my camera anywhere anymore. That's when I decided to buy an EOS M with a 22mm prime, which is small/light with a decent sized sensor and have never looked back. A bit like an assassin going from a sniper rifle to a knife.
So to answer your question, I am happy with the image quality and the depth-of-field  APS-C sensors give, therefore if using an APS-C sized sensor instead of a 35mm sensor means smaller and lighter bodies and lenses, then I will obviously choose APS-C every single time without fail. However, when I think back to the 35mm film days, there were small compact camera's that used 35mm film perfectly well, so if a full-frame mirrorless camera meant something like an Olympus mju-ii just with a 35mm sensor instead of 35mm film, then sure. EF lenses however, nope, I'm glad to see the back of them.
OP crashpc Veteran Member • Posts: 7,235
Hi. It seems we have two similar polls, where the oter one has more discussion in it. I believe we should stay in the other one. I´ve read what you wrote, and I absolutely agree...
jpr2 Forum Pro • Posts: 15,554
Re: what other FF + MILC thread/poll ?
crashpc wrote:
It seems we have two similar polls, where the other one has more discussion in it. I believe we should stay in the other one.
could pls. you post a direct link - as it doesn't seem to be as clearly marked in the subject line as yours - or perhaps was old and no longer on the I-st page?
jpr2
I thought you posted in there already...
https://www.dpreview.com/forums/thread/4072349
Jefenator
Jefenator Senior Member • Posts: 2,866
I like a decent sized body with a real grip and a built-in VF but I definitely do have a use for a smaller "stealth" body as well.
My original EOS M currently occupies that chair but I've been itching to update. Full-frame would be pretty sweet. I've been hoping Sony would issue a bare bones FE body but I would be tickled pink to see Canon beat them to the punch. (That rumor of a fixed-lens RX1 competitor gets my toes wiggling as well...)
 Jefenator's gear list:Jefenator's gear list
Sony a7 Canon EF-M 11-22mm f/4-5.6 IS STM Sony FE 55mm F1.8 Sony FE 90mm F2.8 macro Sony Alpha NEX-7 +8 more
Agree with the RX1 competitor.
MikeJ9116 Veteran Member • Posts: 6,955
I would only buy something this small if it had IBIS and a nice set of lenses designed to take advantage of it.
Glassfish Regular Member • Posts: 478
The smaller size body would be an ideal but if it is also going to support the current EF lenses with or without and adaptor, then it needs a decent size body for good grip and balance (the M isn't that welding for either EF-S/EF lenses).  I suspect it will be some thing between the M5 body and the 5D/6D.  It would need to have EVF for a few reasons.  I am not sure it can start at $1200 though. I suspect it would be $2000+ rather.
thank you! No I didn't (reply there) as none of the options presented are even close to what would tempt me into FF:
  • the RX1 and RX1r were close to be such a dream cam, thanks to their size and the sensor's IQ,
  • BUT... the lack of a built-in EVF (preferably NOT akin to a fake pentaprism, but rather RF-like form-factored little brick, of the Nex-7 size, shape & functionality),
  • and esp. neither RX1 nor RX1r being a true MILC had pushed me away
So, the closest to this poll options the "M5-like FF with EF mount and FAST" wins my vote.
However, a small RF-like brick shaped FF, with a built-in EVF, will be even better - much, much better actually
jpr2
nnowak Veteran Member • Posts: 9,074
Option #2 is not remotely realistic
Sure, who wouldn't want a full frame camera for $1200.  Wanting it does not mean it is realistic.
Option #2 basically describes an M5 with a full frame sensor.  The M5 is $950.  A full frame version will cost a LOT more.  If you want a very reasonable estimate, look at the price difference between and 80D and a 6D.  The bodies are very similar with the sensor size being the primary difference.  That would put a full frame M5 around $2000.
