Preferred mirrorless future
Started Oct 29, 2016 | Polls
nnowak Veteran Member • Posts: 9,074
Assume we cannibalize the full frame DPAF sensor from the 5DIV and live view AF works great.  For $2000 would you prefer...
For the full frame EF-M options, assume full frame EF-M lense are introduced at the same pace as existing crop EF-M lenses.
POLL
M2 with full frame sensor (EF-M mount)
7.8% 5  votes
M5 with full frame sensor (EF-M mount)
40.6% 26  votes
Mirrorless 6D with EVF (EF mount)
17.2% 11  votes
None of these. Crop sesnors are good enough for me.
26.6% 17  votes
Undefined other - pleas define in comments
7.8% 5  votes
  Show results
Alan Sh Senior Member • Posts: 2,757
Re: Preferred mirrorless future
It;s a very interesting question - not, for me the mirrorless bit - but crop vs full. For years, I've been using crop sensors _20D-50D, then 7D) before I got my 6D. I print off the best ones up to A1 in size (I have an A1 printer) and frame them round the house.
I do not have very many 6D (FF) pictures up - so I actually voted for a crop sized sensor as I don't actually see the need for a FF one. I am sure there will be many who will now dismiss me as a heretic and burn me at the stake, but I stand by my Opinon.
Now, if they did produce a FF M5, I might still be interested, but I would need to be convinced as to its use for me.
Alan
 Alan Sh's gear list:Alan Sh's gear list
Canon EF-M 55-200mm f/4.5-6.3 IS STM Panasonic Lumix DMC-ZS40 (TZ60) Canon EOS M100 Canon EOS M50 Fujifilm X-T5 +13 more
lumenite Senior Member • Posts: 1,207
I would like to have #2 M5 with full frame sensor (EF-M mount).
However, I can wait for several months or a year for a better price, thinking of Sony A7 or A7R's current price.
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
b00mer Forum Member • Posts: 84
I think it'd be interesting if it was either FF or even aps-h with an eye towards low light performance, so like 20mp. I think it'd be great if it handled video well like a 1080 that was actually downsampled (from 2.5k maybe?) for increased quality. Just some pie in sky ideas
 b00mer's gear list:b00mer's gear list
Panasonic G85 Sony a7R II Canon EF 75-300mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Panasonic Leica DG Summilux 15mm F1.7 ASPH +3 more
OP nnowak Veteran Member • Posts: 9,074
The 6D started out at $2100.  After 4 years it is down to $1500.  In the three years since announcement, the A7 and A7R have dropped $600 and $400 respectively.
The A7II has been around for almost two years now and the pricing has not dropped at all.
You may have quite a wait.
ttbek Veteran Member • Posts: 4,869
I assume the APS-C no change option doesn't get the price hike?
For me M doesn't need to be a FF system, but it's not something I would object to so long as it gets a crop raw option.
My long term plans for the M system are probably different than most here.  I see M as the future home of my NX glass with Samsung being down and out.  That, and as a more convenient Canon option for MF lenses and being a light camera option some of the time though I'm not adverse to throwing big lenses on either.  I see the M5 more as a replacement for my 100D for now than anything else.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
Are there any adapters out yet for adapting NX to EF-M?
Well, because I do not need high resolution of A7R, I would be satisfied with A7 or A7II's Canon version.
According to the following page, the launch price of both A7 and A7ii was $1700, which is already less than $2000.
https://www.dpreview.com/reviews/sony-alpha-7-ii
MikeJ9116 Veteran Member • Posts: 6,955
I want a 6D2 with an OVF and an EVF.  Make it a true hybrid and send shock waves through the entire DSLR camera market.
That would be the $4000 option and still require the presence of a mirror.
I want the mirror so I can have the OVF. All I need Canon to do is install an EVF in the upper left corner of the camera as you are looking at the back plate. It could even be a popup design like Sony uses. IMO, Canon could do this easily and for little cost. Then I can have a model that gives me most of the benefits of both systems. When the mirror locks up I can have nearly all the function of an MILC. With it down I have a fully functioning DSLR. If I can have both I wouldn't care about the size of the body because the lenses I would be using would dictate a larger body be used.
No, I will make one. Working on EF to NX now, M is the same protocol as EF so the reverse won't be much more work to do.
crashpc Veteran Member • Posts: 7,235
Seems we have a copy.
Well, you propably know my opinion. I would be all over M2 with FF sensor, but I would go for M5 with FF, if there was no other option...
 crashpc's gear list:crashpc's gear list
Canon EOS M10 Canon EF-M 15-45mm F3.5-6.3 IS STM
Simion1 Regular Member • Posts: 115
I sold all my DSLR gear, everything, and bought an EOS M because I was fed up with the size and weight of my camera equipment.
When I would go abroad my entire hand luggage was camera equipment and by the time I reached my destination my shoulder muscles would be aching like a b#*tch. Likewise, after a whole day shooting my left bicep would also tell me to pack it in. For me my camera equipment became an inconvenience and a burden and I found myself just not bothering to take my camera anywhere anymore. That's when I decided to buy an EOS M with a 22mm prime, which is small/light with a decent sized sensor and have never looked back. A bit like an assassin going from a sniper rifle to a knife.
So to answer your question, I am happy with the image quality and the depth-of-field APS-C sensors give, therefore if using an APS-C sized sensor instead of a 35mm sensor means smaller and lighter bodies and lenses, then I will obviously choose APS-C every single time without fail. However, when I think back to the 35mm film days, there were small compact camera's that used 35mm film perfectly well, so if a full-frame mirrorless camera meant something like an Olympus mju-ii just with a 35mm sensor instead of 35mm film, then sure. EF lenses however, nope, I'm glad to see the back of them.
Icypeak Senior Member • Posts: 2,523
Something for a serious adventure/wilderness/travel photographer/videographer, would tempt me, even if it cost $3000.  An M5-style body with full weather-sealing, larger buttons that could be identified by feel with a thinly-gloved hand, larger grip and battery for cold-weather shooting, 4K video, 35MP or more resolution, time lapse stills, zebras for video exposure, and fully-articulated LCD for both horizontal and vertical composition would tick my list.  No more crippled cameras, top-shelf features!
David
kotmj Contributing Member • Posts: 571
Sony makes such a camera today.
Yes, according to specs and prices, Sony's bodies are my preference. What I long for in Canon is something like A7II and I think that Canon won't produce such things.
The problems that I have are that I have Canon gears such as lenses and flashes already and that I am too lazy to change Canon to other brands.
I do not think the Sony A7II is a Canon slayer. I would be equally happy with a 6D. Not based on specs but just the experience of using them. Where the Sony wins for me is twofold: on-sensor focussing and short flange distance. The first allows wanton use of the superlative Sigma Art lenses with fast and accurate AF every single time without the need for AF fine tuning with the dock. The second allows just about any lens ever manufactured to be mounted on the Sony via adapters, some which provide AF to manual lenses (c.f. Tech Art Pro). So Sony is like Android where Canon is a more closed ecosystem like Apple.
I use all my EF lenses on the Sony with the Sigma MC-11. For my uses, they feel quite native. I am very satisfied with this solution.
My Canon 430EXII will not fire on the Sony. So I am using an old manual YongNuo on it for the time being. I find this solution tolerable. If it bugs me too much I will get a TTL flash.
My biggest concern with buying Sony were the insipid colours. I used the Sony A55 and have seen the output from the NEX5 and such and they were just very lousy. Also, there is no AWB on Sony -- it was always wildly off. The recent cameras from Sony have largely fixed the colour problem but AWB remains behind Canon. Both Sony & Canon are behind Fujifilm when it comes to AWB.
A7II, Sigma 50 Art at f1.6, manual YongNuo flash bounched off the ceiling. "Standard" jpeg profile. No post processing.
Thank you. I agree with your opinions in many ways. They are some reasons why I stay in Canon. I want both the specs of Sony A7II and the satisfying output image, affordable lenses, and accustomed UI of Canon.
If I had started my photography with a new brand a year ago, I would have chosen Fujifilm or Sony. However, I have been in Canon for a long time. While I have been eager for the fascinating bodies that other brands provide, I have not moved to them but been waiting and waiting.
I wish I had a chance to use A7II for a while. My interest in Fuji APS-C has gone away with M5's appearance.
jwilliams Veteran Member • Posts: 6,385
Camera sales are dropping like a rock.  This is probably going to mean 2 things:
1) Some great fire sales coming in the short term, but not likely on newer models.
2) Price increass in the future when the camera companies realize there is nothing they can do to stop the slide in sales and then decide to get the max dollar they can for each camera they sell.
Jonathan
