Canon 55-250 STM
Started Oct 28, 2016 | Questions
Johnmw58 New Member • Posts: 7
Canon 55-250 STM
I've just purchased a 55-250 STM and although I haven't had chance to try the lens out properly the image stabilisation seems to be  amazingly good for a lens at this price.
My question is my copy has a line on the side of the lens barrel when extended to 250mm is this the same on all copy's.
 Johnmw58's gear list:Johnmw58's gear list
Canon EOS 70D Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Canon EF 28mm f/2.8 Canon EF-S 55-250mm f/4-5.6 IS STM
anisah
anisah Contributing Member • Posts: 544
Re: Canon 55-250 STM
Don't know about all copies, as my wife only uses one of them! Yes, it does appear to have a very narrow line along the barrel when it is extended to 250mm. This appears to be a join between the two parts of the barrel when it is extended and is part of the construction of the lens.
"The good man does not use others as a tool." (Kung-fu-tse)
"The only thing certain about life is uncertainty." (Rabbi Berel Wein)
"We must learn to love the man who differs from us in opinion." (Swami Vivekananda)
"Holding on to anger is like grasping a hot coal with the intention of throwing it at someone else - you are the one who gets burned." (Buddha)
 anisah's gear list:anisah's gear list
Canon G7 X II Canon EOS 40D Canon EOS 7D Canon EOS 5D Mark III Canon EOS 7D Mark II +12 more
Charlienmr
Charlienmr Regular Member • Posts: 208
I have one that is from about two years ago and it has a faint line on the barrel as you described.
 Charlienmr's gear list:Charlienmr's gear list
Canon EOS 80D Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EF-S 24mm F2.8 STM Canon EF 50mm F1.8 STM +2 more
crashpc Veteran Member • Posts: 7,237
It's a gem for that money....
 crashpc's gear list:crashpc's gear list
Canon EOS M10 Canon EF-M 15-45mm F3.5-6.3 IS STM
OP Johnmw58 New Member • Posts: 7
Thank's for the reply's and I think it is a excellent lens for the money.
The image stabilisation is probably the best that Canon have made so far.
