Proper "rule" for pinpoint stars with M43
Oct 27, 2016
Hi all, I've read about various rules for achieving pinpoint stars on a nontracking mount but there's been some disagreement about which is correct.
I've read about the following:
the 600 rule.....on a 28mm equivalent focal length, this means a 20 sec exposure
the 500 rule......on a 28mm equivalent focal length, this means a 15 sec exposure
the 400 rule......on a 28mm equivalent focal length, this means a 15 sec exposure
the 200 rule......on a 28mm equivalent focal length, this means an 8 sec exposure
the 100 rule......on a 28mm equivalent focal length, this means a 4 sec exposure.
The particular part of the sky I'm interested in is near the celestial equator, the constellation Orion.
I did 8 sec exposures, they give me fairly round stars, but 15 sec exposure shows a lot more stars, however the dimmer stars below the belt seem to show some trailing (curiously, the brighter stars, like the ones in the belt, don't show trailing- maybe because brighter stars appear larger anyway?) I tried to go longer than 15 sec exposures, but 20 sec exposures don't show me many more stars than 15 sec (although trailing seems to be about the same), and 30 sec shows too much trailing and at that point light pollution is become too much of a factor.
With my trust old 10 mp E-520 I found the sweet spot for Orion to be 15 sec exposures at 28mm equivalent focal length for 1:1 viewing (100% pixel level) on a 19" 1280x1024 monitor, will it be the same for my 16mp E-PL6?
If so, then maybe this still applies?
https://www.dpreview.com/forums/post/56527938
I think the formula 209/FocalLength is correct for M43, but 250/FocalLength is close enough, especially if you are using JPEGs.
I made a spreadsheet calculation where I set the constraint that the star image should move the diameter of the CoC (circle of Confusion). For M43 I used a .015mm CoC, which works out to be just under 4 pixels for a 16MP sensor. I used the the maximum angular velocity, which occurs at the celestial equator, or approximately the suns path.
I get the result that the shutter speed should be faster than 209/FocalLength for an M43 camera.
