EOS 760d USB and HDMI ports not working!!!
Started Oct 22, 2016 | Questions
Ehsan94 New Member • Posts: 1
Unfortunately my new 760d (which i am fully satisfied with) makes no reaction when i connect it to my PC or TV either by HDMI or USB wire...
I don't know what is the problem! is there any thing to do with it or it's a hardware malfunction?
Canon EOS Rebel T6s (EOS 760D / EOS 8000D)
kevenh New Member • Posts: 10
Re: EOS 760d USB and HDMI ports not working!!!
You can get in that condition if WiFi is enabled.
Check that setting & update us.
 kevenh's gear list:kevenh's gear list
Canon PowerShot SX620 HS Canon EOS 450D Canon EOS Rebel T6s Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM +1 more
Rob1468 New Member • Posts: 1
Check to see if the wifi function is on ,if it is knock it off then retry with the cables , canon has incorporated if the wifi is on you can't use the cables, knock it off and it will work
DelanW New Member • Posts: 1
i also have same issue and it was sorted after disble the Wi-fi/NFC .
