C-mount Lens on Canon EOS T3
Started Oct 19, 2016 | Discussions
ccicoria New Member • Posts: 2
Hello everyone
I have been attempting to research what could make my newly purchased Fujian 35mm lens work with my Canon T3, but so far, no luck. I've found nothing.
I have an EOS body to C-mount lens adapter, but i still cannot focus the lens without going right up to the subject - which is certainly not intended, I was hoping to do shots that weren't close up.
My question is - is there anyway that I can make the lens function correctly with the camera body? The adapter is useless and too far from the mirror.  I'm starting to think there's no way to make it work, which is a bummer. I was really excited for this lens.
Canon EOS 1100D (EOS Rebel T3 / EOS Kiss X50)
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: C-mount Lens on Canon EOS T3
ccicoria wrote:
Hello everyone
Your Fujian 35mm is a C-mount lens designed to be mounted just 17.526 mm from the film/sensor surface.  The EF/EF-S mount of your T3 has the lens mount flange 44.0 mm from the sensor, so mounting with a simple ring adapter is effectively applying 26.5 mm of extension tube. As you found, good for macro, but not much else.
If you find an adapter with optical lens elements it will maintain the full focus range, but at the expense of acting as a poor teleconverter with loss of maximum aperture and image quality.
C-mount can be adapted to mirrorless systems with short mount-flange-to-sensor distance, but forget about adapting it to an SLR.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
OP ccicoria New Member • Posts: 2
Awe shoot, I was crossing my fingers!  I'll be more careful to research now - Great for macro and a very shallow focal area, but not what I was looking for. Thank you for the explanation!
