Trying to learn HDR with the Panasonic G7 and Nocticron
Started Oct 16, 2016 | Photos
mar2jeter Regular Member • Posts: 441
I have been using lightroom to try HDR. Any tips from HDR pros out there would be greatly appreciated
Comment & critique:
Panasonic Lumix DMC-G7
notorioushsg Regular Member • Posts: 103
Re: Trying to learn HDR with the Panasonic G7 and Nocticron
That's not a good start. I'm not sure what's happening with the processing but it's gone horribly wrong.
Everything has a  cartoonish look... the transition of highlights and colour off the bonnet are painful to my eyes.
In my opinion HDR is used to compensate for our cameras inability to accurately see what our eyes do... in terms of DR.
This picture has no need for HDR. I'm certainly the type that avoids HDR as a look... more one that try's to capture reality. You've pushed this way too much...
 notorioushsg's gear list:notorioushsg's gear list
Olympus E-M1 Fujifilm X-T2 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus 12-40mm F2.8 Pro +1 more
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,436
I like it.  I don't think there are rights and wrong in HDR.  So many possibilities and so many subjective views.  My only thought on HDR is don't let it take over your life, just treat it as a bit of occasional fun.
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
spencergf Contributing Member • Posts: 641
I don't see anything wrong with your shot but there was no real need to use HDR in those conditions.  At least you are trying different things and that is the best way to learn.  Keep on shooting and you will figure out what you like.
Personally, I have never "mastered" HDR.  I doubt that I ever will.  I'm still trying to figure out black and white.  (I've only been taking pictures for 50 years.)
 spencergf's gear list:spencergf's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Leica D Summilux Asph 25mm F1.4 Leica Nocticron 42.5mm Panasonic Leica DG Summilux 15mm F1.7 ASPH +2 more
tt321
tt321 Forum Pro • Posts: 13,854
This actually may be a prime candidate for multi-exposure merge, if the wind was not moving the leaves too much.
The reasons are that the highlights around the headlight and the plethora of curved reflective surfaces including both glass and metal demand very low exposures to contain all the subtle transitions, and you could lose anything in the darker areas of the frame if you try to get all of that in a single, very dark, exposure.
The problem people find with this particular treatment is in the tone mapping after the merge which threw away the highlight areas anyway removing the prime motivation for multiple exposures in the first place. And they are right in saying that if you wanted this look to begin with, you probably did not need to take multiple exposures to merge. For instance, the free Nik HDR software can likely get you this from one of the exposures in the series.
Philip Scott
Philip Scott Senior Member • Posts: 1,179
I like it as a start...has a cool, urban look. I would suggest you try the trial version of Photomatix...also get a copy of HDR Efex 2 (for free)....it was part of the Nik Software Plug-ins Bundle that is now free from Google.
Also check out Trey Ratcliff's HDR Tutorials .
 Philip Scott's gear list:Philip Scott's gear list
Olympus PEN-F Olympus 40-150mm F2.8 Pro Olympus 7-14mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro Olympus M.Zuiko 300mm F4 IS Pro +26 more
