750d issue writing to disc
Started Oct 15, 2016 | Discussions
Grinderman2016 New Member • Posts: 3
hi,
just bought a 650d and shooting now in sevilla and lisbon.
at many occasions the camera 'hangs' and the screen turns black.
When trying to shut down the camera it says 'wait while writing to disc'.
i've waiten 19 minutes but does not finish writing.
to continue i need to remove the battery and wait a couple of minutes before i am able to continue.
this hapoens randomly.
Memory is sandisk 16gb ultra.
Can anybody shed some light on this issue please.
kind regards,
vincent
Canon EOS Rebel T4i (EOS 650D / EOS Kiss X6i) Canon EOS Rebel T6i (EOS 750D / Kiss X8i)
mocha123 Senior Member • Posts: 2,497
Re: 750d issue writing to disc
Hi Grinderman2016,
It could be failing SD Card.
You need to get your photo's off the memory card. I would then do a low level format and see if that cures it.
Menu/Format card/ then put a tick in the 'Low level format' and click OK.
Good Luck.
 mocha123's gear list:mocha123's gear list
Canon EOS 70D Canon EOS 7D Mark II Canon EF 100mm f/2.0 USM Tamron SP 70-300mm F4-5.6 Di VC USD Sigma 17-50mm F2.8 EX DC OS HSM +3 more
For the price of a new card I would just buy one, it would then rule out one possible problem area.
Good luck.
OP Grinderman2016 New Member • Posts: 3
Hi mocha123,
thanks for your reaction.
I already tried that and also tried to replace the card but that id not solve the issue.
It is really happening randomly.
I can shoot a number of pictures and then suddenly the camera 'freezes' again while trying to write to disc.
Kind regards,
Vincent
shk12
shk12 Regular Member • Posts: 431
try a different cars as mocha suggested
 shk12's gear list:shk12's gear list
Canon EOS Rebel SL1 Canon EOS 80D Canon EF 50mm f/2.5 Macro Canon EF 70-200mm F2.8L IS II USM Sigma 50mm F2.8 EX DG Macro +6 more
Hi Grinderman2016,
It sounds like a bad connection between Camera and SD Card, try using a blower into the SD Card slot area or inserting and removing the SD card a few times to see if it clears. I'm thinking if it hasn't been used in a while there maybe a build up of dirt/dust or residue on the contact area.
Good Luck.
Hi,
i've tried a new card already but still the same issue.
also blew firmly in the slot but still no result.
today was desastrous could barely shoot 5 pictures and the damera 'hung' again.
flying back home tomorrow and see what i can do, otherwise i'll return it to the shop as it us still under guarantee.
vince
shk12
yes, return
