Nx3000 developer mode
Started Oct 13, 2016 | Discussions
markyboy81 Veteran Member • Posts: 4,778
Does anyone know the correct key sequence to access the developer mode on the nx3000?
Ive tried a few different sequences I've found in here, substituting the EV button for the trashcan, but no luck so far.
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
Samsung NX1 Samsung NX10 Samsung NX100 Samsung NX30 Samsung NX3000 Samsung NX300M
Re: Nx3000 developer mode
Do you have nx_dev.adj file with
smart_camera
(no new line) in it on sd card?
OP markyboy81 Veteran Member • Posts: 4,778
smart_camera
No I haven't but I'm willing to try this - how do I do it?
smart_camera
I've just seen this thread https://www.dpreview.com/forums/thread/3979382
So will give it a go - thanks!
Oyrutra
Oyrutra New Member • Posts: 16
The hack exposed in that thread didn't work for my nx3000..had any luck?
Unfortunately not. I came to the conclusion that this wouldn't work at all on the nx 3000 so got a cheap Nx 1000!
You could also try modifying the lens mount with tape to enable the lens adapter to work. There are videos demonstrating this on YouTube although I could never get it to work.
Kisaha Senior Member • Posts: 2,300
Why NX1000? Is it similar to the NX3000?
I care about unlimited video for the NX3000 but I can't find a solution, it's video performance is interesting though, much more "organic" than Nx300.
Does anyone know a similar to NX3000 video performance? Even if it records for a bit less than 1 hour is going to be perfect.
I got an Nx 1000 purely as I knew that the hack would work with this camera, and I could enable the option to shoot without a lens.
Oyrutra
I'm already using adapter with tape..it's a ok solution until I don't have to switch lenses often or in fast paced situations as it's happening to me lately, as the tape would come out of adapter and even risk to get in the camera body - googling around looks like the developer option trick is just top secret for nx3000, I found out they use Itron4 OS, if that could help find any solution? - or maybe I should just go for a easily hackable nx300
NX300 is a much better camera in anyway, well, except video! NX300 suffers from a terrible encoder. I bought NX3000 especially for the slightly more organic video performance (which I will test thoroughly in exactly 18 days from today!).
I care for the "unlimited video" option, so if anyone knows something about it (which I doubt, since this question exists for a good 3 years now), please share with us.
I just do not understand how NX300's came available. Maybe on a servicing manual somewhere?
