Is this the beginning of the end?
Started Oct 10, 2016 | Questions
shutterstutter New Member • Posts: 16
Hi,
I have been using an EF100-400mm L (mark I) for the last few years now (on and off) and hadn't used it for a while.
Today I took it out for a spin and noticed a serious "clunk" each time the stabiliser kicked in (and stopped for that matter).
I am talking a serious metallic kind of clunk that is very much audible and can also be felt when putting your hand around the front of the barrel!
Now I am quite sure that this clunk was not there on the past and am wondering if this is the first step in the failing process of my IS?
Do any of you, who have used an EF100-400, ever had this happening to their lens, and if so, what was the end result...?
Thanks!!
OP shutterstutter New Member • Posts: 16
Re: Is this the beginning of the end?
Oh C'mon people, it's not that much to ask!
Absolutely Useless!! Thanks so much for all the technical feedback...
I should probably have asked something like: "Should I buy the EF100-400mm L Mark II or wait for the Mark III?????  Or is the Eos M5 better than the Eos 6D MarkII...
I out of here, so all the best and HAPPY GAS!!
Rant over
Steve Balcombe Forum Pro • Posts: 15,582
9
Rant over
Well what a nice guy you are. I think we'll be better off without you.
DugT
DugT Senior Member • Posts: 1,159
5
Your bad title is to blame. You didnt ask your real question.
https://www.flickr.com/photos/28286266@N02/sets/72157651767602507/
I never killed nobody and I didn't rob that train.
dt
 DugT's gear list:DugT's gear list
Canon EOS 6D Canon EOS 7D Mark II Canon EOS 5DS Canon EF 50mm F1.8 II Canon EF 100-400mm f/4.5-5.6L IS USM +5 more
BlueRay2 Forum Pro • Posts: 14,816
Hi,
Thanks!!
if you are so interested, send your "clunky" lens to canon repair service center and they can let you know what is wrong your lens and how much it'll cost to fix it. sounds like it'll cost a  large wad of cash to fix it so i'd be thinking and planning to buy a new 100-400 II in the near future if you want to replace your clunky lens
gavin
gavin Veteran Member • Posts: 8,242
You can feel IS come on but its very slight and not a clunk.
 gavin's gear list:gavin's gear list
Sony RX100 III Canon EOS 5D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-85mm f/4-5.6 IS USM +5 more
Dave
Dave Veteran Member • Posts: 6,231
Please choose another forum to get political.
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
James Larsen
James Larsen Veteran Member • Posts: 4,500
6
People get offended way too easily these days. Seriously OP, you really just made everyone not want to help you out.
I love Nature & Wildlife Photography, along with Cinematography.
http://jameslarsenphoto.weebly.com/
 James Larsen's gear list:James Larsen's gear list
Canon EOS 6D Canon EOS 80D Canon EF 85mm F1.8 USM Canon EF 24-105mm f/4L IS USM Canon EF-S 10-18mm F4.5–5.6 IS STM +3 more
tonyjr
tonyjr Veteran Member • Posts: 5,295
I guess I am not the only one that reads posts that pertain to me 1st and later ones I might be interested in .
 tonyjr's gear list:tonyjr's gear list
Canon EOS 400D Canon EOS 7D Canon EF 35mm F2.0 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +14 more
riknash Veteran Member • Posts: 6,874
  1. shutterstutter wrote:
Hi,
Thanks!!
The beginning-end result was to get it repaired and then sell it for replacement with a 100-400 II version with a huge loss due to having to first repair it.  You could attempt to sell as-is but full disclosure would be appropriate. You could keep it after its repaired and continue to use it. You could just continue to use it and if the IS fails, simply shut it off and keep shooting.  Good luck with your decision.
 riknash's gear list:riknash's gear list
Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 24-70mm F4L IS USM Canon EF 200-400mm f/4L IS USM Extender 1.4x HTC One
KENTGA Veteran Member • Posts: 8,733
To the OP
Keep your pants on!!! I've asked several questions on different forums that didn't get replies.
 KENTGA's gear list:KENTGA's gear list
Canon EOS 7D Canon EOS 6D Canon EOS Rebel SL1 Canon EOS 80D Tamron AF 18-270mm F/3.5-6.3 Di II VC LD Aspherical (IF) MACRO +14 more
plantdoc Veteran Member • Posts: 4,339
Mine is barely audible and can feel very little. I discovered try to correct for front focusing at 400mm that IS setting 1 produced about 2 soft pictures out of 3. While setting 2 or no IS but very fast shutter speeds produced sharp pictures. Not panning, elbow rest, shutter 1/1250+. Problem not discovered during loose element and check up repair. Unfortunately this problem wasn't discovered until after the repair warranty which might have reduced the repair cost. Will try to use as is for a while. I suspect an IS repair could be expensive on top of the$250 and shipping already spent.
Greg
RedFox88 Forum Pro • Posts: 30,738
Hi,
A good chance. My bluray player started to "clunk " and now can't load/play a disc.
Thanks!!
AdriaanMeijer
AdriaanMeijer Veteran Member • Posts: 3,047
Rant over
Sorry for not replying as swift as I ought to. There were IRL things happening and all.
Now I don't have a 100-400 L (though I would buy one if I would be richer), nor did I ever own one in the past.
I do know one of my lenses makes awfull noise when IS is engaged (all the time) and the user manual of another lens tells me not to worry if it would cling when IS engaged or the engagement is ended. So I would consider my answer to your question quite worthless and therefore a waste of your and my time.
No I read your reply I learn that I was wrong. My apologies for that.
And good luck with the lens.
Gas is expensive.
All in my humble opinion of course!
If I seem to talk nonsense or you can't understand me, it's probably my English
 AdriaanMeijer's gear list:AdriaanMeijer's gear list
Canon EOS 7D Canon EOS 600D Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-200mm F4L IS USM Canon EF-S 18-55mm f/3.5-5.6 IS II +5 more
Dave
Gas is expensive.
I thought IRL cars consumed ethanol.
AdriaanMeijer
Gas is expensive.
No, Alcohol, loads of it.
Oh no, it's the drivers that consume alcohol.
I'm dazed and confused.
Who? me?
No, Led Zeppelin.
Silvex Senior Member • Posts: 1,407
Re: It might be.
Rant over
I was not going to reply until I saw this. Because even though I had that lens for a very long time, I never had that issue. And while it sounds pretty bad, I really have know idea what it means.
I generally don't reply where I have nothing valuable to offer. So don't get discouraged. It's not because nobody cares, it's because nobody knows. That is such a high quality lens, the chances of someone having that same issue and stumbling across your post is very small.
I would send it to Canon for an estimate. Good luck!
