Anybody using MFT bodies for astrophotography?
Started Oct 8, 2016 | Discussions
Bassaidai Contributing Member • Posts: 801
Re: You do not need FF here is an example.
Great photo!!! Would you mind sharing a little technical insight how it was achieved?
Thanks!
Bass
If things appear to good to be true - they're usually neither of both.
 Bassaidai's gear list:Bassaidai's gear list
Panasonic GH5 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +8 more
Grimstod Contributing Member • Posts: 598
MNE wrote:
No success tonight on the "Convergence"
In my area it didn't happen until the planets were about 5 deg above the horizon and some houses were in the way.
I haven't had any success yet taking planetary images using my scope or 135mm lens.
Anyone have success with the convergence?
No success here. I think the majority of the east coast was clouded out.
I will eventually do a video on planetary on my channel though. I do wish I could have done it for this however weather has not been good. I have not had my scope out now in two weeks.
 Grimstod's gear list:Grimstod's gear list
Olympus E-1 Olympus E-3 Olympus E-M1 Olympus E-M1 II Olympus OM-D E-M1X +14 more
MHshooter
MHshooter Senior Member • Posts: 1,010
Re: Anybody using MFT bodies for astrophotography?
Much like with "civilian" cameras, you can buy a m4/3rds astro-camera for about 1/2 the price of a FF.  But now we're talking about $3000 versus $6000 so even m4/3rds in astro cameras are not inexpensive.  But the astro versions allow greater flexibility and they have better electronics to handle the images, 16-bit, etc.
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
Grimstod wrote:
Not really. the best photos are taken with smaller sensors since they are more efficient.
This is taken with a 8mp 43rd sensor that is over 12 years old now.
Wow, beautiful.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
You can do some awesome things with MFT cameras and sensors. One of their largest advantage is that most scopes do not vignette the sensor as they do with larger sensors. I often see many photos that have huge integration time added to them to compensate for the vignetting.
Messier Object Forum Pro • Posts: 12,724
I have the opposite situation.  My m.43 cameras capture about 1/4 of my 1500mm scope’s image circle. So in effect the scope is a FF lens.
I find the m.43 sensor is great for compact objects like Globular Clusters, and especially planets where the high pixel density delivers more detail.
Peter
 Messier Object's gear list:Messier Object's gear list
Nikon Coolpix 990 Olympus C-5050 Zoom Olympus E-300 Olympus E-330 Olympus E-30 +31 more
MNE Senior Member • Posts: 2,472
Re: Why not? It’s easy now!
I’ve heard some astrophotographers prize super fast telephotos, like the old OM 250mm f/2, but I can imagine the new super zoom would do ‘as well’ on a tracking rig, etc, but that specialized type of narrow angle type of photography, certainly gets much much more demanding, in terms of optics, at which point, I’m not even sure that the sensor is such a factor, relatively.
Once, I (briefly) had a nice Questar mirror lens, I’ll never forgive myself for letting that thing go before testing it on one of my cameras! Ugh, regrets. 😩
Jan,
The “old” 200 f2 worked well because it had a large aperture. You must maximize light-gathering capability. A super zoom is likely to be too slow for any deep sky Astro photography.
 MNE's gear list:MNE's gear list
Olympus OM-D E-M10 II Olympus E-M1 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-45mm F4 Pro +2 more
tjl66 Regular Member • Posts: 123
That touches on an excellent point, sometimes people forget to check off axis performance to see how well the scope performs for the given format.  It depends on what your capturing and what your standards are as to how much off-axis degradation you will accept.  If you are capturing nightscapes you might be less worried about off-axis performance than say somebody who is doing Deep Sky imaging.
Peter, what sort of scope are you using?
Terry
All the time!
I use m43 (and 4/3s) format extensively for astrophotography.  Maybe 90% of my astrophotography is with MFT or smaller formats.  I found many of my targets are already so small that even with a MFT sensor I am cropping in including this shot of the moon made a 55 exposure stack using an Olympus em1mk2 and 1990's vintage Celestron C8 with 0.7x focal reducer.
55 x 1/250sec ISO200 images combined in Autostakkert, sharpened in Registax. Camera em1mk2.  Scope Celestron C8 at F7.
Peter
Majority of scopes though are not that long. And using something that long takes a lot of skill. My longest scope is 1000mm Fl. And I wold never wish on someone starting out to attempt anything with a FL longer then 300mm.
Peter
I would further caution using manufactures claims on image circle size. In my own testing I have yet to find a single scope that has an image circle that is 75% the size as claimed by the manufacturer.
Peter
My scope is what it is
It's my scope and I use it. I made no comment on the degree of difficulty
Ok then, but I wasn't recommending anything to anybody
Peter
Peter
I don't need to be cautioned here. I know the size of my telescope's  image circle.
But thanks anyway for your concern.
Peter
