EF 28 f/1.8 USM incompatible with Dual Pixel AF?
Started Oct 7, 2016 | Discussions
Der Bert New Member • Posts: 4
Hi everybody,
My EF 28mm f/1.8 USM focusses perfectly through the viewfinder. BUT: In Live View with Dual Pixel AF Cameras it has a front focus of about 6 to 10 cm.
This front focus is not correctable through AFMA.
I have tried three 80D cameras and one 70D camera.
The lens has been to the Canon service in Berlin and to the central Canon service in Germany. Both returned it to me with the same result: Yes, it is the lens that is wrong but they don't know what exactly is wrong nor how to fix it. They even said on their camera the lens shows a backfocus.
The Central Canon Service offered me an exchange lens for a price of 240€ while keeping my old lens without a refund. I rejected this offer.
Now here is the most interesting part: I aquired two more used lenses of the same type from ebay in hope of a working sample and both of them showed the same problem, hence I also returned them.
On the contrary every new lens of the same type I have tried in a shop focusses just perfect with Dual Pixel AF on my camera.
Canon lists the EF 28 f/1.8 USM as compatible with Dual Pixel AF. I have a strong suspicion that this is only true for newer samples.
To get a clearer picture I would like to ask any owner of this lens to test it on a Dual Pixel AF camera and post your findings here including the serial number of the lens.
I will start:
80D and 70D; front-focus; SN: 87280086
80D; front-focus; SN: 84281193
Thank you for your help!
Bert
Canon EF 28mm f/1.8 USM Canon EOS 70D Canon EOS 80D
Trevor Sowers
Trevor Sowers Senior Member • Posts: 1,605
Re: EF 28 f/1.8 USM incompatible with Dual Pixel AF?
Ef 28mm f/1.8 SN 62900319
7D MKII
This combo seems to focus perfectly with live view or through the viewfinder.
www.TrevorSowersPhotography.com
 Trevor Sowers's gear list:Trevor Sowers's gear list
Canon EOS 5D Mark III Canon EOS 5D Mark IV Canon EOS Rebel SL2 Canon EF 24mm f/1.4L II USM Canon EF 35mm F1.4L USM +21 more
jcr67
jcr67 Senior Member • Posts: 1,602
Using the Canon 28 f1.8 on my 70D in live view the af is perfect.
Serial number on lens is 80970314.
 jcr67's gear list:jcr67's gear list
Panasonic Lumix DMC-TS5 Olympus OM-D E-M10 Canon EOS R6 Canon EOS R7 Canon EF 85mm F1.8 USM +19 more
