Ultimate macro setup (macro lens+extension tubes+teleconverter)
Started Oct 4, 2016 | Discussions
Okapi001 Veteran Member • Posts: 5,145
16
So I've been playing around to see how much macro can I get with my gear. 60mm macro lens (Zuiko) + 2 extension tubes (10mm + 16mm) + MC-14 1.4x teleconverter (not intended for such a task, but works great nevertheless). I can get approx. 2.5:1 magnification, with a decent working distance of some 7 cm from the front lens. And AF works, too.
An old stamp, approximately the size of a FF sensor, with just a 60mm lens.
And with the full macro setup.
 Okapi001's gear list:Okapi001's gear list
Olympus OM-D E-M10 II Olympus PEN-F Olympus E-M1 II Olympus OM-D E-M1X OM-1 +18 more
G _ B New Member • Posts: 19
Re: Ultimate macro setup (macro lens+extension tubes+teleconverter)
Which extension tubes please?
 G _ B's gear list:G _ B's gear list
Panasonic LX100 Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +3 more
OP Okapi001 Veteran Member • Posts: 5,145
The cheapest with el. contacts from the ebay, Pixco.
dr jim Veteran Member • Posts: 6,913
Nice! Now let's see a bug or something that moves. That should be a challenge.:-D
Just for fun!
Jim
 dr jim's gear list:dr jim's gear list
Sony RX100 VI Sony a6600 Olympus E-M1 III Sony a7R V Olympus M.Zuiko Digital ED 60mm F2.8 Macro +11 more
Elemental Photography Senior Member • Posts: 1,093
Looks like fun!  I've been playing with an old Canon FD mount bellows and lenses for extreme macro setups.
A photograph is a creative interpretation of reality.
 Elemental Photography's gear list:Elemental Photography's gear list
Pentax Optio WG-2 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GH3 Panasonic GH5 +8 more
daleeight Veteran Member • Posts: 3,199
Which extension tubes are you using that gives you the AF ability?
Dale
 daleeight's gear list:daleeight's gear list
Olympus E-M1 III Nikon Z7 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +6 more
Noku Dzu Regular Member • Posts: 307
please give us the model name/number of the extension tubes.  Your images are quite impressive.  Thanks
 Noku Dzu's gear list:Noku Dzu's gear list
Canon G5 X II Panasonic Lumix DMC-GX7 Panasonic Lumix DC-GX9 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital ED 60mm F2.8 Macro +5 more
RnF Contributing Member • Posts: 634
I have had these for a few months, really happy with them. Auto focus  works great. Only issue is if you switch lenses, the camera will have to be turned off then back on to reingage the connections. Not a big deal at all.
FOTGA automatic macro extension tube for Olympus panasonic micro four thirds M4/3 https://www.amazon.com/dp/B00CANGBIK/ref=cm_sw_r_cp_apa_IHj9xbYE8K97Q
Scott Dickey
 RnF's gear list:RnF's gear list
Panasonic Lumix DMC-GX8 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic 12-35mm F2.8 +4 more
I have Pixco, but I guess Fotga and Meike (and any other similarly priced tubes of other brands) are pretty much the same. When ordering on eBay you just have to check if the tubes have electric contacts.
RobPNth Contributing Member • Posts: 849
I have just purchased some Pixco extension tubes via Amazon but the electronic contacts don't appear to work with my E-M1 Mk 1. Did you have any problem with yours?
 RobPNth's gear list:RobPNth's gear list
Olympus E-M1 Olympus E-M1 II Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus Zuiko Digital 300mm 1:2.8 Olympus Zuiko Digital 2.0x Teleconverter EC-20 +6 more
Paul80 Regular Member • Posts: 101
Check all the spring loaded pins work, my first set of these had one of the pins stuck down so wouldn't connect properly, an easy fix though if it is your issue
 Paul80's gear list:Paul80's gear list
Panasonic Lumix DMC-G6 Panasonic G85 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS +8 more
WalterK Senior Member • Posts: 2,771
Where in the chain of lenses did you put the MC-14?  I have the MC-14 to use with the 40-150 Pro, and I thought it was not to be used with other lenses except the 300mm Pro because it could protrude into the lens, damaging it.
Walter K
MC-14 gets between the camera and extension ring or adaptor (there is no glass in the ext. ring or adaptor, so there is enough clearance for the protrusion).
Thank you.
Walter K
The problem is when I  put the 10mm tube on the camera first. It doesn't lock into place. Somehow the hole doesn't line up with the camera pin.
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
There is one other thing to check, the contacts need to be sprung if you want to stack 2. I found out the hard way as unfortunately I can not get my two tubes stacked to work on my M4/3 system, and unlike my sony ones - which do stack - I noticed that the only difference I could see was that my brand of M4/3 tubes doesn't have sprung contacts.
Sorry I am not able to confirm either of the brands at the moment, as the gear is not with me today.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
