Samsung ST200F White Screen....
Started Sep 26, 2016 | Discussions
capecodbeachfront New Member • Posts: 1
This is a compact camera I use very infrequently. After not being used for nearly 10 months I charged the camera (battery had gone dead) and turned it on... only to find I had a white screen! At the advice of Samsung, I pulled the micro sd card and battery and reinstalled both. Really, that was their only troubleshooting advice! I assume this has happened to others and there must be some kind of work around?  I have already tried the usually "slam" on different corners thinking I could wake up a loose or corrated connection. No success. Card DID capture images... until I moved it off the correct menu setting for picture taking. Now I have no way to set it back because of the white screen. BTW the date on the pictures captured was wrong leading me to believe the dead battery may have contributed to the failure... Is there a way to 'reboot / reset the camera? Seems strange a lcd scrren would fail from lack of use? Not my favorite camera because of the micro SD card, but still I hate to junk it. Or pay nearly the price of the camera to get it 'diagnosed'?  Suggestions??? Thank you.
Samsung ST200F
