Dirty Sensor on G5X
Started Sep 26, 2016 | Discussions
williams359 Regular Member • Posts: 304
Dirty Sensor on G5X
So if you get dirt on the sensor is there a way of getting to it, to clean it
 williams359's gear list:williams359's gear list
Sony a9 Sony a7 III Sony FE 70-200 F4 Sony FE 85mm F1.8 Tamron 28-75mm F2.8 III +7 more
Canon PowerShot G5 X
photofan1986
photofan1986 Veteran Member • Posts: 3,840
Re: Dirty Sensor on G5X
Hmmm, well when I had such a dust speckle in my S100, shaking it for a moment with force took care of the problem. Otherwise, you'll have to send it to Canon.
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Panasonic Lumix DMC-GM5 Sony a7R III Olympus E-M5 III Panasonic Lumix G 20mm F1.7 ASPH +15 more
OP williams359 Regular Member • Posts: 304
There are four spots in total and shaking did not help. Seems silly to have a camera thats not sealed but unable to be cleaned.
cab321 Regular Member • Posts: 151
Yeah, makes you want to switch back to film, every time you wind you get a clean new sensor.
Seriously, you get dust and lint when you put it in your pocket, or salt mist near the sea.  See my previous posts if you care to read more.
 cab321's gear list:cab321's gear list
Canon PowerShot A640 Canon PowerShot G7 X Google Nexus 7 +14 more
Funkyd3121 Senior Member • Posts: 1,683
Happened twice with my G7, sent it back to Canon.  It was under warranty the first time,  2nd time, out of warranty, but has never happened since. Has not happened with my G15, but for some reason, if I'm not careful I get a fingerprint on my lens, Only with the G15 - go figure.
 Funkyd3121's gear list:Funkyd3121's gear list
Canon PowerShot G7 Canon PowerShot G15 Canon EOS 30D Canon EOS 50D Canon EOS 300D +9 more
stephent Veteran Member • Posts: 4,353
5
Hi mate you could try this, turn the camera on zoom the lens out all the way and place the end of your vacuum hose over the lens.
This is the important part only use low suction, your only moving dust not pulling the lens off.
I have done this with good results over the years, just make sure that you use low suction.
If you do pull the lens out of the camera I never wrote this
Regards.
Stephen.
Greg Gebhardt
Greg Gebhardt Forum Pro • Posts: 25,638
Quite typical with today's point and shoot cameras. Every time you extend or retract the lens air is pumped in and out of the camera.  You image looks like you might have a little lubricant splattered on your sensor.  Sometimes the cost to clean can exceed the worth of the hardware.
Greg
Jax, FL
 Greg Gebhardt's gear list:Greg Gebhardt's gear list
Canon G1 X III Leica Q2 Leica M9 Nikon D4 Sony a6600
Elyharbour
Elyharbour Senior Member • Posts: 2,705
This has gotta be one the best disclaimers I've come across on DPR
Interesting technique...
 Elyharbour's gear list:Elyharbour's gear list
Fujifilm X-T1 Panasonic Lumix DMC-GX85 Fujifilm X-E3 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +4 more
Thanks mate, it's the way of the world these days, deny everything
(unknown member) Veteran Member • Posts: 6,192
Remember that to the lawyers cruising all around us nowadays you are nothing but a tasty snack.
I hope these manufacturers can sort out this sensor dirt issues soon or confirm they are not an issue. Has anyone seen any sort of statement anywhere from any of the makers on sensor dust? if it is a situation for just 5% of users over a space of 2 years I could live with it but I am completely spooked on getting a fixed lens camera at present.
I am not saying it is a problem as I have no real idea what the situation is but caution seems the prudent action on the moment.
Why can't they make so you can unscrew the lens to get to the sensor .
Holy crap, I can not believe it but this worked a treat dust is now gone.  Now I am not saying you should try this as you could damage your camera . I was willing to take the risk and was very careful.
Thank you Stephen !!!!!!
Regards.
Stephen.
6
Test on a white wall, the dust has gone
Regards.
Stephen.
No worries mate, glad it worked out for you.
Did I mention my fee, small unmarked bills will be fine
Regards.
Stephen.
ZbigniewG New Member • Posts: 1
I created this account to say you: THANK YOU!
Your solution helped me. I had black dot on my Canon S200. I used vacuum cleaner around the lens and the dot disappeared
Thank you!!!
F8AD Regular Member • Posts: 196
Regards.
Stephen.
Now do yourself a favor, and get a Kaiser 58 mm lens cap to cover the lens when not shooting or have it in a pocket or bag - or even in dusty wind conditions.
It's a good snug fit, is plastic so it won't mark the camera, and the camera will shut down without harm if you forget to take it off when  you turn the G5X on.
 I put one on as soon as I got my 5X .
dbr49x New Member • Posts: 12
If it's the G5X Mark II then it is the 56mm, not 58mm. I've got both and the 58mm is too big.
