Re: Yongnuo YN685 firmware update, How???
kli wrote: Actually it read like they'd figured out how to possibly do it, they just didn't have a firmware update file to test their hypothesis against.
Right on! Here is the current (provisional) page 70 of TOYUG II:
Find the currently installed YN685 version
· On the YN685 Speedlite, select Custom Function 28 to display the current flash version.
Version History
1.0.0 August 2015 First factory-installed release.
1.2.2 November 2015 factory-installed version.
Requirements for Updating
A “wireless upgrade mode” is used, rather than a USB cable. A YN622C-TX acts as a proxy (agent or relay) to establish the communication link with the flash. (“***” = editorial material still required.)
· A Windows computer (an emulator may not work).
· A computer-to-USB 3.0 Micro-B cable between computer and the YN622C-TX.
· A YN622C-TX trigger with firmware version 1.10 or later. See page 53 for instructions on checking and updating the C-TX.
Updating Procedure
1. Computer - Download and instal the Flash Updater
• Download updater file e.g. http://yongnuo.com.cn/app/YNFlash_Updater_Install_V1.1.rar
• Unzip YNFlash_Updater_Install.rar
• Run YNFlash_Updater_Setup.exe to install the driver and updater in your computer.
2. Computer - Download and unzip Firmware Update files
• Go to page http://www.hkyongnuo.com ***.
• Download and expand the latest firmware e.g. ***.
• The expanded files include e.g. ***.
3. Computer - Run YNFlash Updater
• Find and run C:\Program Files\YNFlash Updater\YNFlash Updater_EN.exe"
(Use Start Menu or desktop icon.) It will ask for a language to use.
• The YNFlash Updater window should appear.
The Memo panel shows YongNuo’s flash upgrade instructions.
[About] shows e.g. “Updater V1.1”.
4. YN622C-TX - Connect to Computer
• Turn off YN622C-TX.
• Connect the C-TX to your Windows PC via a USB Micro-B cable (not supplied)
• Hold down [GR] and turn the C-TX on again.
The C-TX displays yn | 685 | up.
• Device information should appear in the Updater window, e.g. ***
5. YN685 Flash
• Press [Mode] on the YN685 to enter wireless upgrade mode.
6. Computer - Instal the Firmware
• Click "Browse..." to navigate to the required “.dfu” version, and open.
• Check that the firmware version is as expected, then click [Start].
• When completed, the Updater will show e.g. “*** updated successfully”.
The flash will re-start automatically, using the new version.
• Turn off the C-TX and disconnect USB cable.
• Close updater window.
