Re: Maybe not the best idea
OmarAl wrote:
PhotoTeach2 wrote:
Very interesting you said that. So basically like a Xenon flashtube and a lightbulb, you're still discharging with the LED?
Well ... I think that is a yes ...
Very good, I should've known this already, I think it was because I'm typing all this in the early hours of the morning
But as you discovered and mentioned below, there is no "capacitor", (or at least not one in the same sense as there is in a flash/strobe where it is "the" essential component and the basics of its technology).
Because of it's simplicity, does that mean it doesn't necessarily require a capacitor quick-fire rounds of flashes?
I would have to see the actual schematic to be more specific to a specific unit.
The other day I opened up my LED Ring Flash and from what I can see there is absolutely no capacitor, it's extremely simple, just a circuit board with a small chip inside. I also photographed it so I would've have to open it up again. Does it interest you to have a look at them perhaps??
Sure, but would be able to tell more from a schematic, (I am an electronic engineer so could immediately "read" it).
And yes, there is no "capacitor" in the sense there in in flash/strobe.
It is basically like a normal FLASHLIGHT / TORCH, (and the "chip" is probably a "timer").
Also does it only need the electrical short from the camera to lit the LEDs??
Just so I am not confused, does this electrical short trigger something in the flash device to make the flash happen?
Yes, the capacitor is charged to 300-500vdc and then "discharges" though an "arc".
Or is this electrical short the actual "electrical power" that lights up the LEDs??
Well, it is an "arc" .... like LIGHTNING. It literally is a tiny "lightning" strike/arc confined within the tube. It puts out a LOT of light, for a VERY SHORT duration, (less than 1/1000sec and can be as short as 1/50,000sec.).
I ask all this because like I probably implied in my previous posts, could one theoretically replace a flashtube with a standard lightbulb of the same wattage and still get the same results??
Absolutely not ... they are totally different in that the (xenon) tube is an ARC, (a very FAST/SHORT duration arc -- from a 300-500v charged capacitor).
In this case I would like to ask, can a xenon Flashtube work as a continuous light, yes or no?
Absolutely NOT ... No Way ... not even close to the same.
Either way, if the Flashtube was given lower voltage, would it simply not light up? Or it will light up but at lower brightness??
It won't "fire" (arc) at less than the 300-500vdc.
Have you ever seen a "small" lighting strike ... they are all big and bright and LOUD.
Because it was my understanding that flashtubes vs lightbulbs are "very different beasts".
Absolutely YES !!! (very different)
I am beginning to understand this more and more thank you to all of you, much grateful!
Well, it does not seem like you understand it very well, but you sorta have to be an engineer/technician to fully understand the technology, (especially the "cut-off" circuitry which can be even more complex). This (cut-off) circuitry must actually STOP the ARC after it starts. It is like stopping a lighting-strike after it starts. Quite amazing.
I worked on X-Ray equipment for 20 years, and we used that same technology to "time" an X-Ray pulse. (albeit at voltages up to 150,000 volts, instead of 300-500).
YES ... I am still alive so "learned" to be VERY CAREFUL, (w/ 150KV).
But you can be dead even from the charged capacitor @ 300-500vdc.
