Canon Rebel EOS XS probably with obturator problems. (according to shop)
Started Sep 25, 2016 | Discussions
EM17 New Member • Posts: 6
Hello, I have an old camera, Canon Rebel EOS XS, I have several years with it and it don't even take video. Is one generation earlier than the first one with the video feature. Anyway, it just developed an issue. When taking any photo, randomly some black shadow appears on the photo and the rest of the photo just appear very brillant, sometimes I only have the black shadow. And when I say shadow I mean a black object, not transparency.
I was looking if it was worth to repair so I went to a Canon certified shop in my country (MX) and the price they asked was just too much for this camera, something like 150 USD. I see some available on Amazon for 180 bucks, so I wont repair it with a certified shop. What are my options if I would like to repair it? Do you think is possible? Their diagnostic was "Obturator circuit needs replacement".
I tried basic cleanup and lens swap, but the black spot remains.
When I move my camera drom landscape to portrait, or just some vibration, the black object dissapear for a couple of shots but then come back with other movements.
So, as a summary, there is something its worth to save on this camera? I am techy and would like to try a DIY project, so with my problem description do you think I need the obturator?
Thanks!
R2D2 Forum Pro • Posts: 26,551
Re: Canon Rebel EOS XS probably with obturator problems. (according to shop)
Thanks!
I believe that would indicate a bad shutter.  Can you post a couple of pics?
TIA,
R2
seri_art
seri_art Veteran Member • Posts: 3,063
What is an obturator?
 seri_art's gear list:seri_art's gear list
Sony RX100 III Canon EOS Rebel T7i Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +3 more
"Shutter" mi amigo.
R2
seri_art
R2D2 wrote:
"Shutter" mi amigo.
R2
Gracias
OP EM17 New Member • Posts: 6
seri_art wrote:
R2D2 wrote:
"Shutter" mi amigo.
R2
Gracias
Haha sorry, I used google translate for that one, it seems is not the most used terminology.
Thanks!
Thanks!
TIA,
R2
Hello, here a couple of pics:
Here one of the front of the camera, with the 'Clean sensor manually feature' Is this normal:
sleibson Regular Member • Posts: 444
From that last photo, it appears you have something loose in the mirror box. This is a mechanical failure of some kind and needs repair or you need to replace the camera body. Given its age, I'd recommend replacement with a newer Canon camera body.
Steve Leibson
www.sleibson.com
Shooting with Canons for 40 years
 sleibson's gear list:sleibson's gear list
Canon PowerShot G12 Canon EOS 20D Canon EOS 60D Canon EOS Rebel SL1 Canon EF 50mm F1.8 II +10 more
EM17 wrote:
Yeah, your shutter is off the track.  It would take a significant amount of disassembly (methinks) to get at.
You might be better off upgrading to this SL1 screaming deal.
R2
You are right, If I look closely I can see how the shutter arms move, but it seems that the blades are decoupled.
How does these kits work:
http://www.ebay.com/itm/2-PCS-New-Shutter-Blade-Curtain-Replacement-for-Canon-450D-550D-500D-1000D-600D-/251786441116?hash=item3a9fa4319c:g:TtwAAOSwPe1T5eoB
I saw some videos and it seems is a big deal to disassemble all the stuff just to get there, but if I already decided not to pay for a professional service (I quited and price was too high!), change the blades worth the try?
There is a second option, and is to chane all the mechanism, but is abit more money and is a used parto, so I believe the failure probability will be higher.
Any opinion? Maybe I just need t trash this camera
Hey, if you have the electromechanical skills and the small tools required to disassemble a camera and a shutter mechanism and then put it all back together with hope of making it work, then go for it. At the worst, you'll waste only three or four hours, ruin the camera (which is already broken, so no loss), and be out only $3.99 for shutter blades. It might be a satisfying experience depending on who you are. It will certainly be a learning opportunity to see how a camera is constructed. With 50 years of experience taking things apart and putting them back together again, I wouldn't touch this.
If you'd rather spend the same time outdoors shooting photos, then buy a new camera body. Shutter failure on old bodies is not unusual. The shutter takes a beating every time you press the button and take a photo. Your XS is not economical to repair at this point, in my opinion. It's gone past its end of life from my point of view. There are plenty of inexpensive and excellent new and used cameras from Canon and other makers swirling around us.
Steve Leibson
www.sleibson.com
Andy C Knight Contributing Member • Posts: 758
Hi,
If you like to take things apart, then for only 3.99 it's worth a go.
Alternatively if too much hassle and you find an easy way to remove the obscuring shutter blade... It should still be OK for long exposure night Photography.
Regards
Andy.
