Olympus 60mm (Macro) with EC-14
Started Sep 23, 2016 | Questions
antesoles Junior Member • Posts: 26
Hey ho,
can the Olympus 60mm f2.8 Macro can be used with the EC-14 tele converter?
If yes, what does it mean? Can the max. distance between object and lens, that is necessary to achieve 1:1 magnification, be enlarged? From now around 8 inches to 11 inches?
Greets,
ante
 antesoles's gear list:antesoles's gear list
Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8
Arizona Sunset
Arizona Sunset Veteran Member • Posts: 3,797
Re: Olympus 60mm (Macro) with EC-14
It cannot be used with the EC-14.
I am not sure about it's minimum focus distance.
 Arizona Sunset's gear list:Arizona Sunset's gear list
Canon G7 X II Sony RX1R II Sony RX100 VI Apple iPhone 7 Plus
Skeeterbytes Forum Pro • Posts: 23,182
I can't envision a way to adapt them together, given the EC-14 is four-thirds mount and current adapters are four-thirds to m4/3, not the inverse. You can indeed adapt the EC-14 to an m4/3 body but a 4/3 lens has to mount to the teleconverter.
FWIW the 50/2.0 macro is a brilliant lens optically, but lacks the 60's many features and fast focus speeds.
Rick
OP antesoles Junior Member • Posts: 26
Ok, I guess I understand that. Thank you
Jan Steinman
Jan Steinman Senior Member • Posts: 1,015
No. The EC-14 is for 4/3rds lenses; the 60 macro is a µ4/3rds lens. The two have incompatible mounts.
You can use the EC-14 between a 4/3rds lens and a 4/3rds —> µ4/3rds adapter. It seems to get along very well with the outstanding 50-200/2.8-3.5 zoom.
 Jan Steinman's gear list:Jan Steinman's gear list
Olympus 7-14mm F2.8 Pro Olympus E-3 Olympus E-300 Olympus Air Olympus PEN-F +47 more
