Why would you buy EOS M5?
Started Sep 23, 2016 | Polls
lumenite Senior Member • Posts: 1,207
If you buy EOS M5 in the near future, what would be your main concern?
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
POLL
EVF
11.6% 8  votes
Intuitive controls
1.4% 1  vote
Dual Pixel AF
68.1% 47  votes
Digic 7
0.0% 0  votes
9/7 fps
0.0% 0  votes
3.2" LCD
2.9% 2  votes
Others
15.9% 11  votes
  Show results
Prio Utomo
Prio Utomo New Member • Posts: 8
Re: Why would you buy EOS M5?
i will buy IF canon make L-like high quality cheap EFM lens
 Prio Utomo's gear list:Prio Utomo's gear list
Canon EOS M3 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 55-200mm f/4.5-6.3 IS STM
OP lumenite Senior Member • Posts: 1,207
It sounds like you will never buy it.
Tom Caldwell Forum Pro • Posts: 46,273
EF to digital EF-M
Availability of focal reduction adapter for EF lenses.
This is the first EF-M body where te use of a wide range of EF lenses could be seriously contemplated (has evf).
Tom Caldwell
Nigel Tafferham Forum Member • Posts: 59
Glad to see the M5 but not interested, rather have a 80D !  Best of both worlds.
Small size but not much else or anything superior, and I suspect for a while the prices will effectively be almost same.
So still a personal pref thing - but glad an M can now focus !!!!!!
justmeMN Forum Pro • Posts: 10,705
I'm outraged that the Canon M doesn't have Dual Pixel CMOS AF!
I'm outraged that the Canon M doesn't have a built-in EVF!
Oh wait, the latest model has both.
davev8
davev8 Veteran Member • Posts: 4,833
you have the 11-22....its probably best in class...its the sharpest UWA canon has ever made for APS-c....is as sharp or sharper than the £2500GBP 11-24F4L (when on APS-c)
the 22f2 is better than the £800GBP sony zeiss 24mmf1.8 (just)
the 28 f3.5 is a very unique lens
there are more GOOD affordable lenses for the M than Sony APS-c has... like the 18-55 and 55-200 are better than sony has for APS-c
just some more f2 primes are needed
My 5D IS a MK1 classic
emmm.....no way to win this discussion ......my favorite camera will look bad...what to do what to do.......DELETE THE THREAD.....again.......i win
 davev8's gear list:davev8's gear list
Canon EOS 5D Canon EOS R6 Canon EF 50mm F1.4 USM +5 more
davev8
Re: EF to digital EF-M
Tom Caldwell
i cannot see the point of FR adaptors ......you take a compact camera body....put a expensive heavy  glass filled adaptor on it, put a big FF lense on it trying to emulate the IQ of FF but just not  managing it...  but as a by product you get as big and expansive camera as FF
.................just buy a 6D and be done with it ..second hand a 6D is £200-250 GBP cheaper than an M5
M5+meterbones = £1600GBP
6D S/H+ nothing    =£850 GBP
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
6
Even the original M focuses very well. Not lightning fast, but very accurate. And, it actually focuses faster than the vaunted A6300 for most of my uses. That's because the time between deciding what to focus on and taking the shot is a lot less with the M. I just tap on the screen with touch shutter enabled. With a camera without touchscreen, like the A6300, you have to move the focus spot to what you want using various directional keys. The A6300 may have lightning fast AF once the focus spot is over your subject, but the time it takes to move the focus spot is a lot more than the time it takes to tap on the screen of the M. Depending on how you use the camera, this can actually make the M a faster camera than the A6300. I know it sounds hard to believe, but it's true. Of course, if you don't like to move the focus spot around a lot, the A6300 will be faster, but I'm constantly moving the focus spot. The new feature on the M5 of using the screen to select the focus point while looking through the EVF is by far the most interesting aspect of the camera for me. All current cameras (with the same sensor size) give the same IQ, when used with equally good lenses. It's the usability features that really distinguish them.
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
Same here.
Moreover, the latest one provides a better control!
crashpc Veteran Member • Posts: 7,235
Not easy answer on that one.
Handling
Updated sensor
Updated AF
EVF
Higher burst rate
cheap awesome lenses
That´s about it.
 crashpc's gear list:crashpc's gear list
Canon EOS M10 Canon EF-M 15-45mm F3.5-6.3 IS STM
yahoo2u
yahoo2u Contributing Member • Posts: 715
If you already know what you're buying, you should have no concerns whatsoever. A majority of togs have already done their homework when departing with their money.
 yahoo2u's gear list:yahoo2u's gear list
Sigma DP2 Merrill Olympus OM-D E-M5 Nikon D610 Nikon D4S Nikon D810
gettybored New Member • Posts: 7
DPAF and touchpad AF when using EVF make it the most intuitive camera. So which option should I check?
 gettybored's gear list:gettybored's gear list
Canon EOS 5D Mark II Canon EOS M3 Canon EF 85mm F1.8 USM Canon EF 24-70mm F2.8L II USM Canon EF-M 22mm f/2 STM
StormPhoto New Member • Posts: 5
Would love to use it with the new Samyang/Rokinon 50 mm f/1.2
Double Infinity Weddings - http://www.88weddings.com
 StormPhoto's gear list:StormPhoto's gear list
Canon EOS 7D Canon EOS 6D Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF 200mm f/2.8L II USM +6 more
dgumshu
dgumshu Veteran Member • Posts: 4,623
I'm thinking of buying one, as I'll be able to use my EF lenses, it has a viewfinder, 24mp APS-C, and will do 7fps.
 dgumshu's gear list:dgumshu's gear list
Canon EOS-1D X Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R5 OM-1 +52 more
jhunna Senior Member • Posts: 2,727
Dave you are so right, f2 primes are the one hole that's left in the ef-m line of lenses.
I would LOVE pancake 17mm f1.8 efm prime.  45mm, 70mm primes would complete the trifecta for my purposes.
That and 4k video...
 jhunna's gear list:jhunna's gear list
Sony a7C Sony E 20mm F2.8 Sony FE 50mm F1.8 Sony FE 85mm F1.8 Sony FE 35mm F1.8 +7 more
davev8
i think it will happen ..i dont think canon will go to all the efert to make £1000GBP camera and not make cash on lenses for it
Remember sony have no new APS-c lenses in the last 3 years ...canon release 5
