Help ! G7 Problem in the Philippines. Lens attachment failed.
Started Sep 21, 2016 | Discussions
rjd1969
rjd1969 New Member • Posts: 21
Hi all
Need some help !
I'm in deep darkest Philippines and i got the error message ' Lens attachment failed. Please make sure the lens is attached correctly'.
Ive done the following :
reset the camera.
installed latest firmware.
Cleaned the contacts.
Changed battery.
Changed SD card.
Removed the lens and put the lens cover on. The camera menu barely functions and any use is very, very sluggish. I cant see any image through the viewfinder or the screen!
I was literally using the cam for 5 minutes didnt change any lenses or do anything unusual.
Hope some wise heads can offer some advice. Did a search online and cant see any quick fixes.
Richard
Panasonic Lumix DMC-G7
LMNCT Veteran Member • Posts: 4,908
Re: Help ! G7 Problem in the Philippines. Lens attachment failed.
Do you have a second battery?  If so, switch to that battery and see if it helps.  Good luck.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
It appears that you have had some problems with play back too.  Have you called the Tech line at Panasonic Repair?  You may want to check the body.
rjd1969
OP rjd1969 New Member • Posts: 21
swapped battery. still same deal. appreciate your help tho. many thanks.
windmillgolfer
windmillgolfer Forum Pro • Posts: 17,782
rjd1969 wrote:
Hi all
Need some help !
reset the camera.
Changed battery.
Changed SD card.
Just to be clear, is the lens now back on the camera? No lens, no image. Lens on with cap on, no image!
Richard
Is there a possibility of high humidity and condensation,moving from aircon environment to outside?  If so, try drying out in warm/dry location. If no desiccant available then try dry rice - put rice in tray, then stand camera on it with small piece of polythene between camera and rice.
 windmillgolfer's gear list:windmillgolfer's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GF7 +13 more
rjd1969
any ideas on the number? bought in uk and im currently in the philippines :S
will check also......many thanks for the relpy!
rjd1969
windmillgolfer wrote:
rjd1969 wrote:
Hi all
Need some help !
reset the camera.
Changed battery.
Changed SD card.
Richard
I really appreciate all the input and advice. thanks so much. lens back on. in fact several lenses.  without lens cap. still the same. will try and take to a service provider here but not hoping for too much.
rjd1969
Just to complete on the thread in case someone else has the same problem.
Left the camera alone for 2 weeks - surprise surprise came back on and is currently functioning as it should do !
Fingers crossed it stays this way.
R
Tony Collins Senior Member • Posts: 1,737
Guessing a condensation problem then.
Tony Collins
 Tony Collins's gear list:Tony Collins's gear list
Panasonic Lumix DMC-GF1 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Samyang 7.5mm F3.5 Fisheye Panasonic Leica 100-400mm F4.0-6.3 ASPH +1 more
bilbo42 New Member • Posts: 1
Just experienced the same problem with my GM 1 on vacation in Canada. After reading other folks attempts at repair, usually ending with a service center saying the problem was too expensive to repair, I decided I had nothing to lose. I gently scraped both lens and camera contacts with my pocket knife blade and reattached the lens.
Problem solved.
47872Mike Regular Member • Posts: 222
I have just had this problem for the first time with my GX80. I hadn't changed lenses. The camera's IS made a nasty noise and nothing worked.
Turning on and off, removing/re-attaching lens, and removing and re-fitting battery didn't help.
Powering up with no lens fitted and re-fitting lens while it was powered up did make it work again.
Is my camera on the way out?
 47872Mike's gear list:47872Mike's gear list
Canon EOS 20D Canon EOS 50D Konica Minolta Maxxum 7D Sony SLT-A37 Canon EOS 6D +12 more
Mike A 1959 New Member • Posts: 1
Chances are it’s the lens, not the camera. I have a G80. The same thing has happened with my rather expensive penny Leica 12-60. Obviously I’m not a happy bunny.
I know the camera is ok, as other lenses work fine. But on another body the lens does the same. Like the IS is going crazy, then the error message.
Interestingly this was a problem I had only once. I was using my M.Zuiko 45/1.8, and it had been on the camera at least a couple of hours. I remember that in the weeks leading up to this particular evening's use, I had stored the camera with a dumb adapter and manual lens on it.
My best guess for my own problem (described above) was that the camera's contacts were not quite "springy" enough to give consistent contact with my AF lens after weeks without any lens contacts pressing against them. Since this happened I have always stored the camera with an AF lens on it. It could be a coincidence that the problem didn't repeat itself, but it might not be...
