How many FastRAWViewer users here?
Started Sep 18, 2016 | Questions
zuikowesty
zuikowesty Veteran Member • Posts: 4,158
In this recent thread, there was some talk about using RawDigger and FastRAWViewer to get a more accurate report on actual RAW exposure values:
https://www.dpreview.com/forums/post/58298914
I have looked at these two programs, and while I can see how FRV can allow more accurate view of the RAW data for bracketed shots, I am not sure that it will improve my results where I am not bracketing, and I'm reluctant to introduce more steps into my workflow, as I'm always a year or more behind reviewing photos. I've used Lightroom since it was released, and it works pretty well most of the time, but I do struggle with DR issues and always seem to be making a choice between shadow detail or highlight retention.
I'm interested in hearing from those who are using FRV integrated in their workflow with another RAW processor like LR, and how it works for you. I'm using an E-M5 and E-PM2, and shoot in A mode most of the time, using the histogram and "blinkies" to check exposure, which I know is based on the JPEG settings I've chosen, which recently have been Vivid, with H/S settings at 250/5. After finding that the JPG histogram is way off (RAW shows underexposure, and histogram shows nothing, even at a setting of 10 in camera), I've changed the camera to Natural (and may try muted) to see if I can get the histogram to more accurately show what the sensor clipping levels are.
 zuikowesty's gear list:zuikowesty's gear list
Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus E-M5 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Samyang 7.5mm F3.5 Fisheye +11 more
Bill1000Evening
Bill1000Evening Regular Member • Posts: 290
Re: How many FastRAWViewer users here?
I use frv to purge images (poor focus, blown out, poor composition, unneeded images in a bracket set,...) before importing to Lr.  Although I convert to ding on import, I have Lr save a copy of the native raw file that latter gets written to a bluray disk (that I hope I never have to use).  Frv makes culling file quicker and saves backup space for me
 Bill1000Evening's gear list:Bill1000Evening's gear list
Sony a7R III Nikon Z6 Olympus E-M5 III Olympus E-M1 III Sony a7C
OzRay
OzRay Forum Pro • Posts: 19,428
I prefer to let my eyes judge whether a photo is acceptable and I adjust in Capture One to make it so.
Thoughts, Musings, Ideas and Images from South Gippsland
http://australianimage.com.au/wordpress/
TN Args
TN Args Forum Pro • Posts: 10,687
Like Bill, I sometimes use FRV because it can be useful for culling quickly, better than judging by eye. But IME the number of times this advantage happens is not all that often.
However, if you want to use it as a dynamic range improvement tool, bear in mind that FRV doesn't know your camera, so the upper and lower limits shown on the raw histogram are generic. If you want to customise those limits you need to use it in conjunction with RawDigger I believe.
Arg
"The eye is for seeing, not for thinking." —Marc Riboud
 TN Args's gear list:TN Args's gear list
Sigma dp0 Quattro Panasonic Lumix DMC-GX7 Olympus E-M5 II Sony a7R III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
OzRay
All that brings to mind is something akin to giving a WRC driver a dyno chart and suggesting that they use that to improve their driving performance.
TN Args
A good one could.
Arg
OzRay
A good one would likely snot anyone that suggested they should improve their driving skills from some technician's chart.
TN Args
No, that's the one with more talent and ego than sense. Ultimately self-limiting.
Arg
TN Args
I just want to correct myself here -- apparently FRV calculates the clipping point for each shot individually, so it is smarter than I thought. Ya live and learn.
Arg
zuikowesty
OP zuikowesty Veteran Member • Posts: 4,158
Thanks, all. I just imported several hundreds photos from yesterday's outing at the local raptor sanctuary, so I will give it a try on these.
micksh6
micksh6 Senior Member • Posts: 2,613
Yes, natural JPEG setting is much better for judging exposure using blinkies. Also I suggest to set minimal contrast, sharpness and saturation in camera. Then you should have JPEG-RAW variation reduced to ~0.3 EV. This is in daylight on white or green/yellow subjects. Variation in artificial light will be bigger. Don't know how to reduce it.
This is how Fast RAW Viewer will help for single shots - you will learn the difference between RAW and JPEG exposure in different lighting conditions.
Fast raw viewer is really fast. I use it to quickly browse hundreds of photos and see how I exposed shots, noticing mistakes. Then I press 'c' key on photos I select and FRV copies them to given folder. In the end I import that folder to Lightroom. It's much faster to do selection in FRV than in LR.
 micksh6's gear list:micksh6's gear list
Olympus PEN E-PL5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +6 more
OzRay
Far from it. Competent drivers don't require technical specifications regarding the cars that they are racing. They learn the idiosyncrasies of their race cars and provide feedback to the technicians, who then have to make adjustments as best they can.
They provide feedback on, braking, handling, power and torque delivery, responsiveness etc. All the technical specifications in the world do not translate into practical performance at the hands of the driver.
The really great drivers learn to work within the limitations of how they feel on the day, their vehicle setup, the race track, the prevailing conditions, the competition. None of these are set in stone for every race, so technical specifications are nothing to go by.
I profile my camera, my monitor, my printer and the papers that I use; they are givens, everything else is a unknown variable that I take as it comes.
